A guzzi for Clem
Discussion in 'Australian Motorcycles' started by J5, Apr 18, 2008.
  1. J5
    J5 Guest
  2. J5
    JL Guest
    Where's the April 1 date on it ? Doesn't seem fair to create such a
    great hoax without even a little clue (other than the improbability of
    the engineering challenge and the fact there isn't enough distance from
    the last pair to the rear wheel
    JL
    JL, Apr 18, 2008
  3. Or the complete impossibility of getting the ECU to talk to the GPS? Or
    the adjustable keeper that runs from the chin strap of his open face
    helmet to the handlebars? Or the initial inspiration being a six-pack of
    (consumed) beer?
    I suspect there's more than one joke in the technical specs too but I
    don't read Italian.
    Andrew McKenna, Apr 19, 2008
  4. J5
    Damien Guest
    I'm just surprised you bothered to read that much of it! I gave up about
    half way through the first sentence.
    Damien, Apr 19, 2008
  5. J5
    Marty H Guest
    sadly, noy really
    Moto Guzzi 3000 ie - Specifications Engine - Engine
    Type V seicilindrico to 90 °, 6 times
    Air cooling
    Capacity 3.001 cc
    Bore and stroke 92 x 66 x 6 mm
    Compression ratio 17.8: 1
    Diagram distribution intake valve opening 24 ° PPMS
    Intake valve closing 52 ° D.P.M.I.
    Opening valve 54 ° P.P.M.I.
    Closing valve 22 ° D.P.M.S.
    Measured with game quattrolanciere-control valve 12.5 mm
    Maximum power 214.38 kW at 7600 rpm
    Maximum torque? Nm at 6000 rpm
    Power / Turning Multipoint electronic injection, sequential, fasata
    Magneti Marelli IAW5A system alpha-n; 2 bodies farfallati, diameter 40
    mm with injectors Weber IW 031, Lambda probe
    Electric starter
    NGK Spark BPR6ES
    Sewage plant stainless steel, type 2 in 1 catalysed a 3-way probe
    Lambda, silencer adjustable height
    Approval Euro 3
    Transmission - Transmission
    Currency - 5 Gears marches
    Value relationships exchange 1 ^ 17/38 = 1: 2.235
    2 ^ 20/34 = 1: 1.700
    3 ^ 23/31 = 1: 1.347
    4 ^ 26/29 = 1: 1.115
    5 ^ 31/30 = 1: 0.967
    Lubrication a shaking
    Transmission primary teeth helical gear ratio 23/36 = 1 1565
    Final transmission Cardano CA.RC Compact Reactive; double stitch
    cardanic and torque conical floating report 12/44 = 1: 3666
    Clutch bidisco dry
    Frame - Cycling
    Tubular steel frame
    Wheelbase 1,495 mm
    Avancorsa 120 mm
    Tilt steering steerer 45.30 °
    Steering angle 62 °
    Suspension front telescopic hydraulic fork, Ø 45 mm, the adjustable
    spring preload
    Tracks front wheel 320 mm
    Suspension rear monobraccio with leveraggio progressive, single
    adjustable extension and ergonomic knob for adjusting preload
    Tracks rear wheel 240 mm
    Brake earlier double-disc floating stainless steel, Ø 320 mm to 4
    piston calipers contrasted
    Brake disc rear fixed stainless steel, Ø 282 mm floating caliper to 2
    parallel pistons
    Wheels three races quarries aluminum alloy merged into shell
    Circle earlier 3.50 "x 17"
    Circle back 5.50 "x 19"
    120/70 ZR17 front tyre "
    380/25 ZR19 rear tyre "
    Electrical - Electric Plant
    12 V power plant
    Battery 12 V - 46 Ah
    Alternator 12 V - 950 W to 2,000 rpm
    Dimensions - Size
    Length 2,195 mm
    Width (handlebar) 1.370 mm
    Height (dashboard) 1,125 mm
    Seat height 1.070 mm
    Minimum ground clearance 185 mm
    Height foot driver 377 mm
    Dry weight 943 kg
    Fuel tank capacity 13 litres
    Reserve 0.5 liters
    Marty H, Apr 19, 2008
  6. J5
    Some of those stats look like shit!
    Knobdoodle, Apr 19, 2008
  7. J5
    Theo Bekkers Guest
    My desk calculator makes those dimensions 2631cc
    Comp ratio a bit high, or is it a diesel?
    Four times the weight of the two cylinder version?
    Theo
    Theo Bekkers, Apr 21, 2008
  8. J5
    Theo Bekkers Guest
    A mate of mine, who bought a Le Mans 850 when they were new, has just bought
    a 1952 Falcone.
    Now waiting for it to be shipped from Sydney.
    Theo
  9. In aus.motorcycles on Mon, 21 Apr 2008 07:37:25 +0800
    At least its a proper one and not a Neuvo.
    Ages ago at a bike show in Adelaide a Falcone and a Neuvo Falcone
    turned up.
    One of them started his bike and heads turned at the
    "thump!<pause>thump!<pause>" sound. So the other started his and the
    syncopated beat was amazing.
    Zebee
    - who thinks lamp posts are too close together for a beat every lamp
    post, even at the average Falcone speed.
    Zebee Johnstone, Apr 21, 2008
