A funny thing happened...
Discussion in 'Classic Motorcycles' started by A.Clews, Jun 23, 2009.
  1. A.Clews
    A.Clews Guest
    Yesterday I stopped off at Tesco, to get a couple of bits and bobs, on the
    way home. Parked the bike (Trident 900) on its side stand, on a slight
    slope, so that it was leaning *slightly* more than usual. Returned to the
    bike about 10 mins later, and when I hit the start button, it sounded
    laboured and didn't fire. Tried again and it hardly turned at all. Again
    and there was nothing, though the dashboard lights were on, but dimmed
    while the starter button was being pushed. It was as if the battery had
    just died, and this is a nearly-new sealed battery, fitted no more than a
    couple of months ago.
    Began to think how the bloody hell I was going to get home (9 miles away),
    and this being in a river flood plain, there were no slopes on which to
    attempt a bump-start. I then put the bike on its centre stand while I
    considered my options and who to phone for help.
    About a minute later I thought I'd give the starter one more go. This
    time it turned fairly healthily and fired, and *phew* I was able to make
    the homeward journey without further incident.
    I'm *really* puzzled what caused this non-start incident. Is it possible
    that the slight over-lean on the side-stand might have led to a fuel
    problem, but then why the apparently dead starter? It's been starting
    perfectly well on the first push of the button up till now, with no signs of
    tiredness. There were about 140 miles on the trip meter and I normally
    refuel between 170 and 180 miles, just before reserve is needed but when the
    low fuel light is on.
    Comments welcome.
  2. A.Clews
    A.Clews Guest
    Thus spake Oily () unto the assembled multitudes:
    My Trident (1993 model) is a carburated engine, not injection, but I do
    still wonder if it might have been some kind of hyraulic lock situation.
    The starter has been working fine other than this incident.
  3. A.Clews
    crn Guest
    Starter motor bearings
    crn, Jun 23, 2009
  4. A.Clews
    A.Clews Guest
    Thus spake Jim ([email protected]) unto the assembled multitudes:
    Can't be that; the switch isn't in the starter circuitry. The side-stand
    switch kills the engine only if I engage gear, which is fine by me ;-)
  5. A.Clews
    How's your oil level? If this is an 885, the crank vent pipe exits on
    the right side, goes across the back of the cylinders then into the
    airbox. If that's got some oil in it, leaning the bike further than
    normal would make it run into the airbox, causing a mild hydraulic lock.
    I know of a few 885s that have exploded after a left side drop for
    precisely this reason.
    Krusty, Jun 23, 2009
  6. A.Clews
    A.Clews Guest
    Thus spake Mike Civil () unto the assembled multitudes:
    No alarm. Never had one.
    As I implied earlier, I don't actually think it was a 'leccy problem, and
    I've rather warmed to Krusty's oil-induced mild hydraulic lock theory.
  7. A.Clews
    A.Clews Guest
    Thus spake Krusty () unto the assembled multitudes:
    *gulp*
    I haven't checked the oil level for a little while, but it almost certainly
    won't be *higher* than it should be, if that's what you were implying.
  8. A.Clews
    No, is it lower than it should be, & if so, would the reason be because
    the missing oil's swilling around in the airbox[1]. You should have a
    drain tube on the bottom of the airbox with a plug in the end - open
    that up & see what comes out.
    [1] If the rings are getting a bit tired, you could be getting some
    pressure build-up in the cases, which is forcing a bit of oil into the
    vent pipe. Normally it would just drain back into the engine again, but
    if the bike was leaning far enough on the stand, it could drain t'other
    way into the airbox.
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Well, we know for sure that it's not starter motor bearings.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jun 23, 2009
  10. A.Clews
    TMack Guest
    Possible intermittent bad earth from battery or loose battery terminal
    connection (not fully tightened when battery was replaced)? Check for
    corrosion, tighten etc.
    TMack, Jun 23, 2009
  11. A.Clews
    A.Clews Guest
    Thus spake Champ () unto the assembled multitudes:
    I did wonder myself that this might have been the case. It's just odd that
    this has happened only once before (about 2 or 3 years ago, and at that
    time I thought it was the battery was dying, and went out and bought a new
    one) and I've parked the bike on its sidestand loads of times. In fact I
    use the sidestand when it's in my garage, but the stand rests on a lump of
    wood so that the bike is only leaning slightly.
    A.Clews, Jun 24, 2009
  12. A.Clews
    A.Clews Guest
    I'll give that a go when I get a bit of time. Probably next week.
    Well, regarding the rings, even though the bike is now 16 years old, it's
    still on what I consider to be a pretty low mileage, about 39,000 miles (I
    keep thinking about a guy who had an identical model and covered 250,000
    miles in 3 years without any need for major surgery). The story was in MCN
    (so it must be true ;-) and was also on a Trident publicity leaflet (which
    I still have).
    Thanks to all for your thoughts and suggestions. Muchly appreciatedlode
    all overly, oh yes.
  13. A.Clews
    Tim Guest
    [snup]
    My Daytona (T595) does this. Fail to start it "properly" and you need to
    walk away for a few mins. Seems to be a small battery and large starter
    current drain.
    Tim, Jun 24, 2009
  14. A.Clews
    If it was enough oil to cause a mild hydraulic lock then it'd be
    chucking out some serious smoke when it started and for a minute or so
    afterwards. I have seen similar symptoms caused by excessive oil in
    the cylinder, though not on a bike.
    Pip Luscher, Jun 24, 2009
  15. A.Clews
    A.Clews Guest
    Thus spake Tim () unto the assembled multitudes:
    I used the bike today, tempting fate with another stopover in Lewes -
    though this time to buy a gallon of Harvey's Best Sussex Bitter from their
    excellent brewery shop - and the bike behaved impeccably throughout; no
    sign of the trouble I had at Tesco the other day, though in all fairness I
    did park it on its centre stand this time (didn't want to tempt fate too
    far).
    It's true however that if ever I do have trouble starting (more than two
    jabs, say, perhaps after a couple of weeks being parked up) the battery
    runs out of juice very quickly. But in 'normal' use it usually starts
    first jab.
    A.Clews, Jun 25, 2009
