And so it begins. (GL fettling update 2008.1)
Discussion in 'UK Motorcycles' started by SD, Mar 29, 2008.
  1. SD
    I considered leaving a note in the house telling her that I'd had to
    scrape ice off my windscreen at 5am but decided not to bother.
    Andy Bonwick, Mar 31, 2008
    #41
  2. SD
    dog Guest
    you'll have messed up all her log entries now.
    dog, Mar 31, 2008
    #42
  3. SD
    M J Carley Guest
    I didn't leave a note saying I'd had to scrape ice off my saddle. We
    probably passed each other on the M1.
    M J Carley, Mar 31, 2008
    #43
  4. Ooh. Want one.
    The Older Gentleman, Mar 31, 2008
    #44
  5. I've succumbed to temptation and ordered one.
    Not because I need it. Just because.
    #45
  6. Will the rivnuts work with a standard pop-rivet gun, or is there
    something fundamentally different between them?
    Dr Ivan D. Reid, Mar 31, 2008
    #46
  7. SD
    Beav Guest
    What d'you think's holding the bog on in your front wing?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 31, 2008
    #47
  8. SD
    antonye Guest
    There is quite a difference, yes.
    The Rivnut gun works by threading a sized insert, eg M6, into
    the Rivnut to be located in plate. The insert is like a bolt,
    but has a collar on it that screws into the gun. So the Rivnut
    is threaded onto the insert which is secured to the gun.
    Squeezing the handles together pulls on the insert in the
    Rivnut. The only bit that can deform is the collar at the
    top of the thread (behind the hosting sheet of metal), so
    it bulges outwards and nips up against the host sheet. A
    bit like using a rubber version.
    What normally happens with these is that Some Numpty(tm) will
    over-tighten the bolt in the Rivnut to the point where the
    collar slips on the host sheet, so it just ends up spinning.
    If you're lucky and can get the bolt out (with malicious
    use of mole-grips) then you can tighten up the Rivnut by
    using the gun on it again.
    antonye, Mar 31, 2008
    #48
  9. SD
    <sucumbs>
    Me too.
    Oi, Dodger - where did you order the rivnuts from?
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Mar 31, 2008
    #49
  10. That'll be me or SD, then.
    #50
  11. And do they do bulk orders?
    #51
  12. SD
    Beav Guest
    Metrics are now measure in AF? That's a new one on me.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 31, 2008
    #52
  13. SD
    Beav Guest
    Well you never know do you? I'm about to order one too.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 31, 2008
    #53
  14. SD
    How would you imagine the spanner jaw gap (metric or imperial) and across
    the flats head sizes (metric or imperial) are measured?
    sweller, Mar 31, 2008
    #54
  15. SD
    Pete M Guest
    Mate of mine does the same, but he uses old piano keys.
    Pete M, Mar 31, 2008
    #55
  16. SD
    Pete M Guest
    They are brilliant. I discovered the wonder of Rivnuts about 10 years
    ago. Perfect for fitting spotlamp brackets to rally cars, discovered
    them when I found out that's how Ford used to do it.
    #56
  17. SD
    We're convinced already - we've just bought the tool! Where do we get
    the nuts from?
    Champ
    Champ, Mar 31, 2008
    #57
  18. SD
    SD Guest
    uktools on Ebay.
    SD, Mar 31, 2008
    #58
  19. SD
    SD Guest
    I bet it'll be me first.
    Given a new collector is £195 (*plus* VAT and delivery) from Motad, I
    hope this works.
    SD, Mar 31, 2008
    #59
  20. SD
    Ta. Typical - buy a 10 quid tool, then find I need 30 quids worth of
    bits for it.
    Champ
    Champ, Apr 1, 2008
    #60
