Alarms
Discussion in 'UK Motorcycles' started by AW, Oct 30, 2007.
  1. AW
    Which is different from the usual frozen pizza how?
    platypus, Oct 31, 2007
  2. AW
    deadmail Guest
    Different things to different people. Clearly.
    deadmail, Oct 31, 2007
  3. AW
    The ones mother gives don't work.
    sweller, Oct 31, 2007
  4. I put that down to it just being a Timo Car. Until it happened to my
    Nissan as well.
    The Older Gentleman, Oct 31, 2007
  5. AW
    AW Guest
    Tetchy.
    AW, Oct 31, 2007
  6. AW
    Colin Irvine Guest
    Not soggy - if you use a pizza stone, that is.
    Colin Irvine, Oct 31, 2007
  7. AW
    Radio waves have some effect on organic matter shirly. Just very little at
    normal energy levels. You wouldn't want to stand beside a Mw class
    transmitter though!
    Hog, Oct 31, 2007
  8. AW
    Switters Guest
    Are you saying that your microwave fails to heat pizzas?
    Switters, Oct 31, 2007
  9. AW
    Beav Guest
    Apparently this is a major problem with the newer Harley's and it seems to
    be the telephonic juice spreading itself into the alarm wiring and key fob.
    Either way, the cure is to roll/push the bike further away from said mast
    and give it another try.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Oct 31, 2007
  10. AW
    Geo Guest
    Well, a frozen pizza baked/reheated in a proper oven is much more edible
    than a microwave treated one. It's all relevant, particularly when you're a
    student and have to watch your budget. I must have had at least a couple of
    thousand frozen pizzas as a student; cheap, quick, easy and no need to wash
    up more than a knife afterwards. The fact that my cholesterol's high despite
    my low weight is a completely different issue.
    Geo
    Geo, Oct 31, 2007
  11. AW
    Geo Guest
    I always used the cardboard box it came in. Absorbs moisture well enough to
    leave a crispy base and it just about withstands 15-20 minutes in the oven
    so it starts to smell of burnt inks in order to alert you if you forget
    yourself.
    Geo
    Geo, Oct 31, 2007
  12. AW
    Geo Guest
    Damn typos...I meant *proper oven*
    I presume it could if I actually *did* put a pizza in it and turned the
    knobs, but yes, in a way my microwave does not heat pizzas :)
    Geo
    Geo, Oct 31, 2007
  13. AW
    deadmail Guest
    Not at all, just a statement that you're not very funny.
  14. AW
    Rich B Guest
    Sucking his keyboard for inspiration, AW typed:
    Lots of well documented cases when LR brought out the P38 Rangie, of brand
    new cars failing to unlock/disarm/start when parked at airports. Also
    numerous cases to my knowledge of RRs draining the battery overnight when
    parked near to an RF source - the BECM which should go to sleep after 5
    minutes or so is constantly woken up and goes through its thing over and
    over. Apparently, Oregon Scientific weather stations can do this too - the
    first thing to eliminate if there is a persistent flat battery problem. So
    I am not at all surprised that radiation from a powerful TV mast can do
    this.
    Rich B, Oct 31, 2007
  15. AW
    AW Guest
    Definitely tetchy.
    GAF.
    AW, Oct 31, 2007
  16. The early warning radar 10 miles south of Cromer went through a phase of
    shutting down car ECUs. The local garage would come out tow the cars
    away then reset the ECU and off they would go.
    It was reported in the press etc if you google for it.
    Mick Whittingham, Nov 2, 2007
  17. AW
    Mick Whittingham says...
    My ex lives just down the road at Mundesley, she said she'd never known
    anyone local that had this happen.
    Lozzo
    Triumph Daytona 955i SE
    Suzuki SV650 K3
    Honda CBR600 F-W
    Suzuki GSX-R750L
    Yamaha SR250 SpazzTrakka
    Lozzo, Nov 2, 2007
  18. It's never happened to me either.
    Good fish and chip shop in Mundesley (or is it Trimingham).
    I often dive off a RIB from the slip way behind the Ingleside Hotel.
    http://www.theregister.co.uk/2006/11/03/radar_mystery_solved/
  19. Including static magnetic fields, apparently, which would have had
    an inhibiting effect on people trying to do MRI... Or was that another
    pile of unguided directives?
    Dr Ivan D. Reid, Nov 6, 2007
