Any pest experts in the house?
Discussion in 'UK Motorcycles' started by Pip Luscher, Mar 8, 2009.
  1. Pip Luscher
    We seem to have Starlings. Or maybe rats.
    Over the last year or so we've been hearing odd noises in the loft but
    had little in the way of visual evidence of wildlife. I did spot a
    bird between the felt and tiles a few months ago, but not in the loft
    itself. However, during the really cold weather we've had recently the
    noise has been much, much worse, though it has eased now that it's
    warmer. I finally got round to having a poke around today.
    There are lots of little black droppings scattered, mostly towards one
    end of the loft, and a couple of likely 'tunnels' in the insulation
    towards the eaves. There was also a section (about 18" square between
    joists) where the insulation had been /completely/ shredded and
    removed and piled against the end wall of the loft.
    Most fascinating were a line of three 'igloos' between two joists
    where the insulation had been humped up, each igloo having a single
    entrance hole. No obvious feathers, though.
    I suspect starlings, however, the droppings are dark and I thought
    that birds 'urinate' white droppings. The house is about 25 years old
    and detached, but possibly other mammals could get up there via ivy on
    the front of the house.
    Anyone know what the culprit is likely to be?
  2. Pip Luscher
    Simon Wilson Guest
    It's a squirrel, it's always a squirrel.
    Simon Wilson, Mar 8, 2009
  3. Squirrels.
    We've got 'em, too.
    The Older Gentleman, Mar 8, 2009
  4. Pip Luscher
    A.Lee Guest
    jpeg of the shit needed, with a match or something at the side to guage
    its size.
    Mouse, squirrel or rat. Probably mice if the poo is really small - apple
    pip size or smaller, something the size of a small jelly bean is a rat,
    dont know about squirrel shit, probably a bit bigger than a rat - jelly
    bean size?
    Bird shit is rarely in one piece, as they dont sleep/sit on the ground
    much, so it spreads out.Also, their nests will be flat, they dont build
    an 'igloo' type nest. Actually, they wont build any nest in the winter,
    they'll just perch somehwere sheltered.
    Alan.
    A.Lee, Mar 8, 2009
  5. Pip Luscher
    Eiron Guest
    Hippies. It's always hippies. Zyklon B is the best thing to get rid of them.
    Leave the light on and set up a video camera so you can see how they behave
    before getting rid of them.
    Eiron, Mar 8, 2009
  6. Pip Luscher
    Simon Wilson Guest
    ^^^^^ aaaargh
  7. Pip Luscher
    boots Guest
    +1
    If you've any nearby trees or branches crossing power/telephone cables
    then cut them back to make access more difficult. They are destructive
    and will chew through cables. Warfarin{sp} based rate poison will sort
    them out if they will take the bait otherwise you can get live traps
    and then kill them later. Watch out when killing the fuckers they can
    bite.
    boots, Mar 8, 2009
  8. Pip Luscher
    Simon Wilson Guest
    Oh yes they like to chew on the lighting cables etc.
    Little bazzards can run straight up the wall so it doesn't make much
    odds once they know their way in.
    Look from the inside of the loft during daylight for holes. Look from
    the outside for chewed holes in the soffit. Set poison and block all of
    the holes up. IME they know to stay out of the traps.
    Make sure your water tank is very very covered.
  9. Pip Luscher
    Pete Fisher Guest
    In communiqué <1iw9yis.cqt6ip513ep6N%>,
    Almost certainly.
    Our place used to trap them years ago. Until a member of the public
    found out how they despatched them to the great holt in the sky.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 8, 2009
  10. Pip Luscher
    Simon Wilson Guest
    Air rifle?
  11. Pip Luscher
    That'd be my weapon of choice.
    Squirrels are stupid and tend to follow the same route all the time so
    all you need to do is find that route then pop them with the good old
    ..22
    I used to regularly shoot squirrels where I lived in Northampton
    because it had a back garden that backed onto a spinney and the little
    fuckers used to jump from one tree to my fence then run along the
    fence and jump onto a different tree.
    80' was about the maximum range for a guaranteed kill but I had
    telescopic sights on the gun and could usually get them with a clean
    head shot if they paused anywhere along the route.
    Andy Bonwick, Mar 8, 2009
  12. Pip Luscher
    Shredder?
    platypus, Mar 8, 2009
  13. Pip Luscher
    gazz Guest
    we had a wild rat in the house a few months ago (I have pet fancy rats, so
    dont hate rats) we heard scuttling along the ceiling above the bedroom, too
    heavy to be a mouse but I was used the the lolloping sound a rat makes as it
    runs,
    I lifted a floor board above where we heard her, put a webcam with lights on
    it pointing along the joists, and a yogurt drop in front of the cam, (no
    rat can resist yoggie drops, wild or fancy, pets at home do em, the
    vitacraft ones are liked the best, my ratties turn their nose up at the
    crappy rotastack ones) ran the usb cable to the laptop running some motion
    detection software,
    Next day we had video of the rat, just one, a female but no signs of her
    being preggers (easy to tell if you know what to look for, easy enough to
    sex em on video too, males have balls the size of liquorish torpedoes
    dragging along behind them)
    I say that as males chew more than females, but of course the females can
    have between 6 and 18 kittens every 23 days, the young can breed at 4 weeks
    of age, and so the cycle starts.
    I found the place she got in, air brick then up to the ceiling tunneling
    through the cavity wall insulation, I scattered some of my pet rats shits
    about near the exit hole in the rafters, and she soon fucked off (rats can
    be territorial, so the smell of other rats in the area made her think better
    of making the attic home)
    Rats make some pretty elaborate nests, out of anything, but insulation is a
    favored material along with polystyrene, round internally with a small
    entrance hole,
    rat shit is black, will be rock hard 20 minutes after being laid, have no
    smell to it unless you find a still squidgy one and crush it, and be a bit
    like the inside of a liquorish torpedo, in size and shape, usually they will
    do a clump of 3 or 4 at once, they have a sort of holding pouch to store
    shits in so they can do them all in once place, as they like to use one spot
    as a toilet, but each rat might use a different spot,
    Their piss glows under ultraviolet light, reason for this is rats cant see
    reds, their sight is in the lower blue spectrum, so they can see their piss
    trails, but rats dont piss all the time like mice do to navigate,
    just mentioning this, as you could go up there with a black light, dunno if
    squiggles piss glows too tho.
    others know how to kill the rats, and have advised.
    gazz, Mar 8, 2009
  14. Pip Luscher
    Pete Fisher Guest
    Sack and stick. Used to be an approved DEFRA method, but I'm talking 20
    years ago. I *think* they advise the air rifle approach now.
    Our lot stopped doing squirrel control years ago.
  15. Pip Luscher
    Dan L Guest
    Rats
    I've had 'em too.
    Bastards
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    2002 Triumph Sprint RS 955i (It's big, and it's black)
    1996 Kawasaki ZR1100 Zephyr (Gone, but not forgotten)
    BOTAFOT #140 (KotL 2005/6/7/8)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 8, 2009
  16. Pip Luscher
    Rudy Lacchin Guest
    If you do catch anything in a 'humane' trap, kill the occupant by dropping
    the whole thing into a bucket of water. Don't let it out - you don't want
    to be bitten by a rat.
    Rudy Lacchin, Mar 8, 2009
  17. Angle grinder?
  18. Fuckin' *superb*.
    Only on ukrm would you get a posting like this: hi-tech surveillance of
    rats.
  19. Or even a wood chipper, assuming you refer to the little KLM incident.
    doetnietcomputeren, Mar 8, 2009
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, michael bothe
    Ees no' rat. Ees Siberian Hamster.
    Wicked Uncle Nigel, Mar 8, 2009
