After market muffler for a SR500
Discussion in 'Australian Motorcycles' started by -k, Jul 20, 2003.
  1. -k
    -k Guest
    Is a SR500 always going to be a noisy mofo, as I've just got a second
    exhaust muffler for it but It's still just as loud.
    This new muffle is a inverted megaphone style with a screw in end, but is
    just as loud as the shot gun style muffler I had before (different note, but
    still as loud). The bike has an after market header pipe.
    Can I maybe repack it to lower the noise or do I aim for a longer/bigger
    muffler or just accept the fact that a SR500 is a noisy mofo?
    -k, Jul 20, 2003
  2. -k
    atec77 Guest
    try rapping the baffle in 10$ worth or chop type fiberglass mat . must
    be rough not the fine stuff
    worked very well with the yammy 500
    atec77, Jul 20, 2003
  3. In aus.motorcycles on Sun, 20 Jul 2003 21:23:16 +0800
    Doesn't have to be noisy, muffler design and packing makes a diffeence.
    Most off the shelf aftermarket stuff is noisy, it's what the punters
    want. My bbig alloy can on the XT Yam is loud but not irritatingly so,
    the note is very mellow, no bark. But there's bugger all muffling in
    there.
    The cans on the Guzzi are loud now because the packing's died, but were
    quiet when got.
    You can try taking it to a car place that does custom exhaust work, see
    what they say about packing it. If you are in Bris you can try Forans,
    bastard moved up there last year just before my muffler packing died...
    Zebee
    Zebee Johnstone, Jul 20, 2003
  4. -k
    sharkey Guest
    The rice-boy can I just put on the XLV was just a wee bit LOUD,
    so I drilled the rivets out and had a look, it's basically just
    a holey pipe the same diameter as the header up the middle of a
    stainless can, and fibreglass packing around the outside of
    the holey pipe. Pretty typical construction for a 'sports' muffler.
    I've repacked it with more fibreglass, which solved the ears-bleeding
    problem, and added another bit of holey steel blocking the end to
    prevent small furry animals climbing in there. But what made the
    big difference to the sound was adding a loose wad of small chicken
    wire down the length of the middle pipe, which removed the 'crack' of
    the exhaust note almost entirely.
    -----sharks (lo-fi)
    sharkey, Jul 20, 2003
  5. -k
    OldRider Guest
    Get some stainless steel wool from your supermarket. Comes in coarse grade
    (shiny round pads) and stuff that looks like ordinary steel wool - you'll
    need to soak the soap out of the latter (unless you want to smell like a
    killing line)..
    Pack muffer with whatever mix gives you the desired note. I've got the
    coarse stuff in my GS megaphone. Lasts forever and doesn't trap condensation
    as much as fibreglass on short runs.
    cheers
    DC - GS850G
    OldRider, Jul 21, 2003
