Another question - Air Jackets?
Discussion in 'Australian Motorcycles' started by GWD, Jan 5, 2011.
  1. GWD
    F Murtz Guest
    Won't work, before I made my microswitch contraption I made a flap cover
    which covered the ignition key slot, It was supposed to nudge my
    subconscious (to remove disklock) by having to lift it to put key in.
    I just lifted flap put key in, started, and then fell off bike again,
    (did not remove disklock)
    F Murtz, Jan 10, 2011
  2. In aus.motorcycles on Mon, 10 Jan 2011 20:52:28 +1100
    I have an old ubolt lock that has a flat key not a round key.
    When I used it regularly I used to have a bit of tubing that fitted
    over the ubolt key. To unlock the ubolt to use it I removed the
    tubing and put that on the ignition key.
    Can't turn the ignition on with the tubing on the key.. so it's a good
    reminder to unlock the ubolt and put the tubing back on the ubolt key.
    Zebee
    Zebee Johnstone, Jan 10, 2011
  3. GWD
    Nev.. Guest
    Yes you probably have it wrong. You were probably misled by other
    people who were wrong. The website states that 30kg of force is
    required to activate the 'ripcord'. That's an awful lot of effort
    before you actually do any harm.
    Nev..
    Nev.., Jan 10, 2011
  4. GWD
    F Murtz Guest
    So they do allow for idiots like me, Still think they should not exist
    there are to many brainless lawmakers that will want to make them
    compulsory.
  5. GWD
    G-S Guest
    Actually 30kg isn't that much. If I lent backwards a bit as I was
    stepping off a taller bike there could easily be that much force on a
    cord if I overbalance a bit given that I'm a bat fastard :) [1]
    G-S
    [1] skinny people would obviously be less subject to this problem.
    G-S, Jan 10, 2011
  6. GWD
    G-S Guest
    Speaking as a 'forget - er' of disk locks I can see myself forgetting
    the airbag jacket tab on an occasional basis as well.
    I REALLY don't like the idea of them being required by law but I have no
    problem with them being available for those who want to use them.
    G-S
    G-S, Jan 10, 2011
  7. GWD
    G-S Guest
    I tried that, it took me until next week to find my keys because the
    weather warmed up and I was using my summer gloves and my keys were in
    my winter gloves.
    Now that's a useful tip, but neither my summer or winter gloves have
    them (my previous pair of winter gloves did though).
    G-S
    G-S, Jan 10, 2011
  8. It will have to be redesigned then, seeing that you have got out of there at
    least once
    George W Frost, Jan 10, 2011
  9. Then Nev, if you had one and stepped off the bike, it would go off very
    easily with your 130 Kg frame
  10. Almost the same as with a car, with you getting a possible fine for not
    having your seat belt done up before you put the key in the ignition.
    So, you get in the car, do up your seat belt to be legal, then remember that
    your keys are still in your jeans pocket, then go through the whole
    rigmarole again
  11. GWD
    Nev.. Guest
    Actually I would think 30kg is a huge amount of force. The cord is not
    attached to your entire frame... it's attached to a single tether on
    your jacket. Tie a piece of cord to a corner of your jacket and tie the
    other end to a 20kg bag of cement. Give it enough slack to let you take
    about 1 step before the cord pulls tight. Now step away from the cement
    bag with the same effort that you would if you had just taken a step
    back from your bike and see how much effort is required before you start
    to drag the bag along the ground. I'm guessing the jacket will try to
    tear itself off your body before the cement bag goes anywhere, and
    you'll have to exert at least a small amount of effort before you start
    moving the cement bag. Now add another 10kg of dead weight to the bag
    of cement and do it again. The website actually warns that if you have
    a light bike, the bike might actually fall over before the 30kg force
    required to activate the air jacket is reached.
    If you're such a bat fastard who's prone to overbalancing when you get
    off your bike you should probably be first in the queue to buy an airbag
    jacket, but to protect yourself when you're off the bike, rather than on
    it. :)
    Nev..
    Nev.., Jan 11, 2011
  12. GWD
    Peter Guest
    30kg dropped vertically 600mm on wire rope attached to a fixed anchor will
    result in about 1Kn of force on the anchor.
    How much force is required?
    I imagine a 12 month replacement on certain parts as well.
    :p
    Peter, Jan 11, 2011
  13. GWD
    Nev.. Guest
    I've never studied any physics. I have no idea how you came up with
    that or what it means, but it sounds like enough force to activate the
    airjacket - which sounds ideal for an unplanned stop situation where
    rider and bike part company.
    I snipped the bit about warranty because I couldn't actually work out
    what you were alluding to.
    Nev..
    Nev.., Jan 11, 2011
  14. GWD
    Theo Bekkers Guest
    30 kg doesn't sound like much force when there's inertia involved.
    Theo
    Theo Bekkers, Jan 11, 2011
  15. GWD
    Theo Bekkers Guest
    Most people need the key in their hand to get into the car George.
    Theo
  16. Very likely in Queensland at the moment.*
    Fraser
    *particularly if you are crazy enough to be riding a bike in this weather.
    Fraser Johnston, Jan 11, 2011
  17. GWD
    Nigel Allen Guest
    On 10/01/2011 8:27 PM, TimC wrote:
    That must have hurt a lot! Very nasty spot to be bitten.
    My dad was shot in the Dardanelles. Bloody wonder I was ever born.
    N/
    Nigel Allen, Jan 11, 2011
  18. I could see it happening on my CBR1000RR street fighter. No fairing made
    speeds above 160km/h a hang on proposition. Over 200 it felt like a gorrila
    was trying to drag you off the back of the bike.
    Fraser
  19. As long as the japs or germans built it that sounds absolutely brilliant. The
    italians and english should never under any circumstances be allowed to build
    anything that involves electricity, or as they call it, magic smoke.
    Fraser
  20. GWD
    Nev.. Guest
    What inertia? Don't you stop your bike before you dismount?
    Nev..
    Nev.., Jan 11, 2011
