A Day in court...
Discussion in 'Australian Motorcycles' started by Uncle Bully, Dec 7, 2004.
  1. Of course not top gear you clown, 2nd IIRC.
    Pat
    Brisbane, Australia
    http://homepage.powerup.com.au/~mangey/
    Who needs lockers when you got secondaries.
    CL3500/4300-> GH2600/2700-> S2A2300/3000->
    GJ1600/2000->RR3500/3900 ->GQ4200/4200
    Rainbow Warrior, Dec 8, 2004
    #41
  2. Uncle Bully
    Smiley Guest
    I tried to race a bus at a set of lights in my vw beetle once. it won.
    a semi passed me going up the tom ugly bridge once as well.
    Smiley
    Smiley, Dec 8, 2004
    #42
  3. Getting 1500w out of a 200w motor would involve some interesting tweeks (ie
    multiplying the voltage by 8), and I suspect not last very long.]
    #43
  4. Uncle Bully
    Nev.. Guest
    So that's how it works! Hmmmm... so if I swap the 12V electrics in my car
    with a 24V system, will that double the 250Kw to 500Kw? Why doesn't the
    manufacturer offer this as a factory option?
    Nev..
    Nev.., Dec 8, 2004
    #44
  5. Uncle Bully
    Nev.. Guest
    and what gear was the OP in at the time of his offence?
    Nev..
    '03 ZX12R
    Nev.., Dec 8, 2004
    #45
  6. Uncle Bully
    Neil Gerace Guest
    Because the necessary energy polarisers always seem to be out of stock ...
    Neil Gerace, Dec 8, 2004
    #46
  7. Uncle Bully
    Graham W Guest
    No.
    But if you run the alternator voltage sensing line to a resistor bridge
    instead of the battery +, you can get 24V from your alternator and
    pretty much double the electrical output available for your lights. Of
    course lots of other things are going to want conversion to cope with 24
    volts too. It's more practical with an older car or motorcycle.
    Because 12V is enough and is standard. But they are going to 42V (3 x
    12V, which is really 14V) in the next few years for much the same reason.
    See what happens if you ask a facetious question around here - some
    bastard takes you seriously!
    Graham W, Dec 8, 2004
    #47
  8. Uncle Bully
    Johnnie5 Guest
    the reason for that is more to do with higher current draws today with power
    everything which means bigger
    cables and more weight
    solution is to up volatges and reduce current
    remember a couple of years ago that BMW's 7 series was runing 2 x
    alternators which were also
    water cooled to handle the loads
    Johnnie5, Dec 8, 2004
    #48
  9. Uncle Bully
    Graham W Guest
    So were you the only vehicle in view when he pinged you?
    You need to find out if their operating procedures require you to be the
    only vehicle in view, particularly if, as a motorcyclist, you had a car
    right behind you. Ideally NOT one you've just claimed on oath that
    you've just overtaken and which is therefore travelling slower than you
    are...
    Make sure you tell the judge this. Then he'll figure if you weren't
    guilty the first time, he'll let the fine stand anyway since you just
    aid you DID speed next time.
    They're not actually required to show it to you, and even if they did,
    it would prove very little, since it doesn't show how long ago the
    reading was taken or what the unit was pointed at.
    Hilly and windy suggests they may well have got you alone.
    Just overtaken strongly suggests you had been accelerating and that your
    attention would have been on the road ahead, not the speedo. Face it,
    there's every chance you were over. You yourself say you don't believe
    you were doing more than low 60s...
    Plausible, except that the cop will swear otherwise and the court will
    believe him ahead of you. And it's just as plausible that you did get up
    to more than 10kph over the 50kph limit. In a 50 zone, 61kph or 73kph
    doesn't matter, (in Victoria) it's the same offence and the same fine.
    If you decision is based on money then you are daft even arguing. It
    will only get more expensive.
    #49
  10. Uncle Bully
    Boxer Guest
    That is the best advice i have read on the subject. Go with your strongest
    argument and stick to it. keep it simple.
    Boxer
    Boxer, Dec 8, 2004
    #50
  11. Uncle Bully
    Theo Bekkers Guest
    Which is why they changed from six to twelve volts (well.. everybody except
    VW).
    Mercedes was running dual 70 amp alternators in 68 on the 600 limo. Don't
    think they were watercooled though.
    Theo
    Theo Bekkers, Dec 8, 2004
    #51
  12. Uncle Bully
    Marty H Guest
    this is the way I'll go, a motorcyclist got off this way ealier in the year
    here in Vic, anyone have a link, it made the news.
    he prove that speding was the only safe way to overtake the car, he only got
    pinged got a few Kms over, wouldnt work for high speeds
    Marty
    Marty H, Dec 8, 2004
    #52
  13. Uncle Bully
    GB Guest
    All very good advice, particularly the 'Your Worship' bit. Given
    the inordinate number of petty criminals who seem to spend all their
    free time watching Amercian television calling the Magistrate 'Your
    Honour', calling her by her correct title might well put her in a
    good enough mood to give you the benefit of the doubt right there.
    G
    GB, Dec 8, 2004
    #53
  14. Uncle Bully
    Uncle Bully Guest
    A car was directly in front of me and turned off. If the radar was pointed
    at the car then me, surely it would have an incorrect reading?
    "I tested it on a similarly inclined road that ws zoned 70" :)
    Oh I reckon I was doing about 60 and will cop that.
    In NSW it's different.
    I'm prepared to lose a little bit of money for the experience. I don't want
    it to turn into thousands of dollars however.
    Uncle Bully, Dec 8, 2004
    #54
  15. Uncle Bully
    John Littler Guest
    What ADR is that one please ?
    JL
    John Littler, Dec 8, 2004
    #55
  16. Uncle Bully
    Peter Wyzl Guest
    : Rainbow Warrior wrote:
    : > > Most scooters are sold under 200w of power, but are quite easy to get
    : > 1500w
    : > > out of them with a few tweaks.
    : > Getting 1500w out of a 200w motor would involve some interesting tweeks
    (ie
    : > multiplying the voltage by 8), and I suspect not last very long.]
    : So that's how it works! Hmmmm... so if I swap the 12V electrics in my
    car
    : with a 24V system, will that double the 250Kw to 500Kw? Why doesn't the
    : manufacturer offer this as a factory option?
    No, assuming for argument's sake you didn't blow the crap out of everything,
    you would quadruple the power.
    In a linear system, when you double the voltage through the same resistance,
    you double the current. Power is a measure of Voltage multipled by Current,
    so the Power is quadrupled.
    12 Volts into 12 Ohms gives 1 Amp, or 12 Watts.
    24 Volts into 12 Ohms gives 2 Amps or 48 Watts.
    Electric motors vary that a little, because they have impedance as well as
    resistance and are therefore not linear.
    But, playing the game a little, in your 250 kw 12V car the current would be
    20,833.33 Amps (Must be humungous cables...) at 576 milli Ohms (0.000576
    Ohms)
    Doubling your Voltage to 24 Volts gives 41,666 Amps (definitely need bigger
    cables now) and a cool 1 MW!
    P
    Peter Wyzl, Dec 8, 2004
    #56
  17. Uncle Bully
    Rusty Guest
    http://carpoint.ninemsn.com.au/news/blankstory.asp?ID=5511
    Rusty, Dec 8, 2004
    #57
  18. Find out the Manufacturer of the Radar,
    Then see if you can get a copy of the manufacturer's guidelines and then get
    a copy of the Police Guidelines (Freedom in information act). one of the
    guidelines above will state about error due to hills, metallic objects
    behind you etc.
    I saw a story on ACA ages ago about a guy who got off by geting a copy of
    the guidelines and it showed that the cops shouldn't have been using the
    radar in that location.
    Zaphod Beeblebrox, Dec 8, 2004
    #58
  19. Uncle Bully
    Nev.. Guest
    Nev.., Dec 8, 2004
    #59
  20. Uncle Bully
    Uncle Bully Guest
    I reckon my best chance is to argue that the location of the radar is
    outside guidelines. It is a reasonable incline, there isn't a straight piece
    on the road longer than perhaps 150m (? Not sure exactly but the road snakes
    up the hill with barely no straight bits), and being suburban there's lots
    of cars parked on either side. The little I know about radar suggests this
    case is a bit dodgy, but I'd like an expert opinion if poss without paying
    through the nose for it.
    #60
