Ah bollix
Discussion in 'UK Motorcycles' started by M J Carley, Jul 2, 2008.
  1. M J Carley
    Catman Guest
    <visions of Blues Brothers>
    Should we start another thread, do you think?
    www.cuore-sportivo.co.uk
    Catman, Jul 4, 2008
  2. A simple timer to bring the lamp on then go off after 5 seconds, would
    do nicely.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Jul 4, 2008
  3. M J Carley
    I'm pretty sure this must be the case. The ABS warning light flashes on my
    BMW when you turn on the ignition. If the system is working the ABS lights
    will only go out once the diagnostic routine is completed. This only
    happens if *both* wheels rotate at over 5mph and the correct number of
    sensor pulses is read by the controller. As an MOT test bay can only rotate
    1 wheel at a time the MOT tester could not do this without a road test.
    As the ABS has not worked on my bike for 2 years I'm not complaining as I
    have always been given a pass.
    wessie, Jul 4, 2008
  4. M J Carley
    M J Carley Guest
    M J Carley, Jul 4, 2008
  5. Car ABS is testable, the warning light is part of the ABS system and if
    it's not working correctly it's a fail. You'll find big posters at most
    MOT stations detailing what the ABS light should show e.g. early Range
    Rovers only extinguish them after 5mph.
    Bike ABS is not testable.
    I'm a car MOT tester but I do know my way around the bike MOT manual.
    The OP should still complain to VOSA 'cos he's been stitched up.
    John Greystrong, Jul 5, 2008
  6. M J Carley
    deadmail Guest
    I questioned this on my K1100 three years ago, the MOT tester said
    "ABS isn't part of a bike MOT".
    Tester's a cock. Always thought this about Bishops of Bath anyway. Go
    to Barton Motors or D&H; they'll be better.
    deadmail, Jul 5, 2008
  7. M J Carley
    Cab Guest
    Somewhere in Norn Iron?
    Cab, Jul 5, 2008
  8. M J Carley
    Colin Irvine Guest
    <bookmarked> That's useful, thanks.
    Colin Irvine, Jul 5, 2008
  9. M J Carley
    M J Carley Guest
    It's the archive of information relating to yon Troubles.
    M J Carley, Jul 5, 2008
Similar Threads
Loading...
