'97 TL1000s leaking coolant? Where to get parts?
Discussion in 'Australian Motorcycles' started by stevefzr, Nov 29, 2004.
  1. stevefzr
    stevefzr Guest
    My '97 Suzuki TL1000S is leaking oolant from the weep hole on the crank case
    front, near the water pump housing. I assume it's coming from a leaky shaft
    seal on the pump. Is that the case? If so, how do I fix it? Can I replace
    the seal, or do I just buy a new pump? If the latter, where do I cget one?
    Is there significant money to be saved by buying OS?
    Thanks,
    Steve C.
  2. I've had this and other related problems on a couple of Kwaks. Kwaka don't
    sell the seals for the pump, so my guess is the other manufactures won't
    either.
    That having been said, it's a pretty easy repair to do yourself, but you
    have to be prepared for your bike to be off the road while you source a
    replacement seal.
    Drain the oil and the coolant and remove the water pump.
    Completely dissassemble the water pump (this will require a press, as there
    are bearing and seals etc).
    BEWARE - THERE WILL BE CIRCLIPS IN THERE so don't just go maddly pressing
    away. Do things slowly, remove seals with needle nose pliers etc.
    Keep all the seals and bearings in as good nick as possible, then take them
    to your local bearing place, and get them to match them all for you.
    Wherever possible, replace seals without springs with sprung seals. This
    makes a fair difference to their effectiveness.
    Put it all back together, (again using a press) being careful to do
    overything in the correct order etc.
    Put new oil and coolant in.
    If you're in Sydney and don't have a press, feel free to drop around
    sometime and you can borrow mine.
    I wouldn't be riding around with a coolant leak for too long though. That
    stuff is SLIP_ER_Y!!!
    James Mayfield, Nov 29, 2004
  3. I had no problem getting waterpump seals for my Kawasaki KR-1.
    lemmiwinks.au, Nov 29, 2004
  4. Newsgroups: aus.motorcycles
    I had no trouble getting the waterpump seal from Kawasaki for my KR-1.
  5. stevefzr
    Matt Palmer Guest
    smack is of the opinion:
    No no, just ate an icecream...
    - Matt
    Matt Palmer, Nov 30, 2004
  6. stevefzr
    smack Guest
    you blew a seal?
    smack, Nov 30, 2004
  7. Sounds messy. There must have been oolant everywhere.
    You'll have to cget some more.
    Postman Pat (sorry--it's the heat)
    Pat Heslewood, Nov 30, 2004
  8. Not "water-pump" seals, water pump OIL seals. There is a big difference.
    James Mayfield, Nov 30, 2004
  9. stevefzr
    rockit Guest
    my attempt to contact you privately failed so:
    don't know where you are.... Mick Hone in Melb has been very helpful
    with me, and he runs a mail order service...
    03 9890 0304 or www.mickhone.com.au
    from the SV manual:
    before draining engine oil and coolant, inspect engine oil and coolant
    leakage
    between the water pump and clutch cover... if coolant is leaking, then
    there is a mechanical seal and a seal ring that will need inspection and
    probably replacing. The manual suggests the use of special tools... you
    may be able to remove the pump and send it for repair, but they would
    best advise you of that.
    Rockit
    rockit, Nov 30, 2004
  10. Well, according to the manual, the seal on the impeller shaft is called
    the "Oil Seal" and thats the one I replaced. It was a Kawasaki, I
    bought the seal from a Kawasaki dealer <shrug> YMMV.
    lemmiwinks.au, Nov 30, 2004
  11. Fairy Nuff.
    (Impeller shaft, or impeller housing?)
    Could be that they sell it for the KRwhateveritwas, but not for the ZX10,
    GPXTooFiddly, ZZR600 etc etc
    James Mayfield, Dec 2, 2004
  12. stevefzr
    BT leaks a bit of oolant!
    (He'll probably tell me to cget fcuked!)
    Clem
    Knobdoodle, Dec 2, 2004
  13. stevefzr
    Yeah, well, all things considered that breakdown could have been a lot
    worse. The fact that it happened at a petrol station, with a friendly
    mechanic, in a town where I knew people, next door to a parts shop
    that had the pump I needed on the shelf...
    It doesn't get much better, does it?
    BT Humble, Dec 3, 2004
  14. stevefzr
    X-No-archive: yes
    BT Humble wrote in message
    Damn; I hate it when an attempted booth-joke falls totally flat because I
    forgot that BT had a real-life leaking-coolant incident!
    Clem
    Knobdoodle, Dec 3, 2004
  15. Well, you _colud_ have had two goth girlies travelling with you who now
    needed somewhere to sleep for the night...
    big
    Iain Chalmers, Dec 3, 2004
  16. stevefzr
    Nev.. Guest
    Just be sure to clean off the black lipstick before fronting up at the IVF
    clinic.
    Nev..
    '03 ZX12R
    Nev.., Dec 3, 2004
  17. stevefzr
    Conehead Guest
    Not if you keep picking it, it won't.
    Conehead, Dec 3, 2004
  18. I bet BT couldn't wait to get home and have a "pump on the shelf" himself...
    Stops the crockery sliding about,I guess.
    Postman Pat
    Pat Heslewood, Dec 3, 2004
  19. stevefzr
    [doffs hat]
    The master!
    Clem
  20. stevefzr
    smack Guest
    thats was the best... 2004 award
    smack, Dec 3, 2004
