another f-ing cd200 question
Discussion in 'UK Motorcycles' started by darsy, Nov 10, 2003.
  1. darsy
    how the **** to I get the back wheel back on?
    What's going to be easiest - the cush drives fitted to the wheel, and
    try to align with the sprocket thing, or fit the rubbers to the
    sprocket thing and try and push the wheel on?
    neither seem to work - the sprocket thing is too floaty to get any
    sort of sensible purchase on it, and I just cannot get the wheel
    pushed onto it.
    Any ideas?
    darsy, Nov 10, 2003
  2. darsy
    simonk Guest
    Throw it in a skip and get a scooter ?
    simonk, Nov 10, 2003
  3. darsy
    tempting.
    darsy, Nov 10, 2003
  4. darsy wrote
    *ROFL*
    steve auvache, Nov 10, 2003
  5. darsy
    WorkTOG Guest
    Cush drives on the wheel. Grease them, so they slide in easier.
    If all else fails, remove the sprocket carrier from the bike and refit
    the wheel the non-QD way. That means removing the chain case and
    splitting the chain, of course.
    WorkTOG, Nov 10, 2003
  6. darsy
    you've got all this to look forward to, you know...
    darsy, Nov 10, 2003
  7. I've owned Benlys in the past, and never had a problem.....
    The Older Gentleman, Nov 10, 2003
  8. darsy
    On Mon, 10 Nov 2003 18:49:03 +0000,
    share and enjoy.
    Anyway, mine's running OK now...
    darsy, Nov 10, 2003
  9. darsy
    still?
    <fx: surprised>
    sweller, Nov 10, 2003
  10. darsy
    well, it needs the idle speed upped a tad, but it's running pretty
    well. Occasionally pulling off from rest it gets a bit uppity, with a
    little backfire and hesitation, but I'm going to hold off worrying
    about that until I up the idle speed to see if that sorts it - slowing
    right down and then speeding up again doesn't bother it - it's only
    when it's asked to accelerate after idling that it complains.
    I suppose I ought to MOT and tax it at some point...
    darsy, Nov 11, 2003
  11. darsy
    Warm up CD (take it for a spin, rather than have it hoping around the
    garage), small brass screw with knurled slotted head on the RH side of
    carb is the idle speed adjuster. Screw it in (clockwise) to speed up.
    Blip the throttle a couple of times to make sure it settles and idles ok.
    The hesitation maybe the carb slightly gummed, and it doesn't like the
    transition from idle circuit to main jet. You could always try running
    it with redex in the petrol for a couple of hundred miles. If it's a
    real PITA or it starts to get worse it may warrant some further
    examination.
    What's it like without the air filter in place, does it hesitate from
    idle then?
    sweller, Nov 11, 2003
  12. darsy
    Ok - I actually came into work on it this morning, so it'll be nice
    and warmed up by the time I get home this evening, so I'll do it then.
    It's only very slightly slow - it's purring nicely, but kinda sounds
    like it's about to stall but never does, if you know what I mean.
    what's redex exactly? I'm always slightly suspicious of fuel
    additives.
    sure - it's not that bad at all, and can be avoided by giving the
    throttle a bit of a blip before actually pulling off.
    err, how do I remove the air filter - doesn't that mean removing the
    tank?
    darsy, Nov 11, 2003
  13. darsy
    It's an upper cylinder lubricant, supposed to clean gum and varnish from
    fuel and airways. Their injector cleaner makes an appreciable
    difference, even factoring in the "it must be good, it says so. And it
    scares elephants" psychology.
    I'm also always be suspicious of wonder treatments, having been on the
    receiving end of one or two in the past.
    Redex has been about for donkey's years. It may do what it says as BR
    (Bristol Bath Rd, IIRC) used to use it in an attempt to keep the turbos
    clean, without removing them, between exams on the aging class 47 fleet.
    Apparently.
    Your carb is a bit shitty, witness the seized carb slide, so a proper
    strip and clean may do wonders. If you're man enough to ride it 50 miles
    it can be done in an hour or so. Riding it 50 miles may also cure it...
    Under LH side panel there is another cover remove it and behind is a
    metal cage covered in foam. Pull it out, it just clips in place. This
    is the air filter which you have now removed.
  14. [cd200]
    Wouldn't that also be it's longest journey for about 3 years?
    William Grainger, Nov 11, 2003
  15. darsy
    If you're suggesting what I think you're suggesting, then I make it
    more like 90 miles each way.
    Still, I'll ride it two and from work this week, that'll be about 110
    miles all in, and we'll see how it goes.
    darsy, Nov 11, 2003
  16. darsy
    by a large margin, yes.
    it's really pretty much OK; certainly perfectly acceptable for my 10
    or so mile journey to work.
    darsy, Nov 11, 2003
  17. darsy
    Jeremy Guest
    but for frankfurt...?
    Jeremy, Nov 11, 2003
  18. darsy
    darsy, Nov 11, 2003
  19. darsy
    Jeremy Guest
  20. darsy
    that's a thought - I'll have to see what the weather's like the next
    suitable weekend.
    I'm not currently a member of any breakdown service - do any of them
    actually offer cover to >20 year old <200cc bikes?
    darsy, Nov 11, 2003
