Aftermarket fuel gauge
Discussion in 'UK Motorcycles' started by @home, Jul 8, 2006.
  1. @home
    @home Guest
    Could anyone please tell me if it's possible to fit a fuel gauge to a 97 600
    Bandit.
    If so are there any 'How tos' or suppliers you could point me towards?
    Cheers
    Stu
    @home, Jul 8, 2006
  2. @home
    Accepted wisdom is to drill a hole in the bottom of your fuel tap. Gas
    weld on a short stub of tube (keep the filler closed and the tank
    completely full and it won't explode). Now run a piece of clear tube up
    the side of the tank and you will always be able to see the exact fuel
    level. Put a little red ball in the tube to improve visibility.
    Alternatively angle grind a slot right down the side of the tank, the
    cutting blades are just the right thickness. Araldite in a strip of
    clear polycarbonate, job's a goodun.
    As a last resort reset the trip mileometer each time you fill up, learn
    how far you get to reserve. Find out how far you then get on reserve
    (while carrying some spare in a proper can) like the fucking rest of us.
    Hog, Jul 8, 2006
  3. @home
    deadmail Guest
    I've never done this.
    I've also only ran out of fuel once. Well, once that I remember anyway.
    deadmail, Jul 8, 2006
  4. @home
    Never done what? checked the limit of reserve? I have sometimes.
    Hog, Jul 8, 2006
  5. @home
    deadmail Guest
    Checked the limit of reserve.
    I rely on the trip-meter.
  6. @home
    "run"
    Pip, Jul 8, 2006
  7. @home
    Cab Guest
    I used to rely on the trip meter with the Zephyr and the Divvy. The
    gauges where logarithmic in style, so couldn't be counted on properly.
    Cab, Jul 8, 2006
  8. @home
    I used to rely on the Quota's fuel warning light.
    Wired in Italy.
    I've gone back to using the trip meter.
    Pip Luscher, Jul 8, 2006
  9. No.
    The Older Gentleman, Jul 8, 2006
  10. @home
    anybody43 Guest
    "You might use the ancient method of drilling a hole in the fuel cap,
    putting a
    wire into a cork float and extending it through the hole so you can
    look and
    see how high the cork is floating.. be sure to bend over the wire so it
    cannot
    fall into the tank when it is empty"
    Says:- rec.aviation.homebuilt.
    If you didn't like that one then there will be plenty more
    where it came from.
    Mostly americans and they spell gage differently.
    look up capacitance, ultra sonic.
    anybody43, Jul 9, 2006
  11. @home
    I rely on Champ.
    sweller, Jul 9, 2006
  12. @home
    "Get used to disappointment"
    Pip, Jul 9, 2006
  13. @home
    It's worked so far.
  14. @home
    @home Guest
    Thanks for the replies, I am using the trip meter to find out how far I can
    go on a tank full, I just got used to using the fuel gauge on my Bandit 12,
    which I miss now I'm on a Bandit 6.
    I just want it all that's the problem.
    Cheers
    Stu
    @home, Jul 9, 2006
  15. @home
    Cab Guest
    Honestly? Just use the trip meter and save yourself the headache.
    Cab, Jul 9, 2006
  16. @home
    Alan Guest
    I don't know how accurate Suzuki's fuel gauges are but I've owned three
    Kawasaki's and a Triumph that had one and they were only usefull as a
    very vague indication that there was something between "some" and "none"
    in the tank. They all over read when more than half full and under read
    when less. Like everyone else I just set the trip when I fill up.
    Alan, Jul 9, 2006
  17. @home
    @home Guest
    | Alan ZX9R E2 (Green of course) '03 Tiger 955i (A pleasant shade of green)
    You are all very right, it will be much easier to stick with the trip meter.
    Thanks again
    Stu
    @home, Jul 9, 2006
  18. @home
    Buy another 12.
    In fact don't buy just any old Bandit 12, buy Adies one of her for a
    very low price.
    Andy Bonwick, Jul 9, 2006
  19. @home
    Adie Guest
    swap the b6 tank and clocks for a B12 one and that's what you'll have.
    Adie
    Triumph 955iSS (for sale) / ZX9R / GSF1200 bandit (for sale) / CG125
    keeper of the FAQ for my sins
    Adie, Jul 9, 2006
  20. The Trophy's is amazingly accurate - reads three-quarters and then
    half-full when three-quarters and half-full, etc.
    Runs onto reserve just as the needle dips into the red...
    My old Kawasaki GT750 )now stewarded by Statto) had (has) a joke of a
    gauge. Read full for 100 miles, and then dropped one LCD bar every 10
    miles, and when it got low flashed an annoying red light at you for
    ages.
    The Older Gentleman, Jul 9, 2006
