Advice needed
Discussion in 'UK Motorcycles' started by Gordon Baxter, Sep 17, 2006.
  1. Thank you for your responses yesterday re my question on setting a quiz for
    Superbikes.
    Could anyone be more specific about the more technical data that could be
    included, and which to steer clear of.
    Gordon
  2. Gordon Baxter
    Cab Guest
    http://www.justfuckinggoogleit.com
    Cab, Sep 17, 2006
  3. Thanks for that. I am well aware of how to access the necessary data. the
    reason for my request was to ask 'motorbike enthusiasts' which of the data
    they would like to see in a quiz and which data would be unreasonable.
    Gordon
  4. Gordon Baxter
    WavyDavy Guest
    Which of what data?
    Do you expect me to trawl through all the replies you've had so far and pick
    out the best bits? Why not compile a load of questions from the replies you
    already have and ask if we think its a fair and representative set of
    wuestions ranging from easy/guessable to 'only for the committed'?
    PS. You might want to consider snipping sigs in future if you want to avoid
    Cab (or Pip, or............. quite a few others) "arguing like a girl"
    (except obv it's only Cab who "argue's like a girl"[sic]) at you.....
    WavyDavy, Sep 17, 2006
  5. Thanks for coming back Dave your help is very much appreciated. The data
    below is from the Ducati 999R Xerox. What I am after is what data to use
    for three questions which everyone interested in motorbikes would know,
    three questions that would need a reasonable knowledge and two questions, as
    you put it, are 'only for the committed'.
    Frame - Tubular steel trellis
    Wheelbase - 1420 mm / 55.9 in
    Rake - 23.5° - 24.5°
    Front suspension - Öhlins 43 mm upside-down fully adjustable fork with TiN
    surface treatment, for radial calipers
    Front wheel travel - 120 mm / 4.7 in
    Front brake - 2 x 320 mm semi-floating discs, 4-piston 4-pad radial caliper
    Front wheel - Y-shaped 5-spoke light alloy forged 3.50 x 17
    Front tyre - 120/70 ZR 17
    Rear suspension - Progressive linkage with fully adjustable Öhlins monoshock
    Rear wheel travel - 128 mm / 5 in
    Rear brake - 240 mm disc, 2-piston caliper
    Rear wheel - Y-shaped 5-spoke light alloy forged 5.50 x 17
    Rear tyre - 190/50 ZR 17
    Fuel tank capacity - 15.5 L / 4.1 US gal (includes 3 L / 0.8 US gal reserve)
    Weight - 181 kg / 399 lbs
    Seat height - 780 mm / 30.7 in
    Instruments Speedometer, rev counter, high beam indicator, turn signals, oil
    pressure warning light, low fuel warning light, neutral light, water
    temperature, immobilizer system
    Warranty 2 years unlimited mileage
    ENGINE
    Type L-twin cylinder, 4 valves per cylinder Testastretta Desmodromic; liquid
    cooled
    Displacement - 999 cc
    Bore x Stroke - 104 x 58.8 mm
    Compression Ratio - 12.5:1
    Power - 110 kw - 150 hp @ 9750 rpm
    Torque - 11.9 kgm (86.1 lb-ft) @ 8000 rpm
    Fuel injection - Marelli electronic fuel injection, 54 mm throttle body
    Exhaust - Single steel muffler with catalytic converter
    Emissions - Euro2
    TRANSMISSION
    Gearbox - 6 speed
    Ratios - 1st 37/15, 2nd 30/17, 3rd 28/20, 4th 26/22, 5th 24/23, 6th 23/24
    Primary drive Straight cut gears; - ratio 1.84
    Final drive Chain - Front sprocket 15; Rear sprocket 36
    Clutch - Dry multiplate with hydraulic control
  6. Gordon Baxter
    SteveH Guest
    Sounds like a fucking boring quiz for anoraks to me.
    SteveH, Sep 17, 2006
  7. Gordon Baxter
    Cab Guest
    <snip>
    Somehow, I don't think you're going to go far with this...
    Cab, Sep 17, 2006
  8. Committed anoraks, mind. Frankly, anybody who knows any particular bike
    to that level of detail outside the makers should be committed.
    Grimly Curmudgeon, Sep 17, 2006
  9. Oh, for ****'s sake. Are you really that stupid?
    The Older Gentleman, Sep 17, 2006
  10. Gordon Baxter
    Will-to-Live Meter
    0 1
    ________ o
    platypus, Sep 17, 2006
  11. Gordon Baxter
    deadmail Guest
    <snip list>
    Don't forget the 'circuit adjustable gearing' mechanism which allows two
    gear ratios to be ran for the same circuit so, for example, you can use
    a higher gear ratio on a long straight (to get a higher top speed) and a
    lower gear ration on a short straight (to accelerate to the top speed
    faster). It's kind of like a derailleur mechanism but a bit 'butcher'.
    deadmail, Sep 17, 2006
  12. Gordon Baxter
    WavyDavy Guest
    I think you're going waaaaaay too technical.
    Try sticking with questions such as:
    Easy: "Which rider has won the most WSB races in the history of the modern
    Championship?";
    Medium: "Prior to Troy Corser in 2005 who was the last person to win the WSB
    Championship on an in-line 4 cylinder motorcycle, and what make was the
    motorcycle?";
    Minor Anorak: "What does the word 'desmoquattro' refer to on Ducati's WSB
    machines?"; and
    Anorak with bar: "How many riders have won both a MotoGP/500cc championship
    race *and* a World Superbike race? Name them."
    That sort of stuff. Anything else would be, as stated by others, just a
    little bit boring.....
    WavyDavy, Sep 18, 2006
  13. Thanks Dave that's been a great help.
    Gordon Baxter, Sep 18, 2006
  14. Gordon Baxter
    WavyDavy Guest
    No worries..
    I'll assume you know all the answers..... :^)
