75 CB500T Clutch Problems
Discussion in 'Motorcycle Technical Discussion' started by elkie, Apr 13, 2004.
  1. elkie
    elkie Guest
    hi,
    No matter how much I adjust the clutch cable, the clutch will not
    release. I have bought 4 new clutch springs, have gotten new m6x25 bolts,
    I tighten the bolts down. and there is no movement at all in the pressure
    plate. I'm not sure what else to check on this. this is driving me crazey,
    one this works this bike is ready to be driven.
    any ideas on this problem?
    elkie, Apr 13, 2004
  2. elkie
    Mark Olson Guest
    Are the m6x25 bolts shoulder bolts? If you used standard bolts and
    tightened them all the way, the clutch will not release because the
    pressure plate is not be free to move away from the clutch basket.
    Did you verify that the clutch release rod moved freely from pulling
    in the clutch lever, when you had the pressure plate removed? If not,
    the problem is most likely in the clutch adjuster mechanism in the
    left crankcase cover.
    Mark Olson, Apr 13, 2004
  3. elkie
    elk Guest
    Shoulder bolts? They are not, just regualr m6 bolts. The picture in
    the manual didn't look like them.
    I'll get some of those, due i get 25m lenght bolt from end to
    flange, or 25 from end to end of the threads. Thanks.
    And everything is freely moving, except the pressure plate.
    elk, Apr 13, 2004
  4. elkie
    elk Guest
    Nope just regular bolts, manual never said anything about using
    shoulder bolts.
    how do i get these bolts. 25 from end to flange or 25 from end to
    end of threads?
    everything is moving freely except for the clutch plate.
    thanks
    elk, Apr 13, 2004
  5. elkie
    Mark Olson Guest
    I also noticed the drawing on partsfish.com didn't look like they were
    shoulder bolts, but there has to be some means of keeping the bolts from
    tightening down all the way until the pressure plate is completely tight
    against the friction plates. I suppose the bolts could simply be made
    to bottom out in the tapped holes in the basket, but that would be a
    really crap idea, and I doubt that's how Honda chose to do it.
    If you buy the bolts from Honda they will be the correct ones. They're
    only about $1 each. Don't overtorque these, they are not really very
    tight at all in my experience.
    Have you got a manual?
  6. elkie
    Mark Olson Guest
    [re: clutch pressure plate bolts]
    I would use Loctite on them, though.
