American brake setup
Discussion in 'UK Motorcycles' started by BGN, Sep 5, 2005.
  1. BGN
    BGN Guest
    Hello dears.
    I'm referring to a 1Mb clip posted at
    <http://hayn.gotadsl.co.uk/american.divx.avi>
    What's going on there then, in relation to the front brake setup?
    When Trinity does an emergency stop she grabs the right lever, and she
    appears to lock the rear, upon doing her 'turn in the road' (ahem) she
    isn't holding the right lever, so I assume the left lever is being
    held for the front brake.
    I know it's just a movie clip, but I assumed Merkin bikes had the same
    lever setups as bikes in the UK. Are the levers in this clip just
    used for effect or do they function as demonstrated as standard in the
    US?
    I think it's time for Gin and Bed.
    BGN, Sep 5, 2005
  2. BGN
    Ovenpaa Guest
    Ovenpaa, Sep 5, 2005
  3. BGN
    muddy Guest
    special effects, innit?
    Levers are the same, side stand is opposite.
    Yes.
    muddy, Sep 5, 2005
  4. BGN
    BGN Guest
    BGN, Sep 5, 2005
  5. BGN
    Wik Guest
    You can see all that?! Blimey. May have to fish the DVD out to check.
    It was all done on greenscreen, wasn't it? I guess at some point,
    someone had to actually ride a bike a bit, but I'm fairly certain it
    wasn't wosserface and most all of it was done in CGI. There's a "making
    of" bit on one of the DVDs, isn't there?
    Wik, Sep 5, 2005
  6. BGN
    mb Guest
    OK, tell us which side of the bike your sidestand is on...
    mb, Sep 5, 2005
  7. BGN
    BGN Guest
    Matrix 1 = Lobby scene on loop all day
    Matrix 2 = Road scene on loop all day
    Matrix 3 = I'm sure there's something worth we watching somewhere.
    Disk 2 of Matrix Reloaded. The bike stuff was done on film, but some
    of the vehicles were put in as CGI later on. "Trinity" had done some
    motorbike work before, but I think *some* of the motorcycle stunts
    were done by another lady. The ones where she is 'filtering' are
    deffo done by her stunt double.
    BGN, Sep 5, 2005
  8. BGN
    BGN Guest
    From that clip the side stand looks like it's on the left.
    BGN, Sep 5, 2005
  9. BGN
    muddy Guest
    Maybe they have the image of the bike reversed when they did the special
    effects.
    muddy, Sep 5, 2005
  10. BGN
    BGN Guest
    After a quick search for Harley Davidson on google.com images, it
    appears that the side stands are on the left.
    BGN, Sep 6, 2005
  11. BGN
    Yes, dear.
    Pip, Sep 6, 2005
  12. BGN
    BGN Guest
    Perhaps I should go to work.
    BGN, Sep 6, 2005
  13. BGN
    muddy Guest
    heh
    muddy, Sep 6, 2005
  14. BGN
    muddy Guest
    It was a Duc though.
    muddy, Sep 6, 2005
  15. BGN
    <wags finger, grinning>
    Pip, Sep 6, 2005
  16. BGN
    muddy Guest
    <sheepish look>
    What?
    muddy, Sep 6, 2005
  17. BGN
    BGN Guest
    Upon getting out of the house to start my journey to work I pulled the
    choke open and the fucking cable appears to have snapped. Utter
    BASTARD. I've never had to try to start a motorcycle without a choke
    before, it's like trying to lift a piano down a set of stairs.
    After a quick natter to Uncle Lozzo it appears that I can do something
    with the inlet to the air box after lifting the seat off. After
    getting home from work it appears that I have to take the side panel
    off to do this on my ER5.
    I always get a new car when the ash tray is full. What similar
    measure should one use to judge the life of a bike?
    BGN, Sep 6, 2005
  18. BGN wrote
    In this weather a moderately unworn modern engine should start just on
    the button alone, no choke, no throttle just spinning electrics. If it
    don't it needs a fettle.
    steve auvache
    750 VT Shadow (something for the weekend)
    Bindit 600 (was lost and now is found)
    GS500E (small but perfectly formed)
    mongvan (dehydrated)
    steve auvache, Sep 6, 2005
  19. BGN
    BGN Guest
    Don't be silly.
    BGN, Sep 6, 2005
  20. BGN
    BGN Guest
    Is 18,500 miles moderately unworn? And how modern is a modern engine?
    I think the ER5 has some ancient engine design.
    The engine starts after a little convinving, but then idles at some
    stupid rate and then conks out. After a re-start it seems fine when
    it idles at the right speed.
    It looks like the Pay Day "just needs a new chain" appointment will
    soon be a Pay Day "New chain, new front pads, new brake lines, fanny
    with rear brake, new choke/cable, new <insert next item to go wrong
    here>" appointment.
    Perhaps I should just let it have its 20,000 mile service early.
    BGN, Sep 6, 2005
