i recently read an article where buell touts the virtues of their low-mounted exhaust to help in "mass-centralization" in enhancing a motorcycle's directional agility, beyond a normal set of rear-mounted silencers can support. this got me thinking about the axes about which a motorcycle rotates when turning, and how the location of the exaust system (i.e., the mass) affects the rotation. the vertical axis about which a motorcycle rotates _directionally_ is actually located at the rear tire's contact-patch. in this case, the rear mounted canisters would be a benefit, as their mass is closer to that axis. however, i think _directional_ changes about this axis are relatively slow, meaning that the +/- of a particular canister placement strategy vs. another are of minimal importance in the end. that brings us to the longitudinal axis about which a motorcycle rotates when _leaning_ into turns, which is basically a straight line between the front and rear contact-patches. in this case, low-mounted canisters would be of substantial benefit, as buell's canister placement, for example, are as close to this axis as practical. compare this w/ normal rear-mounted canisters which are fairly high if mounted to the side(s) and very high if mounted above the tire in the tail. directional changes along this axis, such as that seen in quick left- and right-handers is VERY rapid, so the +/- of a particular strategy in this department are definitely worth considering. in the latter case, one can argue that the difference between tail-mounted canisters and side-mounted canisters was significant enough to drive their location on the side of the gsxr1000 despite the market demand for a tail-mounted setup. seems to me that "mass centralization" as a name is catchy, but somewhat off-target. a more aptly named strategy would be more like "reduced CG height", but it doesnt roll off the tongue nearly as well.
