Another crappy vid
Discussion in 'UK Motorcycles' started by ogden, Sep 15, 2010.
  1. ogden
    I didn't think it looked too bad. Once you've got the confidence in
    your ability to physically climb it then there's no difference between
    climbing that and climbing 50' because if you fall from either height
    you're dead.
    I've done just over 500' lightweight caving ladders and didn't worry
    about a lifeline because we didn't have one long enough and we
    couldn't be arsed knotting two or three shorter ones together. Those
    things used to twist and flap about all over the place but once you'd
    got the technique sorted they were actually quite easy to climb and as
    long as you didn't lean out from the ladder there was no real weight
    on your arms.
    The biggest bastard of them all is when you clip into a rope with
    about 150' above you to the attachment point and then step off
    whichever ledge you're on without thinking about the 10% stretch in
    the rope. That 15' fall before the stretch is taken up seems a long
    way and your first thought is that the fucker has ripped out.
    Andy Bonwick, Sep 15, 2010
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, ogden
    That.
    Wicked Uncle Nigel, Sep 15, 2010
  3. ogden
    There's not really very much to catch the wind and make it way is
    there?
    I wouldn't want to be near it if it got some seriously icy rain or a
    snow storm hit it because it'd build up on one side and then it'd
    start wobbling if the wind got hold.
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Andy Bonwick
    There fucking is! You'd get *much* longer to think about it all on the
    way down.
  5. ogden
    All the money in the world wouldn't get me up there. Even the promise
    of a bj from Natalie Imbruglia wouldn't get me up there.
    Krusty, Sep 15, 2010
  6. ogden
    Salad Dodger Guest
    I thought he'd only ever got halfway up a telegraph pole?
    Salad Dodger, Sep 15, 2010
  7. ogden
    Salad Dodger Guest
    That's worse than the old footage of Dibnah doing his stuff. At least
    this bloke's not lashing his own ladders as he goes.
  8. ogden
    Jérémy Guest
    Don't you use static ropes in caves? 10% would be quite a lot for a
    climbing rope, depending how much you weigh.
    Jérémy, Sep 15, 2010
  9. ogden
    boots Guest
    The BT tower has a good wobble too. I was working there the day after
    my brother's stag do, it was a while before I realised it wasn't
    totally due to my excesses from the previous night
    boots, Sep 15, 2010
  10. ogden
    Beav Guest
    My granddad used to be the deputy manager of a cotton mill (Holdsorth and
    Gibbs) in Lancashire when I were a sprog and he asked me if I wanted to
    climb the chimney when the thing was next due a cleaning. I've no idea how
    high it was and I can't ask Fred Dibnah who dropped it years later, nor me
    grand dad coz he's dead but it was an experience I wasn't and still aren't
    in a hurry to do over.
    The higher you climb, the more it feels like the ladder is leaning backwards
    trying to tip you off and it was the fucking scariest thing I've ever done.
    Come to think about it, it still is. No cage around the ladder either an
    definitely no safety line, but I had granddad right behind (underneath?) me.
    As for the bloke in the vid, well he's obviously just a total nutter,
    although it'd be a pretty good jump off point for and aspiring base jumper.
    Beav, Sep 15, 2010
  11. ogden
    Beav Guest
    Half the time (or more), he wasn't tied in though.
    Beav, Sep 15, 2010
  12. ogden
    Beav Guest
    It's also like sliding your hand up a tarts skirt for the first time. It's a
    lot further to the prize than can be imagined.
    Beav, Sep 15, 2010
  13. That makes me feel decidedly ill.
    Ironically I can look down from the Empire State Building observation
    level with no great problem - note not the very top bit where there is a
    radio mast.
    There was a splendid programme on BBC4 [1] on Tuesday night which showed
    30 mins of historical footage of Newcastle upon Tyne. In that they
    showed the men building the Tyne Bridge. How the hell they walked along
    narrow metal beams with no H&S equipment at all I do not know. I
    struggle to walk across the bridge on the pavement!
    [1] there were actually several good programmes about Newcastle over the
    one evening.
    Paul Corfield, Sep 15, 2010
  14. ogden
    For SRT we used to use static which 'd have about 3% stretch but you
    can't use that on ladders because if you fall on static it hurts a lot
    and the anchors tend to rip out. 'Lifeline' type rope for ladders
    would be max 10% (this is from memory so +/- a small bit) but you'd
    not expect to fall far if the guy on the line knew what he was doing.
    The time when I found out how much stretch there is in dynamic rope
    we'd been arsing about on a ledge with the ladder a bit of a swing
    away from where I was standing and I tied into the rope then took a
    jump for the ladder. I missed and went into free fall then bounced a
    few times before I grabbed the ladder and climbed up. The sensible way
    to do it would have been to have left a tether on the ladder holding
    it where it could be reached easily but that would have required a
    degree of common sense and I was cold & tired so couldn't be arsed.
  15. ogden
    boots Guest
    Wasn't that what happened to the Emley Moor mast?
    boots, Sep 15, 2010
  16. ogden
    I honestly don't know but I've been on a site where the whole place
    was evacuated after a flare stack suffered icing then started to
    misbehave and that was only about 150' tall.
    I got conned into cutting the tip off a much bigger flare stack in
    Kazakstan and when we were stood on the platform at the top doing the
    cut the cables supporting the tip were shrouded in ice. When we cut it
    the fucker shot several feet up in the air, the ice popped off the
    wires and it came back down with a big bang. Laugh? I nearly pissed
    myself.
  17. ogden
    Jim Guest
    Well, the answer for that is that you're just as dead falling from
    1700ft as 50ft, you just have more fun on the way down.
    Jim, Sep 15, 2010
  18. ogden
    Colin Irvine Guest
    "This video is no longer available due to a copyright claim by
    TheOnLineEngineer.org."
    Colin Irvine, Sep 16, 2010
  19. ogden
    geoff Guest
    Yeah - did anybody download it ?
    geoff, Sep 16, 2010
  20. ogden
    Cab Guest
    I'd be up there like a shot, if a bj from Natalie was on the cards. I'd do it
    without a cord, there and back inside of half an hour.
    Cab, Sep 16, 2010
