So, I'm pulled up at the lights (clutch in) and the Raptor goes from idle to zero rpm in a gentle rundown of revs - no sudden cut out, no coughing or spluttering. Pull off road and try and restart - cranks over fine but doesn't fire. Half a tank of fuel, Whack a litre of metho in in case the recent heavy rains filled it full of water. Still won't think about firing, just cranks over. Check all the fuses, all look fine but swap them anyway, sounds like the fuel pump is whirring (it's pretty quiet but i think i can hear it). Put jumper leads on to ensure it's not low voltage but it just cranks and cranks no hit at all. No error message from the ecu on the display ("check" changes to engine temp when cranking as it should), power commander lights up OK. No plugs are unplugged that I can see. Any suggestions ? Only thing I couldn't check on the side of the road was spark (and won't be able to until the weekend) which seems to be the obvious culprit. I'm thinking coil but am I missing a more obvious culprit. Shouldnt be clutch or side stand switch as they prevent the engine cranking at all, and the engine cranks over fine (and fails to crank when either are engaged). Anything else I should check ? JL
