Alternator output - ping PipL mebbe
Discussion in 'UK Motorcycles' started by Krusty, Sep 27, 2010.
  1. Krusty
    Google hasn't turned up the Raptor's alternator spec[1], so as a
    general question, is a late '90s Jap bike alternator likely to cope
    with powering a SatNav, heated waistcoat, heated grips & a 100/80 watt
    headlight?
    [1] Anyone know what a TL1000S spits out?
  2. Don't know....
    But someone here
    http://wotid.com/tls/content/view/53/60/
    has stated they ran two 55w driving lights on the TL so that's an extra
    110W. You're adding about 20W for the headlight and ? for the
    waistcoat. SatNav will be negligible.
    However, this all relies on the regulator and alternator on the Raptor
    being the same...
    stephen.packer, Sep 27, 2010
  3. Krusty
    What battery is fitted? Should give you an indication. On the R-GS, BMW go
    up from a 14Ah battery to a 19Ah one, plus a bigger laternator, if the
    heated grips option is specified. This rating is designed to cope with the
    ABS option to, which has a power sapping pump.
    If you have the same battery as Tayna quote for the TL100R (14Ah) then you
    might get away with it. Googling suggests you have a 12Ah battery
    http://www.bikepartsuk.com/modelsearch.asp?model=Cagiva Raptor 1000
    which I reckon will make the charging system marginal.
    Can you use one fo the new fangled 100% more light bulbs? More lumens for
    your standard 55W
    http://www.autobulbsdirect.co.uk/H4-Bulbs/
    wessie, Sep 27, 2010
  4. Krusty
    I'm glad you've decided to come on the winter trip with us but I think
    your Tiger would be better suited to the conditions than the Raptor.
    I send you an invite to the mailing list when I get a chance.
    Andy Bonwick, Sep 27, 2010
  5. Krusty
    Unfortunately not: I only have the service manual for my TL-R left and
    though it gives a description of how the alternator & regulator work,
    how to test them and so on, it just says that the alternator is three
    phase AC!
    Pip Luscher, Sep 27, 2010
  6. Krusty
    Interesting mod, that. Ta.
    The alternator will be, dunno about the reg/rec.
  7. Krusty
    Pretty sure it's a 12Ah.
    I've got the Philips ones in the Jeep & I'm not that impressed. They're
    a bit brighter on dip but they seem dimmer on full beam.
  8. Krusty
    10/10 for effort.
  9. Krusty
    Salad Dodger Guest
    The DL was uprated to 400 watts in 2003. No idea what from, though.
    <pats nice little 1080W Compufire>
    No, I haven't fitted it yet.
    Salad Dodger, Sep 27, 2010
  10. Krusty
    Aha: just found the spec buried in a table marked 'servicing
    information': not in the specifications or in the electrical section.
    The (TLR) alternator's rated at approx. 380W @ 5000rpm.
    Battery is gel 12V 10Ah.
    Regulator is shunt type that uses 3xSCRs controlled by 'a chip'.
  11. Krusty
    Aha! Guess I'd better track down the heated waistcoat & grips specs.
  12. Krusty
    ian field Guest
    Shottky-barrier rectifier diodes Vf typically 0.2V as opposed to 0.7V for
    regular silicon.
    The downside of SB rectifiers is higher reverse leakage and price starts to
    rise rapidly as Vrm rating goes above about 60V - this may not seem much of
    a problem, but a PM alternator can belt out well over 250V if allowed to run
    with no load, so an intermittent connector on the alternator and your
    rectifier is toast.
    The data sheets also recommend ESD handling precautions (sensitive to static
    discharge) but I've never blown one.
    The main advantage of SB rectifiers is very low reverse recovery time (Trr)
    which is good for high frequency switch mode power supplies. Personally I
    doubt the 0.5V per diode saving will yield any noticeable advantage - if the
    current capacity isn't there an extra volt isn't going to make a big
    difference to the power output.
    If I were going to put SB diodes on a PM alternator I'd put an old brit-bike
    zener diode on the output as a failsafe - maybe a couple of silicon diodes
    in series with the zener so it doesn't take over the role of regulator.
    ian field, Sep 27, 2010
  13. Krusty
    Which seems to be 60W for the grips & 38W for the waistcoat, so I
    reckon it'll be fine.
  14. Krusty
    ian field Guest
    If the regulator contains 3xSCR its pretty unlikely to be a shunt type, the
    3 SCRs being half the 3PH bridge rectifier - the control chip simply doesn't
    turn the SCRs on when the battery is full.
    The nearest I've seen to a SCR operated shunt regulator is on the single
    phase PM alternator on the CB250G5/CB200 etc, when the battery is full the
    SCR is switched on to short one AC arm of the bridge rectifier to chassis -
    effectively switching the full wave rectifier to a half wave rectifier.
    A typical example of a shunt regulator would be the old Lucas zener diode -
    there have been various power transistor based shunt regulators from Japan
    with more accurate voltage reference and sharper VI knee curve than a zener.
  15. Krusty
    ian field Guest
    Not a manufacturer official document then.
    (fire thyristors and watch smoke pour out of breather pipe................).
  16. Krusty
    Simon Wilson Guest
    They also don't last very long IME.
    Simon Wilson, Sep 28, 2010
  17. Krusty
    Nah, they're separate.
    IANAE but I reckon you'd get some pretty serious voltage peaks on
    unloaded coils (typically 60-100V) and there's be nothing to measure
    if they were simply switched off for a whole half-cycle. You could
    switch them off as the DC voltage peak exceeded the upper limit but I
    think you'd get some hefty spikes as the magnetic field collapsed, so
    you'd need some means of dealing with that.
    Pip Luscher, Sep 28, 2010
  18. Krusty
    ian field Guest
    More than that - I've measured over 300 on a single phase alternator
    spinning at 5000revs.
    I've also got away with using a SP motorcycle rectifier for mains - but its
    not something I make a habit of.
    If you put the 3 SCRs at the + end of the 3PH rectifier (pointing upwards
    IYSWIM) each SCR having a "bias" resistor to its respective AC input
    terminal, it will switch on every time its AC terminal goes positive. Next
    add the regulator - a chip that senses when the battery has reached 13.8V,
    it switches on 3 transistors that clamp the 3 SCR gates to the + terminal
    and preventing them switching on.
    Switching spikes would only be a problem with GTO SCRs that can be turned
    off by reversing the gate current - normal SCRs once triggered continue
    conducting until the AC cycle decreases below the SCR holding current.
    Whether or not Shindengen thought of it, if I was building a motorcycle
    rectifier I'd use controlled avalanche rectifier diodes, sort of half way
    between an ordinary diode and a zener, Avalanche voltages are typically 350V
    and up and have a much shallower knee curve than a zener.
    An off load alternator shifting 300 + volts won't continue to do so at much
    current, so a decent sized controlled avalanche rectifier will hold it below
    its destructive breakdown voltage.
    ian field, Sep 28, 2010
  19. Krusty
    Steve Guest
    Given that you lost me at the word 'SCR' I suspect you're making all
    this up....
    Steve, Sep 28, 2010
  20. Krusty
    ian field Guest
    Mathew 7:6
