air forks
Discussion in 'Australian Motorcycles' started by ysidro, Dec 31, 2005.
  1. ysidro
    ysidro Guest
    Greetings, have recently bought a Honda which takes a max
    of 6 PSI air in front forks. What's the best way of putting
    such a low pressure/small volume of air in them ?
    Ysidro.
  2. bicycle pump?
    fulliautomatix, Dec 31, 2005
  3. ysidro
    Bummers Guest
    Bummers, Dec 31, 2005
  4. ysidro
    ysidro Guest
    Tried that but the act of checking the pressure with my (probably
    innacurate) gauge lets all the air out :-(
    Y.
  5. ysidro
    justAL Guest
    I would think that you fill the compressed forks with oil then extend the
    forks and install the end caps.
    Once it's on the bike the weight of the bike on the suspension will compress
    the suspension and any air in there.
    It may give you the 6 psi you're after.
    justAL, Dec 31, 2005
  6. Mine came with a gauge and it doesn't let the air out.
    I think it is made for ATV tires.
    R. Pierce Butler, Jan 1, 2006
  7. ysidro
    alx Guest
    nup. get a bike pump and a good gauge..or one dedicated for air forks.
    alx, Jan 1, 2006
  8. 6 PSI is 167 " water gauge if you can be bothered to make a "Manometer"
    ian .at.bendigo, Jan 3, 2006
  9. It's about one and a half bicycle pumps on my bike.
    Pisshead Pete, Jan 3, 2006
  10. ysidro
    Kathy Leslie Guest
    You buy a Progressive Suspension air pump (0-100 PSI) specifically
    designed for motorcycle suspension (ie, it doesn't let the air out!!)
    See http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=2483504349
    Kathy
    Kathy Leslie, Jan 3, 2006
  11. ysidro
    imagineero Guest
    you can buy special pumps with gauges from $50~$100... but for my
    money a bicycle pump works pretty good. you dont need to know the exact
    pressure unless you also iron your socks and underwear. Start by
    completely emptying the forks (should be linked ones with only one
    valve right?). this gives you zero pressure. attach pump, put one
    pump of air in. go for a ride. not enough? empty air again, put two
    pumps in. go for a ride.
    remember you can always add some preload to the springs as well... use
    spacers
    also, you might find there is a valve for the rear shock inide the left
    side cover. look at the shock and there will be a bit of hose comin
    out of it. Air here works *much* better than air in forks which only
    stays there a while anyway and blows out your fork seals early. If you
    want better suspension up front forget the air and replace your springs
    with some from progressive or whoever.
    imagineero, Jan 3, 2006
  12. How do you stop the tranny fluid blowing back out?
    I find it best to adjust after a fork oil change. Put oil in and end caps on
    then give it 5 or 6 pumps or whatever 'til the front end stops rising
    noting how many pumps it takes. Empty air then add a pump, or how ever
    many, as necessary. Usually lasts until the next oil change or when you
    check the pressure again! Add a pump or two to extend service intervals if
    you feel it getting soft!
    Two bob bits.
    Agreed. Treat the air as a fine tunable adjustment not a compensator for
    fuckedness.
  13. ysidro
    imagineero Guest
    I find i dont have any trouble with the oil coming back out on
    forks.... on all the bikes ive seen the valve is usually contained in
    the fork cap, or its on a bridging piece that runs between the two
    forks. either way it doesnt dip down into the oil so nothing (or
    perhaps a very small trace) comes out of it when releasing air. Rear
    shocks with air (and lots have this! check *behind* the units on twin
    shock models, look for hoses going somewhere on monos) are a different
    beast... they tend to hose it every which way if they dont have the
    more modern style of internals with a membrane that separates the oil
    from the air. On the newer ones you're really better off getting it
    done in a suspension shop with whatever inert gas they use there at
    stupid high pressures that would soon embedd one of those fiddly little
    damn circlips well into my forehead...
    Shaun
    imagineero, Jan 4, 2006
  14. ysidro
    Theo Bekkers Guest
    Eh?
    Theo
    Theo Bekkers, Jan 4, 2006
  15. Viagra gives me a stiff neck?
    Pisshead Pete, Jan 4, 2006
  16. ysidro
    ysidro Guest
    I cant notice ANY difference with no air or 6 PSI air in the forks :-(
    Y.
    ysidro, Jan 6, 2006
  17. ysidro
    Bummers Guest
    It's supposed to give an additional, progressive bump stop.
    It won't help "foaming" - air is air!
    Bummers
    Bummers, Jan 6, 2006
  18. ysidro
    sharkey Guest
    Perhaps, I dunno.
    Provides a small amount of preload adjustment, and was kind of trendy
    for a while as a way of claiming adjustable preload with no extra cost.
    Also helps hold the fork seals shut, believe it or not. And thus
    keeps the rain out of your fork oil. Too much pressure can justk
    blow them right out, mind you.
    If you can get the preload right by shimming the springs, do that
    instead. Or replace them with progressive or other aftermarket ones.
    Lots of people have good things to say about RaceTech Gold Valves, too.
    -----sharks
    sharkey, Jan 6, 2006
  19. Y.
    I thought the only reason the air was in the forks was to place a small
    amount of pressure on the fork oil to stop foaming ,nothing to do with
    damping directly,or preload.
    I'm often wrong though, unless I'm mistaken.
    Capt A.L.
    Capt.about lunchtime, Jan 7, 2006
  20. ysidro
    Tads Guest
    If the forks rise when your adding air, be careful as you are increasing the
    steering rake which will make the bike turn slower through corners with the
    bike wanting to go wide (extreme cases).
    My 1994 FLHS Hardly Dangerous has the air valve in the end of the handle bar
    so it effectively had a air reservoir which helped. The twin rear upside
    down shocks (Showa) also took air and for a tourer weighing in at around 340
    kilograms, the air was a bonus when loaded up touring Aus.
    For a sports tourer I would focus on trying different weight oil starting at
    between 5 weight up to a max of 15 w (depending on how heavy the bike is).As
    someone said in a earlier post, don't rule out spacers placed on top of the
    springs of around 10-25 mm each that are a firm fit.If you can, you may need
    to slip the forks through the yokes a bit (5 to 20mm )to compensate for the
    increased rake you'll get by fitting spacers. Of corse if bucks aren't a
    issue by some quality stiffer Ohlin replacement springs which will transform
    the bikes handling no end !
    A basic rule of thumb is, the less rake (steeper) the sharper the turning
    will be but the bike will be less stable at high speed. The longer the rake
    the better the bike will handle at high speed but as said, will handle like
    a wet sponge through corners.You don't have to be a speed demon to
    appreciate a well handling bike especially after a long ride.
    When I raced my GSX-R-600 in the then SuperSport class at Wanneroo around
    97, the Ohlins front replacement springs and rear fully adjustable Ohlins
    shock helped shave off around 3 seconds a lap and encouraged confidence in
    the bike as the feedback through the front end was positive.
    Good luck and Iron side up
    Tads
    Tads, Jan 8, 2006
