All of a sudden lots more Ooomph!
Discussion in 'Motorcycle Technical Discussion' started by Dallas, Feb 17, 2004.
  1. Dallas
    Dallas Guest
  2. Dallas
    Mark Olson Guest
    Part of it is forgetting how fast the bike is compared to the car,
    and part is the higher density of the cooler air. That's why the
    first few blasts in early spring are so fun when you take the bike
    out of winter storage.
    Mark Olson, Feb 18, 2004
  3. Not quite.More power requires more fuel, too. A carburetted engine
    has no way of measuring O2 qty, it measures air volume, so
    will run rich at high ambient temp and lean at low ambient temp,
    just as it will run rich at high altitude and lean at low
    altitude for the same jetting.
    Fuel injected engines with either an air mass sensor on
    intake (a heated wire, essentially) or an O2 sensor on the
    exhaust side, make your statement essentially correct.
    Michael Sierchio, Feb 19, 2004
  4. Dallas
    pragmatist Guest
    I don't know if the Kaw has a pressure sensor or not but I can tell
    you that density altitude does make a 'seat of the pants` difference.
    I used to ride from home on the east coast, (400' above MSL), to play
    in he rockies in the summers, and even with dropping the jet needles a
    notch to keep the carbs close to tune, there was a noticable decrease
    in passing power, even on the Interstates short of Denver,(5000' above
    MSL), let alone in the mountains proper.
    If that Kaw was last tuned for winter weather, the temperature effect
    would be even more noticable.
    Dallas, you might check your state of tune as the weather warms up
    again this spring. Don't lean her out too much, but you might be
    pleasantly surpprised if you keep her spot on.
    Best of Luck, Pragmatist - "R75/5 Forever!"
    "Due to budget cuts, the light at the end of the tunnel has been
    turned off."
    pragmatist, Feb 20, 2004
  5. Dallas
    Pete Guest
    Could be an interesting side issue here. A pilot told me once that three
    enemies of lift are height, heat and humidity. All 3 lower air density.
    A carburetor is supposed to respond to flow, not density, so these 3 things
    should also affect the performance of a carb.
    When you get up into the mountains, it burns rich because of the reduced air
    density ie they respond to flow. (AFAIK fuel injection has mass flow sensors
    which fix this)
    Vehicles seem to run better when it's humid (like in the rain). Water is
    supposed to be a good anti-detonant. At one time something that happened
    was to put water injection on your motor when you popped it up. An
    explanation I heard was its because the water takes on a bunch of latent
    heat when it vapourizes in the combustion chamber, reducing pre-ignition.
    Fair enough. But if it already exists as vapour in the air, this doesn't
    apply. Its pressence just reduces the density of the air. And I would think
    the %O2 to some extent.
    What's my point? Uh....I'm not sure. Thought I had one when I started
    this...
    D.
    Pete, Feb 20, 2004
  6. Dallas
    LJ Guest
    My worthless unscientific addition is that my old 1981 Honda 750C ran
    noticably better in humid conditions. Never knew why, I just enjoyed.
    LJ, Feb 21, 2004
  7. give extra power over short periods
    was injected into the manifolds to increase pressure
    steve robinson, Feb 21, 2004
  8. Dallas
    pragmatist Guest
    OK, (I used to fly a Cessna back when pterodactyls still tried to
    horn into the landing pattern and it was affordable so I'll try to
    respond.)
    Yes they do. Altitude and humidity both 'lean out` your mixture.
    Humidity has less effect however as 'best power` is achieved with a
    mixture slightly richer than stoichiometric because the vaporization
    of the extra fuel, (or water vapor in some cases), helps turn more
    heat into pressure in the cylindars instead of loosing it out the
    pipes. This was the idea behind water injected engines and the reason
    engines seem happier in the rain. The engine runs cooler and fuel
    efficiency rises.
    Right, thats why I 'drop the jet needles a notch`, (lean the mixture a
    bit), going from low altitude to high on my bike. (Its easy on the
    airhead beemer with the carbs right out there where you can get at em.
    Suffer you rice burner jockeys!)
    Right again as far as the O2 content, but the water vapor expands
    better than air when heated and so still offers some benefit provided
    the mixture is correct.
    I didn't really have one either, just like to shoot off my big mouth.
    See ya on the road,
    - Pragmatist - R75/5 Forever!
    pragmatist, Feb 22, 2004
  9. Dallas
    pragmatist Guest
    Just in case anyone might care...
    Water injection was also used for fuel economy for old commercial flights.
    Some Methanol/water systems achieved fuel efficiencies of .36lb./HP/Hr. at cruise.
    Pragmatist.
  10. Dallas
    Trey Guest
    Trey, Feb 23, 2004
  11. Dallas
    James Clark Guest
    My truck doesn't have too much trouble running 15psi boost on kerosene.
    James Clark, Feb 23, 2004
  12. Dallas
    Manjo Guest
    Dallas,
    I've played with my dual-carbed Vulcan 1500 engine for the last few years.
    Your bike is probably on the edge of running rich. Not too rich, just rich.
    The colder temperature around the engine and the denser air leans the
    air:fuel mix (increased air density) just enough to change the performance.
    In your case, increased performance.
    My limited and anecdotal experience implies that most MODIFIED/rejetted
    carbed bikes run too rich. Too many dealer wrenches will unnecessarily
    increase jetting when they install third party exhaust pipes.
    I'm also of the opinion that extreme weather changes (heat and/or humidity)
    can push the air-fuel mix to either side of the optimal ~14:1/air:fuel mix
    effecting performance which is "set" by the fixed jetting versus the air
    density that can vary literally from moment to moment. This variability
    created the market for computer controlled fuel injection that constantly
    measures several environment factors, and adjusts fuel volume as required
    for optimal engine performance.
    I've read that racing mechanics will rejet and change needles in a carbed
    engine for the race day's weather.
    JM2C. Ride safe.
    Manjo 1500A9
    Manjo, Feb 23, 2004
  13. Dallas
    Trey Guest
    If your car's engine is running at 10.5:1 (static) compression, you cant add
    that much boost. If your engine is running at 8.5:1 (static) compression,
    you can add more boost.
    If ATM is 14.6 PSI, then at 10.5:1 that's 154.3 psi at TDC. add 6 pounds of
    boost and we are now at 216.3 PSI in there. (this is assuming there is no
    vacuum for the first measurement which we know is not true, )
    Or, at 8.5:1. that's 124.1 PSI N/A, and 217.6 PSI with 11 pounds of boost.
    A friend of mine runs 12PSI boost with 10.5:1 compression. With 91 octane,
    he has to keep it under 5,000 RPM. with 104 octane, he can take it to the
    redline. With the amount of time that car spends in the shop. I really don't
    think its a good idea to try it.
    when you look at the specs for super charged or turbo cars, you will notice
    the compression ratios are always lower then the N/A cars in the same line.
    Trey, Feb 23, 2004
  14. Dallas
    Trey Guest
    Correction, I just remembered when I had the vacuum gauge connected to my
    truck. At idle, it was pulling 25" of vacuum, at WOT, it was at zero. So at
    WOT, these measurements are accurate.
    Trey, Feb 23, 2004
  15. Dallas
    James Clark Guest
    I'm only running 21:1, and preignition isn't a problem.
    (You can't burn what isn't there.)
  16. Dallas
    pragmatist Guest
    A little bit of both. Remember we're talking about big old radial
    aviation engines at low R.P.M. here. The methanol not only prevented
    the system from freezing at high altitudes, but drew off more heat in
    turning from droplets to vapor than water. The fact that the stuff
    could contribute to the burn was helpful, but incidental.
    The principle was to prevent knock, (autoignition of the charge), at
    the high 'boost` that allowed greater B.M.E.P. and therefor higher
    efficiencies from the same fuel input. In those slow turning engines,
    the strokes took more time than we're used to thinking of in bike
    engines, and those big air cooled cylinders were running closer to
    their strength limits than we normally encounter in road engines.
    Prevention of knock was critical.
    As to running water injection on the road today, a system that does
    all the required metering and math, plus the water tankage would
    probably not be practical on bikes. For cars the idea looks promising
    at first glance:
    a. lower peak cylinder temp.s hence greater thermal efficieny less
    wear, less NOx production.
    b. less total fuel consumption hence lower total carbon output.
    c. economically, the system would probably be less expensive than the
    anti pollution stuff currently required.
    With current engine management technology it's definately doable, but
    then how would they continue to sell us all the expensive, power
    robbing, emissions plumbing they spent all that R&D dough on??
    **I am not anti clean air regulation, I just believe that it should be
    done by efficiency, not waste.** - 'Less fuel burned = less
    pollution.'
    But that kind of regulation would make it tougher to sell those
    bloody damned S.U.V.s of which we are all so fond.
    ( Oooops, - Sorry for the rant. )
    Pragmatist
    "Eternal vigilance is the price, both of freedom,
    and a crabgrass free lawn. - The lawn is easier."
    pragmatist, Feb 24, 2004
  17. *snip*
    Agreed. Whole heartedly.
    J. Firespear
    Ranger J. Firespear, Feb 24, 2004
  18. Dallas
    Pete Guest
    The way I understand it, super or turbocharging effectively increases the
    compression ratio, which would tax the octane rating of the fuel. It was a
    few years back when I had an active interest in this topic, like...mid 70's.
    I was keen to turbo my BMW 2002 at one point. There was an European version
    which was turboed, I can't recall the exact figures, but the turboed
    compression ratio was something like 8.5:1 instead of 9.5 or 10.5:1
    depending on the model.
    At that time, the water injection thing was a cheap easy solution to the
    ping problem. I seem to remember that one theory was to use a windshield
    washer pump an a DP sensor to turn it on when the manifold pressure went +.
    Another cheap and dirty solution was simply to vent the manifold pressure
    into the water tank. When the manifold went +, it squirted water into the
    intake.
    Apparently they weren't that particular about how much water they got, as
    long as they got enough. It was a matter of increasing the orifice or
    whatever 'till the motor was happy and stopped pinging.
    I'm not quite up on the current technologies, but as someone mentioned in
    another post, I would think that what he called modern "engine management"
    would make a difference today WRT the preignition, boost, and allow turboed
    motors to run on crap gas.I know my truck has a knock sensor in it. It
    doesn't seem to care what I put in there,could be aftershave for all it
    knows, all you ever hear is the odd "tick". I guess it mucks with the
    ignition timing and mixture to stop it or something.
    But I figure there's no free lunch, as they say. So when I load up the truck
    and head off east, committed to traveling a thing here in BC called the
    "Coquihalla", infamous to truckers for its long steep grades, I put good gas
    in it. I think it pays off, because the "Engine management" sensor/computer
    technostuff knows I'm being usually kind to it and the appropriate
    adjustments are made, and I believe it actually uses less significantly less
    fuel, maybe even enough to pay for a pint at the next waterhole.
    I have some other theories about manufacturers claims about vehicles taking
    "regular gas". Everything now adays is supossed to happy on "regular gas"
    When you look at the motor specs, your intuition tells you that better gas
    should be put in these things. But they seem to work OK on it, so that's
    what they get.
    Cheers
    D.
    Pete, Feb 24, 2004
  19. Dallas
    Trey Guest
    What are you running 21.1 in? do tell. Since most Diesel's run in that range
    The most you can run in a Gas engine on pump gas is 14:1 I believe (you CAN,
    but shouldn't)
    So what "Isn't there"? fuel?
    Trey, Feb 24, 2004
  20. Dallas
    James Clark Guest
    6.9 out of a Ford. Most current diesels run < 18:1 with open chambers.
    Keep the fuel out of the chamber until you really need it.
    James Clark, Feb 24, 2004
