Discussion in 'UK Motorcycles' started by Christofire, May 29, 2006.
  1. Christofire
    Ben Guest
    Well, I said that when talking about the v-twins to rule out things
    like the SV1000. That bike could be so much better with some decent
    suspension.
    Basically I want something that handles really well. It doesn't
    necessarily need to have the top-end whack of a thousand because I
    don't use it but I've been spoilt by bikes the accelerate like stink,
    stop immediately and go round corners without even thinking about it.
    So any new one needs to do that.
    Ben, Jun 2, 2006
    #41
  2. Christofire
    oh I know - just pointing out that there are a fair few jap v-twins to
    choose from, but I'll conceed none of them are particularly sporty.
    darsy, Jun 2, 2006
    #42
  3. Christofire
    I know quite a few people with Brutales, & I've never known a bike that
    generates quite so much passion amongst its owners. They all absolutely
    adore them, even more so than the F4 (which many of them have too).
    A Brutale America is definitely on my shopping list if & when funds
    allow.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jun 2, 2006
    #43
  4. Christofire
    Hmm. Well suspension is the easiest & cheapest major factor to 'fix'
    with a trip to Maxton, as has been mentioned before. I certainly
    wouldn't let it put you off getting an otherwise perfect bike.
    I know you said "no Italians", but what about an Italian with a Suzuki
    TL1000 engine & electrics? That should take any reliability worries out
    of the mix. I know the looks are somewhat 'different', but a Cagiva
    V-Raptor 1000 sounds like it might fit the bill nicely. If they handle
    anything like SO's Raptor 650[1], you won't be disappointed.
    [1]It actually handled scarily bad at first due to 3X lowering it by
    winding the rear pre-load most of the way out. I've put it back to
    standard now & it's awesome.
    Krusty.
    Krusty, Jun 2, 2006
    #44
  5. Christofire
    Ben Guest
    It's not just suspension though, is it? It's the whole design of the
    chassis that makes something like a ZX10 or a GSXR1000 handle the way
    it does.
    It crossed my mine, but I believe it has a very low seat height which
    probably wouldn't suit me.
    The Tuono is a possibility though.
    Ben, Jun 2, 2006
    #45
  6. Christofire
    True to a certain extent, but I doubt that any modern bike with
    sporting pretensions has a chassis that's bad enough to be noticeable.
    The only thing that might be a problem, depending on your preference,
    is that the steering's either too fast or too slow. But again, both of
    those are easily tweaked with suspension adjustments.
    Krusty.
    Krusty, Jun 3, 2006
    #46
  7. Christofire
    Ben Guest
    Firestorm, no. The SP2, yes, which is why I mentioned it earlier i
    the thread.
    Not sure about owning a Honda though.
    Ben, Jun 3, 2006
    #47
  8. Christofire
    Umm most of us are hopeless at tweaking suspension!
    Hog, Jun 3, 2006
    #48
  9. Christofire
    Ah, yes I can see how that might be a problem. Well 'speed of steering'
    is very easy to adjust. If you've got a separate rear ride height
    adjuster[1], increase the height to speed up the steering, reduce it to
    slow it down.
    If you haven't got a ride height adjuster, don't try to change it by
    messing with the shock pre-load unless you want to fubar the
    handling[2]. Move the forks instead - slide them up through the clamps
    a bit to speed up the steering, down through the clamps to slow it down.
    It's fairly important to set the sag (pre-load) before doing anything
    else though, as any adjustment to that will affect the steering.
    [1] The MV is the only bike I know of that has, but I'm sure there must
    be others.
    [2] Which is exactly what Three Cross did to SO's Raptor when she asked
    them to lower it. They slid the forks up so far through the clamps it
    was tank-slapping all over the place, & backed the rear pre-load right
    off to lower the rear[3]. The result was the front suspension was the
    standard stiffness (i.e. hard), but the rear was like a trail bike.
    Needless to say this totally fucked the handling, making it squirm all
    over the place. Yet another 'clueless fuckwits' award to Three Cross
    then, & verging on criminal negligence imo. It really was fucking
    lethal.
    [3] I've now put the forks & pre-load back to where they should be, &
    it handles superbly.
    Krusty.
    Krusty, Jun 4, 2006
    #49
  10. Christofire
    Have you seen what you can get a C2 model for?
    Andy Bonwick, Jun 10, 2006
    #50
  11. Christofire
    Statto Guest
    <fx:sticks fingers in ears>
    Lalalalalalala
    Statto, Jun 10, 2006
    #51
Similar Threads
Loading...
