Another HTPC thread. Popcorn C-200. Bewilderment.
Discussion in 'UK Motorcycles' started by 'Hog, Jan 12, 2010.
  1. 'Hog
    'Hog Guest
    Just as I was about to hit BUY on a WD TV LIVE HD media player I noticed the
    existance of the C-200. Has anyone been using this Popcorn device? Three
    times the price of the WD but it has slots for HDD and Blu-Ray and I don't
    care what it costs if it generally supports a lot more functionality. I have
    a TB NAS anyhoo for storage.
    Seems to me that building an HTPC with HD video/audio is an expensive
    project compared to using a £100 'streamer (though it is another damn device
    and handset lying around. An Asus Xonar sound card is £140 alone and the
    current AMD 2700 processor isn't going to cut the mustard so that's a new
    chip and motherboard.
    'Hog, Jan 12, 2010
  2. 'Hog
    Domenec Guest
    Checked the PopCorn...
    http://www.popcornhour.com/onlinestore/index.php?pluginoption=productspec&item_id=12
    At that price or lower you can get some mini-itx mobo+processor and a
    case, HDMI video output and 5.1 audio included. Not sure, but you I
    think should de able. Then power it with XBMC
    http://xbmc.org/about/
    Note that PopCorn uses a 667MHz processor that is below the specs of
    my shite olde Via Epia 800 (running at 800MHz and being able to do
    some video transcoding)
    Sure Popcorn works out of the box, but a hand-made HTPC is a creature
    you get to love, and as a winter project your living room is warmer
    than the shed :)
    Domenec, Jan 12, 2010
  3. 'Hog
    frag Guest
    took a blunt brush and painted...
    Post corrected :)
    I looked at getting the Popcorn, wes very very tempted but decided to go for
    Squeezebox as I didn't need any video capability.
    If I wanted something to do audio and video I'd get the C-200 without
    hesitation.
    frag, Jan 12, 2010
  4. 'Hog
    Domènec Guest
    Domènec, Jan 12, 2010
  5. 'Hog
    frag Guest
    Don't know if you're an iPhone user but if you are check out iPeng when you
    get the SqueezeBox. Very nice control app.
    frag, Jan 13, 2010
  6. 'Hog
    'Hog Guest
    Nice, but it isn't an HD video device.
    For £100 delivered I'm going to order the WD HD Live box. WTF. It overcomes
    the current HTPC limitation by playing ripped Blu-ray movies. Sadly my
    Panasonic plasma display has only 2xHDMI ports and the HTPC and DVD/Surround
    system use them up. There seem to be autosensing HDMI mini hubs available
    though and the WD and DVD will never be in contention.
    For no reason other than geekiness I want (ultimately) a large expensive
    energy hungry PC based HTPC with a multi region Blu-ray RW drive, DTS-HD 7.1
    sound and lots of flashy LED's. I hadn't realised the Asus Xonar does video
    processing as well and has 2xHDMI outputs.
    Mindewe I fancy one of those Xonar Essence STX cards for hi-fi audio
    'Hog, Jan 13, 2010
  7. 'Hog
    frag Guest
    The HD is superfluous :)
    When you get one of these let me know how it works.
    I want something that'll take upto 5 HDMI inputs, has 2 HDMI outputs and can
    also output the audio to a seperate digital socket to pipe to the amp.
    I've got a lovely SD > HD scaler that can do all that, but because its main
    purpose is to scale SD up it doesn't auto switch the output frequency to
    match the input. (in spite of the manual saying it should do)
    So I end up with 1080i/60Hz input, 1080i/50Hz output and the picture shifted
    to the left by a third until I switch the output to 1080i/60Hz.
    Don't forget it's go to go "Ping!" as well.
    frag, Jan 13, 2010
  8. 'Hog
    'Hog Guest
    Habba Hubba Hubba
    www.quietpc.com/ie-en-eur/products/watercooling/reserator1-v2
    'Hog, Jan 13, 2010
  9. 'Hog
    'Hog Guest
    I suppose I'm mainly playing music and DVD from HDD. I'll go into the
    rental shop, take 4 films for a night or whatever they have going, then
    DVDFab them for future consumption. Or I might have the odd 1080P Blu-Ray
    from <cough> Rapidshare. The WD box will allow me to play 1080P HD without
    upgrading the PC. Looking around the new top end
    case/motherboard/processor/psu etc is in the £600+ range.
    But now you mention it, would be nice to have an intelligent PVR function
    that can grab a program (or Series) and would pick up any changes in
    transmission time (and skip blipverts). What does one need to add to
    achieve that? Can it be fed from the TV tuner or perhaps I can guess you
    need a TV card and aerial feed (and software).
    I unwrapped XBMC on Monday and just started to look through it.
    'Hog, Jan 13, 2010
  10. 'Hog
    frag Guest
    took a blunt brush and painted... **** me, the radiator / reservoir is a bit OTT.
    No fan on the CPU/GFX but it does have a water pump. I hope it's a quiet one.
    I'd be tempted to plumb in the living room radiator.
    frag, Jan 13, 2010
  11. 'Hog
    Have you found anything to convert the recordings to AVI/MPEG or
    anything else that works outside W7? That's the only thing pissing me
    off with it at the moment. Well that & the lack of a decent interface
    for organising channels.
    Krusty, Jan 13, 2010
  12. 'Hog
    'Hog Guest
    I guess a new box will end up W7. What about the hardware for TV capture
    etc?
    'Hog, Jan 13, 2010
  13. 'Hog
    Ooh ta, I'll try that.
    You still only using it with a PVR-150 through your Sky box...? If so,
    imagine what it's like when you've got 1000ish freesat & freeview
    channels in no particular order to sort out.
  14. 'Hog
    What source(s)?
  15. 'Hog
    Colin Irvine Guest
    Interesting. Some of the Humax PVRs have been experiencing problems
    that can be sorted by doing a manual channel search to ensure only one
    transmitter is being used.
    Colin Irvine, Jan 14, 2010
  16. 'Hog
    I'm doing that - slowly. And re-ordering, & building 'Favourites'
    groups, & changing the tuner preference, because....
    ....of that. I've had the same problem on some channels, but they're
    available on freesat too so I've just done the 'edit sources' thing &
    switched off the freeview feed.
    Krusty, Jan 14, 2010
  17. 'Hog
    'Hog Guest
    Just coax aerial and Freeview
    'Hog, Jan 14, 2010
  18. 'Hog
    http://www.hauppauge.co.uk/site/products/data_novat500.html if you get
    all the channels you want on Freeview. If you want to record analogue
    too you'll need something like a Hauppauge PVR150 too. Don't be tempted
    by one of the cards with software analogue decoders - they're shit.
