An afternoon of fettling
Discussion in 'Classic Motorcycles' started by Timo Geusch, May 25, 2009.
  1. Timo Geusch
    Anybody here know about XL250 Motosports? Apart from me, that is
    (obviously).
    I've tried to make use of the bank holiday to get the Laverda and the
    Motosport closer to being roadworthy. The Laverda is almost there, but
    the XL250 electrics have me stumped. That's annoying, because I'm
    usually quite good with bike electrics. Alas, part of the problem is
    that someone's been at the electrics before me and that someone was
    obviously well versed in Hot Rod electrics because every fucking wire he
    used was black.
    The main bit that has me stumped are the electrics for the lighting
    circuit. My understanding and expectation from playing with other Hondas
    is that all connections from the handlebar switches go into the
    headlight shell and from there into the main loom. This doesn't seem to
    be the case on this Motosport as the connectors from the rhs switch
    block go into the main loom. Which makes sense because Honda designed
    this bike for an easy conversion to a light-less offroader and you'd
    still want the kill switch connected. Unfortunately the wiring colours
    on the headlight switch also don't match up with the OEM Honda wiring
    diagram. Bah. Looks like I'll have to measure my way through the wiring
    loom and work out what's what...
    Compared to that bowl of Udon noodles the Laverda is almost ready - I
    need to apply some paint protection film to the back of the tank, get
    some new fibre washers for the petrol taps and then I can almost think
    about getting it MOTd.
