Absolutly new to the sport
Discussion in 'Motorcycle Technical Discussion' started by pbook, Jun 18, 2004.
  1. pbook
    pbook Guest
    I am looking for advice on what to buy.
    1. budget $3500
    2. work commuter
    3. riding in national park (off road)
    4. rural mountain roads paved
    5. touring pacific northwest and deserts +1k milers
    What type of tires would you recommend?
    thanks,
    pbook
    pbook, Jun 18, 2004
  2. pbook
    John Johnson Guest
    Do you have a license? How much riding experience do you have?
    I would recommend different bikes for 2,5 than for 3,4, and I don't
    think that you'll find any single bike for 3500 that will do all of
    these things well.
    Without knowing more, I'd recommend finding a good commuter (something
    like an SV650, Bandit 600, Honda 599) bike, then expand into other
    areas, or on finding an off-road bike (XR, KLR, etc.) and expanding.
    Either way, you likely want to start with something fairly small, light,
    and without lots of plastic (quite expensive to repair if you fall
    over/hit something).
    I would strongly recommend against buying a "fixer-upper" if you need it
    to be a reliable commuter (if it's your only vehicle), unless you are
    _extremely_ keen on working on the bike...all the time. Especially if
    you're new to biking, aren't mechanically inclined, or end up wanting a
    different bike, putting that much work into your ride is going to be
    frustrating. If you want a project, things are different.
    No one set of tires is going to do 3 and 5 well.
    HTH, YMMV
    Later,
    John
    'indiana' is a noun. Leave only the noun between @ and .edu to reply
    John Johnson, Jun 18, 2004
  3. I have very little experience to offer, but just some comments
    on the nearly contradictory requirements you seem to have...
    Can't help -- I just dumped $6000 OTD for a Vespa GT200...
    Assuming similar to my use... probably any scooter in the
    150-250cc range. Many scooters even have storage space available
    /before/ adding cases.
    Probably want something with large diameter wheels (so much for
    the majority of the scooters -- even the larger wheel diameters tend to
    only reach 16", most are in the 10-12" range), and moderately long
    suspension travel (so much for the rest of the scooters). What I used to
    know as a "trail bike" 25 years ago, slightly detuned engine for
    expanded torque range at a loss of top speed, dirt bike build, but with
    full street lighting -- think they now bill them as "dual sport".
    I'd guess something in the 250-650cc range, with a bit of
    nimbleness in cornering. Almost anything qualifies.
    Reasonably large engine for sustained cruising speed, lots of
    fairings and windshields for streamlining, water cooling... Lots of
    storage boxes. Not something you'd want to take off road -- too bulky to
    navigating pot-holes, streams, and rocks. OTOH, you wouldn't really want
    to take a "trail bike" on very long sustained road trips either...
    I think almost everyone makes something suitable for this; even
    some scooters -- the Burgman 650 (?), Honda Silverwing. Not cheap...
    Dennis Lee Bieber, Jun 18, 2004
  4. pbook
    bowman Guest
    Used DR650, KLR650, or maybe even a F650 though their prices tend to run
    higher.
    bowman, Jun 18, 2004
