Alarms
Discussion in 'UK Motorcycles' started by AW, Oct 30, 2007.
  1. AW
    AW Guest
    Wierd. Stopped for fuel at the petrol station opposite the TV aerial
    transmitter mast in Crystal Palace this morning and then I couldn't
    get the alarm to respond. Fecking thing automatically arms itself 45
    seconds after the ignition has been switched off so you can't not
    reset it. This happened a while back at the same place but I put it
    down to a dodgy battery in the alarm fob and that time I eventually
    managed to get it to disarm. This time though I just couldn't get it
    to reset so eventually had to ring up the other half and get her to
    look up the manual disarm instructions.
    Got to work and it all arms and disarms itself happy as anything.
    Gah.
    Could it have been the radiation from the TV Tower somehow interfering
    or swamping the alarm? I found this statement on Wiki regarding the
    CP transmitter.
    "It is possible to also get a bad picture if the signal strength of
    the TV transmitter is too high, for instance in the Bromley area of
    south east London the signal from the TV mast is so strong that it may
    cause the TV's front end to be overloaded. Check for this by inserting
    an attenuator inside with the TV aerial connection. If you start by
    trying with 10 dB, and then move to 20 dB then this might provide a
    cure.
    In that part of London the TV transmitter (Crystal Palace Transmitter)
    and the Croydon Transmitter tower which has VHF pager transmitters are
    both such strong sources of radiowaves that FM only UHF (432 MHz) and
    VHF (144 MHz) radiosets can become overwhelmed when they are attached
    to a beam aerial which is pointed at the Crystal Palace and Croydon
    towers respectively. The receiver of the FT-290R2 which is a 144 MHz
    multimode (FM/CW/SSB) radio is more able to cope with such strong out
    of band signals".
    AW, Oct 30, 2007
  2. ISTR some documented car ignition failures near some transmitting
    station close to the M1....
    The Older Gentleman, Oct 30, 2007
  3. AW
    50g2000hsm.googlegroups.com:
    I was on a training course at Crystal Palace. We were accommodated in the
    hideous tower block close to the transmitter. TV reception was crap on the
    14" portable in my room.
    I've heard anecdotal evidence to suggest that noise from various sources
    can interfere with car/bike alarm remote controls.
    wessie, Oct 30, 2007
  4. AW
    Kiran Guest
    Fairly well known for bike alarms to be affected by TV transmitters, mobile
    phone masts.
    Happened to Judge on a trip to Italy once. Unfortunately, he managed to get
    the bike going again.
    Kiran, Oct 30, 2007
  5. AW
    AW Guest
    Just a bit odd as I stop at that petrol station fairly regularly and
    it's only happened the once before.
    AW, Oct 30, 2007
  6. AW
    AW Guest
    Reception is fairly rubbish close to the Upper Norwood transmitter as
    well, particularly on C5. No loss though.
    AW, Oct 30, 2007
  7. AW
    The Older Gentleman was seen penning the following ode to ... whatever:
    Remember the car alarm in my Nissan Skyline that wouldn't disarm
    outside your gaff? This is far from unusual.
    Timo Geusch, Oct 30, 2007
  8. AW
    AW Guest
    Makes you wonder what it's all doing to your head, doesn't it!
    AW, Oct 30, 2007
  9. AW
    AW says...
    Same thing happened to me the one and only time I borrowed Pip's RF900,
    at Ally Pally. It didn't help that snow was falling as I was furiously
    trying to get the bike started.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Yamaha SR250 SpazzTrakka
    Lozzo, Oct 30, 2007
  10. AW
    AW Guest
    I hate alarms anyway. It was fitted when I bought the bike as I
    certainly wouldn't bother spending my own cash on one. The efficacy
    of alarms was amply demonstrated as I pushed the bike out of the
    petrol station to take it round the corner to see if I could get it to
    disarm away from the transmitter and then freewheeled down the hill
    to Dulwich College, all with the alarm blaring and the indicators
    flashing and no-one paying a blind bit of attention.
    AW, Oct 30, 2007
  11. AW
    deadmail Guest
    Not really. Then again I've an understanding of how a radio works.
    deadmail, Oct 30, 2007
  12. AW
    AW Guest
    Irony isn't your thing, is it?
    AW, Oct 30, 2007
  13. AW
    deadmail Guest
    Depends. What do you think irony means?
  14. AW
    AW Guest
    Oh ferfuxsakes. Is this take everything literally night? Note the
    exclamation mark. It was not a serious comment but a quip. Jeez.
    AW, Oct 30, 2007
  15. AW
    AW Guest
    Do you know what humour means?
    AW, Oct 30, 2007
  16. AW
    SteveH Guest
    SteveH, Oct 30, 2007
  17. AW
    ts Guest
    Quote from <http://www.thumperpage.com/articles/Elefant.html>:
    " . . At a petrol stop Jethro found that he couldn't disable his alarm,
    meaning his bike wouldn't start. . . . After we returned to Wales the
    incident was mentioned to the Datatool alarm distributor who immediately
    asked "was it a German petrol station?". It turns out that German petrol
    stations have some feature that disables Datatool alarms, if Jethro had
    pushed his bike 200 yards it would have started. "
    For what it might be worth.
    ts, Oct 30, 2007
  18. AW
    AW Guest
    Sigh. Yes, whatever.
    Hardly.
    AW, Oct 30, 2007
  19. AW
    At 2450 Mhz, it'll heat up your frozen pizza.
    platypus, Oct 30, 2007
  20. AW
    Geo Guest
    Not mine it wont. I always use a proper over otherwise the pizza turns soggy
    and generally shit.
    Geo
    Geo, Oct 31, 2007
