Any one else ever seen this ?
Discussion in 'Motorcycle Technical Discussion' started by Runk, Apr 26, 2009.
  1. Runk
    Runk Guest
    My 84 Goldwing evidently has a bad float or needle in on of the left side
    carbs. After it's shut off it will drip a small puddle of gas out the bottom
    of the exhaust pipe. Seems to be running into the crank case also and
    diluting the oil. Just wondered if anyone else has run into this . Kind of
    thinking the alky in the gas nowadays is attacking some components. Just
    bending some ears...
    Runk, Apr 26, 2009
  2. Runk
    Guest
    Yes.
    The additives may be eating up the rubber parts, or the gasoline may
    be evaporating and causing the float valves to stick from gum and
    varnish buildup.
    I add Stabil to a full tank of gasoline before storing my bike for the
    winter, and I run 4 or 5 ounces of Berryman B12 Choke and Carburetor
    Cleaner through a full tank of gasoline in the spring.
    If B12 doesn't solve the problem, you may need to disassemble the
    carbs and examine the float valve seat. The tiniest bit of gum and
    varnish can keep the float valve from seating.
    Sometimes it's necessary to stick a piece of crocus cloth on the end
    of a small
    rod or perhaps a 1/8th inch drill and use that to clean the float
    valve seat.
    If all else fails, you can mail order new float valve parts from:
    www.carbkitscapital.com
    www.flatoutmotorcycles.com
    www.powersportspro.com
    www.bikebandit.com
    www.oldbikebarn.com
    €, Apr 26, 2009
  3. I wouldn't worry about modern fuel rotting the components, whatever
    Krusty says. I've never known it to happen (fuel companies do test their
    fuels, amazingly enough).
    Likewise, it's very unlikely to be gummed carbs unless the bike has been
    laid up for ages, and even then, the float assemblies are the last
    things to gum up, in my experience.
    So, you've almost certainly got a leaking float valve. Sometimes the
    float valves just stick on Hondas of this generation (and earlier).
    Tapping the carb body with a tool is often enough to free them.
    However, there's a photo-essay article in the very latest Classic Bike
    (UK magazine) whch details this very problem on some old Hondas.
    The culprit is a little rubber O-ring which seals the float valve
    housing into the carb body. With the passage of time, this hardens and
    lets fuel through, even though the float has actually operated and shut
    off the valve.
    These little O-rings are surprisingly costly, especially if you want to
    do a bank of carbs. However, the seat can be removed (it's just a
    push-fit) and a *very* small dab of gasket sealer around the O-ring is
    enough to make it fuel-tight again. Cost effectively zero.
    The article shows the whole thing, step by step, with pictures.
    I'm afraid Krusty didn't refer to this because it's not something he
    knows about, unless he's read ther article in question. I must say I
    didn't know about these seals until someone brought it to my attention.
    If I'm feeling charitable, I suppose I could do a hi-res scan of the
    article and stick it on a web page for you.
    The Older Gentleman, Apr 26, 2009
  4. On older BMWs the floats need occasional
    replacement. Not sure why, but they begin
    to admit too much gas in exactly this way.
    I replaced the floats on mine recently. While I
    was at it, I took a mototool and scribed a couple
    marks on the inside of the float bowl to make
    it easier to adjust and check the float height
    when I have the bowl off.
    Could also be a problem with the float needle
    or just a hunk of crud preventing the float
    from seating correctly. Check for both of these
    when you pull the float bowl.
    Rkleinsch1216128, Apr 26, 2009
  5. Runk
    Guest
    Suck.
    My.
    Dick.
    €, Apr 26, 2009
  6. Do you ask everyone to do this?
  7. Runk
    Guest
    Just you, princess.
    €, Apr 26, 2009
  8. Runk
    Schiffner Guest
    Well you know how that chickehawk is, desperate because he can't bend
    that far.
    OBTW thanks for the heads up on that O ring. Though mine carbs haven't
    had to be apart since new...in 1979.
    Schiffner, Apr 26, 2009
  9. Runk
    Runk Guest
    Thanks guys for the ideas , I'm getting ready to tear into the carbs . I'll
    let ya know what I found. Runk.....
    Yes.
    varnish buildup.
    of a small
    valve seat.
    www.bikebandit.com
    www.oldbikebarn.com
    Runk, Apr 27, 2009
  10. Nor mine, on the 400, since new in 1977. Beat ya!
    Though one carb is mildly incontinent. But there's a manual fuel tap and
    turning the fuel off when parked an easier option for the moment.
    The Older Gentleman, Apr 27, 2009
  11. Runk
    Schiffner Guest
    Agreed. I might get Raddak's rebuild kit and do mine, along with
    following his optimization procedures. It only gets 30mpg at sea level
    OR in the mountains a mile high plus. It can/should get around 40mpg
    in theory. Then again haven't I been considering this for years? Oh
    well it's running fine so what the heck.
    Schiffner, Apr 27, 2009
  12. An anthem for our times :))
  13. Runk
    Schiffner Guest
    Especially on vehicles that have NEVER had the carbs off! Oh sure the
    carbs have been balanced as needed but other than that, well those old
    Kehein's just keep on doing their jobs. 8^))
    Don't futz with it if it aint broke! A mantra for the ages.
    Schiffner, Apr 28, 2009
