64-bit question
Discussion in 'UK Motorcycles' started by the man with no idea, Jan 3, 2011.
  1. I have, at last, got round to buying a new laptop (1). It'sonly Medion
    but seemed well specced for the price (4). What seems strange to me is
    that they've supplied a 4gb machine with 32-bit w7 installed but a
    disk for the 64-bit version in the box. So I have the choice of
    leaving it as is and not fully utilising the memory or re-installing
    w7, with all the faff that might entail.
    The question is: would it be worth the effort to go 64-bit? Others
    who've done it on this machine have found it a bit problematic. Would
    it be possible/worth partitioning and running both systems to compare
    how they run or in case something goes belly up?
  2. Bad form and all that - I deleted the notes but not the references.
    Too much wine.
  3. the man with no idea
    Do you want to use the whole 4GB? 32bit Windows won't let you.
    If not, you might as well not bother - the only reason to use a 64bit OS
    is to get round 32bit memory limitations.
    If you do, then go ahead. The worst you'll find is some weird bit of
    hardware doesn't have a 64bit driver.
    ogden, Jan 3, 2011
  4. the man with no idea
    Paul - xxx Guest
    Wotogdensaid ...
    Son had the same dilemma, but he needed to run Adobe Maya and other
    higher-end applications for 3d modelling so it made sense for him to go
    64 bit. He's had no problems at all with it, though his is a HP, not a
    Medion,
    Paul - xxx, Jan 3, 2011
  5. the man with no idea
    davethedave Guest
    What? Windows 7 32bit can't use 4gig? I thought that was the upper limit.
    What can it use then?
    davethedave, Jan 3, 2011
  6. the man with no idea
    Nige Guest
    My thinkpad is 64 bit out of the box, only issues i have had where a couple
    of non-64 version software apps.
    Nige,
    'Candygram for Mongo'
    R1
    Nige, Jan 3, 2011
  7. the man with no idea
    It can use 4gig, but will only make 2gig available to applications,
    unless you add the /3gb switch to the boot.ini.
    Krusty, Jan 3, 2011
  8. the man with no idea
    They should work fine, unless they're really, really old & have 16-bit
    installers.
    Krusty, Jan 3, 2011
  9. the man with no idea
    ginge Guest
    Plus a 32 bit OS can only address a maximum of 4GB, so some of the RAM
    is unusable due to bits of the 4GB address space instead being mapped
    to video cards, etc. Expect to actually get 3.25 GB RAM usable for
    apps on a 32 bit OS.
    ginge, Jan 3, 2011
  10. the man with no idea
    spike1 Guest
    about 3.5. the bios and hardware needs about half a gig to cover I/O, DMA
    stuff and the ROMS that the actual cards (sound cards, graphics card,
    network cards, etc) have on board.
    There's a workaround though, you need to switch on something called PAE
    (paged address extension) that splits te memory into pages, allowing access
    to the full ram, just not all at once, though the OS should hide that from
    the user.
    | |What to do if you find yourself stuck in a crack|
    | |in the ground beneath a giant boulder, which you|
    | |can't move, with no hope of rescue. |
    | Andrew Halliwell BSc |Consider how lucky you are that life has been |
    | in |good to you so far... |
    | Computer Science | -The BOOK, Hitch-hiker's guide to the galaxy.|
    spike1, Jan 3, 2011
  11. the man with no idea
    3.25GB in Windows x86
    Still doesn't let any one app use the whole lot though.
    ogden, Jan 3, 2011
  12. the man with no idea
    spike1 Guest
    True, but it's the best option 32 bitters have. Either that or lose access
    to everything above the 3.5gig mark.
    spike1, Jan 3, 2011
  13. Thanks for the reply. It seems a bit daft to have 4 and not use it. It
    seems very daft that Medion didn't ship it like that.
  14. Well, it seems that this is all going to be a bit over my head. If I
    use PAE am I likely to see an improvement in performance?
    Here's something else. I think this laptop uses onboard graphics
    normally but swaps to the nvidia card as apps demand. It is supposed
    to have 1GB of dedicated memory but also accesses system RAM. Under
    performance information the PC says the following:
    Display adapter type NVIDIA GeForce GT 425M
    Total available graphics memory 1434 MB
    Dedicated graphics memory 64 MB
    Dedicated system memory 0 MB
    Shared system memory 1370 MB
    Now I have no idea why it reports only 64MB dedicated but I'll worry
    about that later. My question is whether it might be possible to
    dedicate, say, 1GB of system memory to graphics, leaving the 3GB for
    the system to use? Or would it then leave only 2.5 available to the
    system?
  15. the man with no idea
    Mups Guest
    IIRC PAE only work if you have more than 4GB of memory and the
    applications you're running support it. I'm not even sure if Windows 7
    supports it as its a server thing.
    Mups, Jan 3, 2011
  16. the man with no idea
    No. Not in the slightest.
    Beware people claiming to have a BSc in Computer Science - it's no
    guarantee they have any idea what they're on about.
    PAE is _Physical_ Memory Extension. It extends the memory address space
    from 32bit (4GB) to 36bit (64GB) but only for the OS, not applications.
    The OS then has more memory to dish out to apps, but the apps aren't PAE
    aware so still have the 32bit limit (4GB). You not only need more than
    4GB in the host machine, but also an OS that supports PAE effectively,
    such as Windows Server (Enterprise Edition and above).
    Since you only have 4GB, and a workstation OS, PAE won't give you any
    benefit.
    My approach is to always go 64bit unless there's a specific reason not
    to. Typically odd hardware with crap drivers or apps that simply don't
    work (or aren't vendor-supported) on a 64bit host. Modern server
    versions of Windows don't even come in a 32bit flavour anymore, which
    should hint at the way the wind's blowing.
    Pass. I don't usually deal with workstations or anything with fancy
    video cards.
    ogden, Jan 4, 2011
  17. the man with no idea
    spike1 Guest
    It's about how much the CPU can actually see that's the issue.
    Without PAE, it sees 4gig, that's all it's capable of addressing and why I/O
    and other stuff gets in the way when you have 4 gig of RAM in. That's what
    32bit means. 32 bits = 2^32 which equals 4gigs.
    The cpu can't see the full RAM *AND* the I/O stuff. (and the system needs
    the I/O stuff to function so blocks out the excess RAM).
    spike1, Jan 4, 2011
  18. the man with no idea
    spike1 Guest
    Never been a windows bod personally. I knew you could turn on PAE in some
    older versions of windows so I assumed you could in 7.
    And as for the "only if apps are written for it" thing, that's just
    sloppiness on microsoft's part if true. PAE is an OS level thing, the
    applications are shielded from it in things like linux.
    spike1, Jan 4, 2011
  19. the man with no idea
    spike1 Guest
    Meeeeeeeowwwwwwwww
    spike1, Jan 4, 2011
  20. the man with no idea
    wrote:
    If the cap fits...
    ogden, Jan 4, 2011
