Accident damage
Discussion in 'Australian Motorcycles' started by Jimi, Feb 3, 2005.
  1. Jimi
    Matt Palmer Guest
    Theo Bekkers is of the opinion:
    For a bike, essentially, yes. Cars they get a little more picky about,
    because the RTA won't accept a pink slip without a brake test report
    printout.
    Indeed, although I'm not sure whether they'd work for you or against you --
    if they fail you, they'll see you again because you have to go back there
    for the recheck, which just costs them more money...
    - Matt
    Matt Palmer, Feb 4, 2005
  2. Jimi
    Theo Bekkers Guest
    And the RAC/NMRA charge $150 odd to inspect a car you want to buy? What kind
    of check will you get for $25? Hmmm, tyres... yes, four. Lights work ... OK.
    And most importantly "Does this guy regularly buy his petrol from us"?
    Theo
    Theo Bekkers, Feb 4, 2005
  3. Jimi
    Theo Bekkers Guest
    So it's not in their interest to fail anyone?
    Theo
  4. In aus.motorcycles on Fri, 4 Feb 2005 12:31:43 +0800
    The check for bikes is lights work, tyres are legal, it's not pissing
    oil, horn works. A thorough inspector who has a clue about bikes will
    also check the suspension goes up and down and the front brake can hold
    the bike still when they push on the front forks.
    The check for cars includes a brake test machine, I'm not sure about
    emissions testing.
    IT takes a mech at least half an hour to inspect and do paperwork, often
    longer, so it's a losing proposition for them.
    Zebee
    Zebee Johnstone, Feb 4, 2005
  5. Jimi
    Matt Palmer Guest
    More or less.
    They can get in a bit of shit if they pass vehicles that are totally shot,
    though, which is the only thing stopping them from rubber stamping anything
    that comes along, though.
    Our local (specialist VW dealer) has to be really picky, because they
    specialise in old vehicles -- apparently the RTA is a harder on the
    specialists because of the likelihood of older cars being crapboxes. The
    local petrol station mechanic, on the other hand, has passed my bike despite
    a lack of working horn, and just said "if the cops stop you, just tell them
    it was working when it got registered".
    - Matt
  6. In aus.motorcycles on Fri, 4 Feb 2005 12:54:24 +0800
    They have to be careful, there are checks.
    The more usual scam is to say it needs work and offer to do said work.
    I've had that from a bike shop, I declined. The one time I had a bike
    fail, it was cos the tester said "Oh come on, you don't really expect me
    to pass that front tyre do you?" and I agreed it was a bit dodgy.
    He hadn't started to fill in the form though, so it wasn't officially a
    fail.
    Zebee
  7. Jimi
    John Littler Guest
    Which is why I never take a bike to a bike shop for a pink slip.
    JL
    (then again I seem to get blue slips more often than pink slips anyway)
    John Littler, Feb 4, 2005
  8. Jimi
    John Littler Guest
    Ya reckon ? The last car pink slip I got took under 10 mins ? Probably
    closer to 5. One guy filled in the paper work while the other was doing
    the block for the brake test. 10 man-minutes.
    At the statutory $22 per, that 6x$22= $132 per hr, that's probably
    double what most mechanics are charging out for.
    The last bike BLUE slip took under 10mins (most of which was spent
    trying to eyeball the engine and chassis numbers with a torch). A pink
    slip where it's a cursory check that the numbers look vaguely the same
    (as opposed to "I really do have to check the numbers are right" for a
    blue slip) would be well under that.
    JL
  9. Jimi
    GB Guest
    I (officially) paid $18 for the bike and $28 for the car
    last month.
    G, told him to make like a duck and shove his bill up his
    arse... and since he's my little brother, he could hardly
    argue, could he!
    GB, Feb 4, 2005
  10. Jimi
    GB Guest
    Yesm there are, but said checks cut both ways. Apparently
    the RTA says that there shouldn't be too few fails, but
    there shouldn't be too many fails either.
    Apparently the RTA counsels the inspectors to the effect
    that they should be firm but fair - not complete bastards
    about it. Failing people left, right, and centre will get
    them every bit as busted as letting obvious pieces of shit
    past all the time.
    G
    GB, Feb 4, 2005
  11. Jimi
    GB Guest
    There's no emissions test. There's a magic brake test machine
    that measures pedal pressure wrt G's pulled while stopping. That's
    the brake test.
    With respect Zebee, wrong, wrong, wrong. It takes about 15
    mins to do it all, less if the other mechanic isn't busy
    and one checks the lights and the seatbelts while the other
    makes a start on the paperwork.
    In recent times, the requirements for 'rego' checks have
    actually become, er, lesser. There's not the requirement to
    invoke pedant-week wrt cancer in panels and stuff, and now
    it's a more 'safety' oriented check. On a car, bearings and
    tie-rod-ends, lights, leaks, horn/washer/wipers, tread on
    tyres, stops within reasonable distance and has seatbelts
    that work.
    Inspector has lee-way to exercise discretion wrt general
    safety and such - so the inspectors I know will generally
    fail anything 4wd with ridiculously raised suspension, give
    a "I don't want to see that next year" to any family sedan
    with a bullbar, but fail in a screaming fit the pigeon-
    pair of wankers with matching commodore utes who both
    thought it would be cool to cut off the rear muffler and
    have the exhaust exit under the body somewhere.
    WRT to 'losing proposition', no. If you can set up a steady
    stream, and do four regos an hour (or more) (which isn't at
    all a stretch), then it's actually quite reasonable money for
    people who usually charge $65-$75 per hour for labour.
    They say it's a perfectly reasonable earner.
    G
    GB, Feb 4, 2005
  12. Jimi
    GB Guest
    Charge out at $65-$75/hour, do four (car) regos in an hour
    at $28 a pop, and you're well in front.
    A minor leak isn't a safety issue. The inspections have become
    re-oriented towards safety in recent times. People don't get
    knocked back for cancer in panels and minor leaks anymore.
    As it should have done.
    G
    GB, Feb 4, 2005
  13. Jimi
    Knobdoodle, Feb 4, 2005
  14. Jimi
    Yep.
    Clem
  15. Jimi
    And not such an interesting shape!
    Clem
    (but we've got apples)
  16. Jimi
    Johnnie5 Guest
    ah yeh , i go to the guy who does the 'on bench' brake test ;)
    Johnnie5, Feb 4, 2005
  17. Jimi
    Gary Woodman Guest
    Argue? Wouldn't he just bite your knee?
    Gary
    Gary Woodman, Feb 7, 2005
  18. Jimi
    Gary Woodman Guest
    You get 12 months to re-register, without an inspection, after the
    rego lapses, in the ACT.
    Gary
    Mark Latham, former Leader of the Alternative Liberal Party: "My
    message
    to the business community is that Labor is pro-growth and
    pro-productivity."
  19. Jimi
    bcg Guest
    Closest I came to a slippery end was a cow truck going around a sharp bend
    on Cambewarra mountain (Heading south towards Nowra). Truck tipped left and
    a huge gush of crap etc spewed out of the back forming a huge slick across
    a hairpin turn.
    I went through it at snails pace and it was still very, very slippery.
    -bcg
    bcg, Feb 11, 2005
  20. Jimi
    Jack Guest
    bcg wrote:
    Gawd, you've just reminded me.
    Travelling on the Monash Freeway (Melb) outbound, and kept getting hit
    on the chest and visor by some spray. Slippery too, the front end kept
    wiggling. See a semi way up front, and accelerated to warn him that he
    was leaking hydraulic fluid, good deed for the day. Traffic was heavy
    so took several minutes, meanwhile the leathers and visor are getting
    covered by the fluid.
    Finally get up close. No, it wasn't hydraulic fluid that was pouring
    out; yes, it was a cattle truck with p** and sh** streaming out the
    back, that had covered the front of the bike, my leathers and my
    helmet. Lucky I had the visor down!
    Turned around and went home to spend the afternoon cleaning up,
    including standing in the back garden fully dressed in the leathers
    with the hose as a shower.
    Since then, have not liked cattle trucks...
    Jack, Feb 11, 2005
