An old chestNUT
Discussion in 'UK Motorcycles' started by Pete Fisher, Jun 29, 2006.
  1. It's possible the smaller rattle gun shocked things enough to do some of
    the job, but the 3/4" would have done it I'm sure.
    Essentially a bit of friction welding, imo. I'm fairly sure if you were
    to microscopically examine the thread surfaces you'd see a fair bit of
    tearing.
    Grimly Curmudgeon, Jul 3, 2006
    #41
  2. Pete Fisher
    Pete Fisher Guest
    In communiqué <>, Grimly
    Hmm, I probably should have forked out the extra for 3/4 drive but I
    already had a couple of impact sockets in 1/2.
    I suppose the 'rattle' may, if nothing else, have allowed the plus gas
    to "reach the parts". PG really is the dogs bollox of penetrating oil
    IMHO. Increasingly difficult to find though.
    It's one of those days though. Looked closely at the sprocket/torsion
    damper assembly and manual to see that a circlip needs to come off. My
    pikey little old convertable internal/external thingy is not up to the
    job. Never had to tackle a 55mm diameter, thick, strong, bastard before.
    Ho hum - another trip out. Now I come to look closely at the old
    sprocket it isn't really in too bad nick either.
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Jul 3, 2006
    #42
  3. Useful tip - bus and truck repairers have 1" rattle guns with compressor
    power to match for those things that are really stuck.
    #43
  4. Pete Fisher
    Pete Fisher Guest
    No doubt they have fucking great big circlip pliers as well. I would
    quite gladly have replaced mine with less pikey ones, but all I can find
    locally are poxy little Draper jobs. Nice interchangeable prongs, but
    just not enough stroke to get the job done (no puns please this is
    UKRM).
    Currently trying to prise the bastard out while the sprocket is held in
    a vice, using what I have got and selection of sharp instruments. Trip
    to casualty in the offing no doubt.
    If the chap who used to service my SOCs in the old days was still in
    business I would run round to him with it. Note to Steve H - except the
    Alfa. His comment when I proudly turned up with the 2.5 V6 75 Cloverleaf
    at his workshop ? "You must be fucking mad. No way am I touching that
    fucking thing." Fortunately I found a local Alfa guru, but that is
    another story.
    Come to think of it, when I am on site tomorrow I can pop across to
    'Meteor'. A lot of my cash went their way for a few years persuading an
    MoT tester to issue a certificate for a 1984 Talbot Express based camper
    van. They owe me a favour.
    #44
  5. Pete Fisher
    Pete Fisher Guest
    Bad form to follow up my own post but it is DONE!
    With the aid of much cursing, old circlip pliers, an ancient 'Opinel'
    lock knife I found when walking the hill at Mont Verdun in '83, and a
    screwdriver.
    Re-assembly was a reversal of the above procedure.
    No slashed wrists (even intentional).
    Thanks to all who offered hints and tips, and a very funny
    'divertissement' from Pip - must be a white hat thing ;-)
    Time for something long and chilled (containing alcohol and taken by
    mouth).
    #45
  6. Pete Fisher
    I've just spotted this - no, the300Kg wasn't Nick, it was the all-up
    weight of the ZZR plus LOz, lifted at the business end of the scaffold
    pole.
    Pip, Jul 5, 2006
    #46
  7. Pete Fisher
    I always forget about gravity, he said lightheadedly.
    I did think that, but it seems like an enormous mass/weight/force to
    me. I'm stuck with 100 pound feet being quite a lot, see.
    Pip, Jul 5, 2006
    #47
  8. Pete Fisher
    Kewl. Persistence pays dividends.
    It's often surprising what you'll dig out of the old toolbox when your
    back's against the wall. I know what you mean about the lock knife, I
    have a WWI British Army issue penknife which has a somewhat unlikely
    can opener next to the blade. It must be made of some decent steel,
    as it has pried, levered and persuaded many reluctant fittings apart
    in ways that the manufacturer could never expect.
    As to the circlip dilemma, I've had bodgery success with three drifts
    and a Mole grip: fit two drifts into the 'eyes' of the circlip, wedge
    the third drift perpendicularly in between them to act as a fulcrum,
    held with the (gloved) left hand; then apply Moles and squeeze the
    drifts together, closing the circlip. It will work to open a circlip
    too, by squeezing the other side of the fulcrum. Takes a bit of
    jiggling to get all the bits into a functional position, but sufficed
    to strip an Alfa gearbox that seemed to be held together exclusively
    by inaccessible circlips.
    Hope you enjoyed it ;-)
    Pip, Jul 5, 2006
    #48
  9. Pete Fisher
    Pete Fisher Guest
    Excellent! 'White hat' cunning at it's best.
    Putting it back on was, if anything, more hairy. Was it going to break,
    or more likely fly off into the furthest recesses of the garage, amongst
    the detritus of previous similar man machine interactions, never to be
    seen again?
    Pete Fisher, Jul 5, 2006
    #49
  10. Pete Fisher
    ChrisDC Guest
    Just remember, 100 Nm is about right for car wheel-nuts. Sorted.
    ChrisDC, Jul 5, 2006
    #50
  11. Pete Fisher
    Cab Guest
    Bugger. I are a pillock. Of course.
    Cab, Jul 6, 2006
    #51
  12. Pete Fisher
    It's the compressor that does the work not the driver. In all honesty
    anything less than 120cfm isn't worth a **** for sustained use and you
    just won't get that from a home use compressor.
    Andy Bonwick, Jul 7, 2006
    #52
