Allied Forces?
Discussion in 'UK Motorcycles' started by BryanUT, Dec 4, 2006.
  1. BryanUT
    Beav Guest
    But Nelson Mandela and Victoria Beckham don't *really* count.
    who
    Actually, it was Sir CHARLIE Drake.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  2. BryanUT
    Beav Guest
    Especially during daylight hours.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  3. BryanUT
    Beav Guest
    And they'll probably say the same thing today as they did in the 40's. "You
    Brits are fghting a war, we Poles are fighting the Germans". It was
    apparently very "personal" for them. Well according to an old Pole I used to
    know.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  4. BryanUT
    Beav Guest
    Is it normal to have "R's" in khazi?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  5. BryanUT
    Beav Guest
    Oh yes indeed. A solid base is essential, but a well made steel "trolley"
    with little (if any) flex didn't appear to cause any problems. I suppose if
    he'd been making parts for a Volvo Space Shuttle, it may have, but he
    wasn't, so it didn't.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  6. BryanUT
    Beav Guest
    I wonder if this system actually originated with Marks and Spencer? All
    their suppliers (of most things, if not all) had to run their companies in
    accordance with M&S "rules", one being that nothing was allowed to be bolted
    down or stored directly on the floor. I suspect that this came mainly from
    the food side of things as being able to move EVERYTHNG allowed for a high
    degree of hygiene.
    Just a thought, mind.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Dec 10, 2006
  7. BryanUT
    Scraggy Guest
    ITMA
    Scraggy, Dec 10, 2006
  8. BryanUT
    Scraggy Guest
    It is if you don't want to shit down your leg.
  9. BryanUT
    DR Guest
    I used to work in a factory making tin boxes, many of which were
    destined for M & S. ISTR that apart from the fact that the machinery
    involved weighed several tons, there were H & S rules that presses and
    such *must* be bolted down. I suppose that was a different situation,
    though, not making the actual food itself but the containers for it.
    DR, Dec 10, 2006
  10. Petticoat Line.
    Ali
    Alison Hopkins, Dec 10, 2006
  11. BryanUT
    You're 100% correct on this one Darren.
    The front end presses will have been bolted down as will the inkers,
    neckers, decorators etc right through to the baling machines.
    I've been in plenty of food production areas supplying M&S amongst
    others where a lot of the equipment is bolted down but the important
    fact is that anywhere that contamination can take place the equipment
    can be easily and quickly removed for cleaning.
    Andy Bonwick, Dec 10, 2006
  12. *Ding*
    Or for reorganising the factory floor so it can make other products.
    The Older Gentleman, Dec 10, 2006
  13. Yes, but this is irrelevant here. It's also irrelevant, if we return to
    the point of whether the original Barbarossa could have worked (and I
    maintain it could, and it *so* nearly did), because the T34 wasn't
    available in any numbers for another year or so.
    OK, two instances in small-scale engagements. Shit happens. Otherwise,
    I'm sorry, but whatever you think, the Wehrmacht kicked the shit out of
    everyone, except when they faced overwhelming odds in men and materiel.
    (Oh, and the Waffen SS was even more effective)
    Well, yes, this is my point. The Wehrmacht won.
  14. BryanUT
    Kim Bolton Guest
    Them were the days.
    My mum cooked à la Marguerite Patton during the war, it's why I'm
    built of sturdy stuff.
    That and National Milk, Cod Liver Oil, and Orange Juice you could
    stand a spoon up in.
    Kim Bolton, Dec 10, 2006
  15. BryanUT
    Kim Bolton Guest
    Apparently SOE got an altitude-triggered bomb onto Hitler's aircraft,
    ready for one of his trips.
    As the plane climbed, it received a radio warning of bad weather.
    Consequently, the plane never reached the 10,000 foot altitude at
    which the bomb would have triggered.
    SOE had to mount another operation to get the bomb off the aircraft
    before it was discovered.
  16. FFS, do some research.
    I think you're confusing this with the documented atempt when a bomb,
    disguised as bottles of brandy, was smuggled onto his Condor. It failed
    to detonate, and (at great personal risk), the perpetrators recovered
    the bomb.
    SOE, AFAIK, never had anything to do with it, and certainly did not
    attempt anything with an altimeter fuse. I mean, airliners were
    unpressurised then and mostly flew well below 10,000 feet anyway.
  17. Yes, I'd agree here.
    I think this is fair. Had the Germans not behaved so abominably in the
    East, had they enlisted more local support (and Christ knows they got
    enough anyway), and had they let the captured area have some degree of
    self-determination, then it might have gone very differently.
    Oh, and if they'd started in May, as planned, before they got diverted
    into the Balkans.
    But they gambled everything on a lightning strike to behead the moneter
    before it really woke up. And they so *very* nearly succeeded. Stalin
    even tried to make peace and give up the Ukraine.
    OK, I concede there have to be occasions when they were beaten by
    inferior forces. Very, very few, though. And you can only provide two
    examples. Now see below.
    OK, you asked.
    France, Belgium, Netherlands, 1940. France and Britain had more guns,
    more men, more tanks and (yes) more aircraft. And they lost.
    Crete, 1941. Britain was sitting in total control of an island, and the
    Wehrmacht attacked it entirely from the air, and were incapable of
    dropping anything more than light artillery. The Wehrmacht won (at a
    cost).
    Russia, 1941. Russia had more men, weapons, guns and aircraft. They got
    their arses kicked.
    Middle East, 1941-42: Rommel had fewer men, fewer resources, less
    materiel, and he whipped the 8th Army. He lost in the end, because we
    built up our materiel and denied him his supplies. No other reason.
    Kharkov, 1943, the recapture of. An utterly astonishing piece of
    generalship.
    France, 1944: Michael Wittmann, tank ace, utterly *hammered* a British
    armoured column. Yes, a small-scale engagement, but worth mentioning.
    I could go on....
    True. The Germans' were better than anyone else's..
    They lost, yes, because Russia, Britain and the US had more men, guns,
    ships and aeroplanes. And more oil. And more money. And the blame for
    losing the war lies more with Hitler than the Wehrmacht. The Wehrmacht
    was the finest land fighting force on the planet at the time. Sorry, but
    it *was*.
  18. BryanUT
    Kim Bolton Guest
    Well, you wouldn't know this, but in the mid-sixties I destroyed
    thousands of SOE's altitude-switched bombs. They were designed to use
    PE as the explosive, which was filled into the unfolded
    bicycle-tube-like attachment.
    You might have researched that these were set to go off at 10,000
    feet; and frankly your description appears of one of these hidden in a
    bottle.
    Stauffenburg's bomb also used SOE explosive.
    AFAICS you need to do some research.
  19. Fine. And this was 1943. The bomb was dismantled afterwards by the
    perps. It used an acid timer. The acid timer did its stuff, the striker
    pin hit the detonator, and the det failed.
    See above.
    Might well have done. Didn't use an altitude detonator, though, did it?
    Nope. See above, and check for yourself.
    The Older Gentleman, Dec 11, 2006
  20. They didn't. They just used it better. And look elsewhere than Wiki.
    Wrong again. The French 75mm was still an outstanding gun. The French
    air force was at least as powerful as the German, but they just parked
    most of it out of the way.
    This is irrelevant to the central point - the Wehrmacht won, despite not
    enjoying an advantage in men and materiel. What they had might have been
    *better* and was certainly used better (cf: concentration of armour).
    Which proves my point.
    But the Wehrmacht still won.
    Actually, Russian strategy at the beginning was to *advance*. Which they
    did. And lost millions of men in encirclements. Seriously, you really
    need to read more.
    He had no option. He was ordered to. And there was no evacuation
    possible.
    The Wehrmacht had many superb generals and field marshals: more than the
    Allies. Manstein, von Rundstedt, Halder, von Manteuffel, Model,
    Guderian. You have to think really hard to come up with a list as good
    as that from the Allies. Patton, Zhukov, Montgomery, maybe Chuikov,
    Eisenhower. And that's from three nations, not one.
    Yes ;-)
    They lost, yes. But unit for unit, they were still the best. They didn't
    have enough units.
