Ally Pally
Discussion in 'UK Motorcycles' started by Andy Bonwick, Jan 27, 2007.
  1. Andy Bonwick
    The best way to describe it was as being very quiet.
    Loz was there trying to persuade people that they needed to lash out
    big bucks on leathers and I caught up with John and Matt from Online
    Racing for the first time in ages so it wasn't a wasted day.
    There were plenty of stands flogging cheap crap, plenty selling decent
    stuff, quite a few very nice bikes and lots of things that I felt I
    needed to buy.
    Significant purchases were as follows:
    Brembo adjustable ratio radial master cylinder
    Set of braided brake lines
    Pair of Rev'it winter gloves
    EDZ undersuit
    FOAD big 'c' spanner for adjusting the pre-load on rear shocks
    Adie spent money as well but she can post details herself if she feels
    the need.
  2. Andy Bonwick
    <green>
    Hog, Jan 27, 2007
  3. Andy Bonwick
    Andy Bonwick says...
    Oooh fucking lovely, wish I could afford one. I'm going to get an 04
    onwards R1 Brembo one for the Daytona, as the OE Nissin one is a known
    weak point and will always leave the brakes spongy. The R1 job is 125
    quid complete but unadjustable for ratio, only span.
    Lozzo, Jan 27, 2007
  4. Andy Bonwick
    Don't be. It wasn't expensive but it looks really trick which is what
    counts.
  5. Andy Bonwick
    Use your influence. Let the force overpower common sense.
    I'm well chuffed before I've even fitted it. The thing I really want
    to try out is the undersuit because everyone I've spoken to about them
    reckons they're brilliant under full leathers. I feel the cold really
    badly so it should make a world of difference.
  6. Andy Bonwick
    Like how much not expensive!
    Hog, Jan 27, 2007
  7. Andy Bonwick
    Where did it come from, Harris?
    Whenever we were selling a one-piece suit at Gericke we'd send the
    customer into the changing room with an EDZ undersuit to try when they
    tried on the second set of leathers. They always bought one as well. If
    they liked the first set of leathers they tried, we just got them to try
    the undersuit as well when they went to get changed back into normal
    clothes, that usually resulted in an add-on sale too.
    My add-ons figures were astounding.
    Lozzo, Jan 27, 2007
  8. Andy Bonwick
    About £160 but then you have to add on the cost of the 'add ons' like
    brake light switch. I wanted one because the brakes on the bike faded
    like **** on a trackday and sorting them out is worth the effort as
    far as I'm concerned.
  9. Andy Bonwick
    Ah now thats ok compared to the AP radial adjustable from Harris. Who
    did you get it from?
    Hog, Jan 27, 2007
  10. Andy Bonwick
    Christofire Guest
    Do let me know what you do and if it works. After the steering damper
    the brakes are next for me. I'd like a bit more power and something to
    combat the fade - it's not been a problem on the road, but it was at
    Mallory.
    Christofire, Jan 28, 2007
  11. Andy Bonwick
    Molly Guest
    Not much better today. Only bought a hugger for my 10R and a Cornish Pasty.
    Molly, Jan 28, 2007
  12. Andy Bonwick
    I'll wait until it's all sorted and let you know what it's like.
    You might be able to persuade me to let you have a rip on the bike
    when you do the TT marshall bit if I drink loads of beer the night
    before the course. It's worth noting that I'm off to see the man who
    can later this month to have the fuelling fucked about with and the
    predicted results should be 'interesting'.
    Andy Bonwick, Feb 2, 2007
  13. Andy Bonwick
    Christofire Guest
    After today's ride I'm more interested in getting the thing stopped
    better. The brake fade has become a road problem too. I suppose I
    should start with new pads / less pies and work from there.
    Christofire, Feb 4, 2007
  14. Andy Bonwick
    snip>
    I fitted a Brembo radial master cylinder and braided hoses yesterday
    and the front brake feels better but only a bit of serious abuse will
    tell if it really is better.
    If you go down this route then make sure you buy a reservoir as well
    as the cylinder because the pipe's a different size on the Brembo. I
    managed to sort it by forcing smaller bore pipe over the Kawasaki
    reservoir but I'd have paid the extra £15 if I'd known it was needed.
    You also need a different banjo bolt that incorporates a brake light
    and the whole lot should come in at around £250.
    Less pies and new pads might improve your brakes but the Brembo bits
    look good.
    Andy Bonwick, Feb 4, 2007
  15. Andy Bonwick
    zymurgy Guest
    Why the **** are you braking so hard ? Can't you use the gears /
    engine braking too ?
    Even when trackdaying the 12R the 6 pot tok's didn't fade.
    Could be an idea. What are you using in there ? OEM ?
    P.
    zymurgy, Feb 5, 2007
  16. Andy Bonwick
    "considerably faster than you"?
    platypus
    "Merely corroborative detail, intended to
    give artistic verisimilitude to an otherwise
    bald and unconvincing narrative."
    platypus, Feb 5, 2007
  17. Andy Bonwick
    On 4 Feb 2007 16:10:17 -0800, wrote:
    snip>
    He's got a slipper clutch so stamping down the box and dropping the
    clutch doesn't work.
    You need to ride faster next time.
    ZX10R brakes fade under hard use. I don't know why but it seems as if
    once you've made them fade for the first time then they're fucked.
    Several people I've spoken to have said that braided hoses cure the
    problem but I just went that extra step to make sure I'd fixed it once
    and for all.
    When I bled my brakes after changing to braided lines the fluid left
    in the calipers came out looking as if it was contaminated, it was
    almost black and nothing like the colour of the fluid that was in the
    reservoir. This went for the back brake as well as the front so hard
    use wasn't the cause.
    Obviously I don't know if this is typical of the bike or typical of
    the radial calipers fitted but it's not normal for under 6k miles of
    use. I made sure I flushed the system out with plenty of new fluid
    before I was happy with the job.
    Andy Bonwick, Feb 5, 2007
  18. Andy Bonwick
    <Jumps on bandwagon>
    I'd suggest that if you're even thinking about (deliberately) using
    significant amounts of engine braking on a track you're not getting
    anywhere close to the potential of the bike. In simple terms, as I've
    always understood it, you should be using maximum acceleration out of,
    and maximum braking into, every corner. This doesn't leave much of a
    place for engine braking.
    _______
    Ace, Feb 5, 2007
  19. Andy Bonwick
    SD Guest
    Poor eyesight, and slow reactions, may also fit.
    Oh, and clumsiness. Poor planning.
    | ___ Salad Dodger
    |_\_____/_| ..87918../..23274.../..31893.
    SD, Feb 5, 2007
  20. Andy Bonwick
    Pete Fisher Guest
    <pendant mode>
    Talking strictly of tarmac tracks.
    </pedant mode>
    | Pete Fisher at Home: |
    Pete Fisher, Feb 5, 2007
