Any pest experts in the house?
Discussion in 'UK Motorcycles' started by Pip Luscher, Mar 8, 2009.
  1. Pip Luscher
    boots Guest
    That's probably the easiest, although beating with a spade is as
    effective.
    boots, Mar 8, 2009
  2. Pip Luscher
    Yes, but all the reports I saw said "shredder".
    platypus, Mar 8, 2009
  3. Pip Luscher
    "Clicky-ba turn in my hand, Lord."
  4. Pip Luscher
    gazz Guest
    so you dangel you scrotum infront of his face, when he tries to make off
    with your nuts, you hit him over the head with your stick?
    gazz, Mar 8, 2009
  5. Pip Luscher
    <snip useful stuff>
    Hmm, thanks for the info. So far, I'm leaning more towards the
    squirrel theory. We do have a lot of grey squirrels round here. Also,
    the shit is scattered fairly uniformly at the far end of the loft, not
    really laid in clusters. It's a pity my little UV lamp died.
    The only way a rat could get up there would from the front of the
    house (unless they can climb brickwork or plastic gutter pipes) or
    between the walls (no obvious way into the loft space), whereas there
    seem to be clear access points both front and to the rear under the
    eaves.
  6. It's a rat with a good PR department.
    michael bothe, Mar 8, 2009
  7. Pip Luscher
    Worryingly, the exposed section had a lighting cable junction to one
    of the upstairs lights. I gave it a cursory look but didn't really
    examine it for chew marks.
    Expect a 'my house just burned down' post in the near future.
  8. Fucking commies.
  9. Pip Luscher
    Hankjam Guest
    I maybe wrong but as they are aliens, once you've trapped them, you
    have to kill them, you cannot let them go, so the law says...
    greys that is.... not the lovely red ones.
    Aj
    Hankjam, Mar 8, 2009
  10. Pip Luscher
    SP Guest
    Oh, I prefer to let the JR on them, much more entertainment.
    Lesley
    Residing in the Capital of Culture 2008
    CBR600FW
    Peugeot 206 S
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Mar 9, 2009
  11. Pip Luscher
    SP Guest
    Red or grey?
    Lesley
    CBR600FW
    Peugeot 206 S
    BONY#54P BOB#18
    SP, Mar 9, 2009
  12. Pip Luscher
    gazz Guest
    oh rats can climb walls, obviously not smooth ones, but brick walls are a
    piece of piss to them, i used to amaze people when i took one of my rats out
    on my shoulder in summer, I'd plonk him on a bit of brick wall and he'd just
    cling there as if he was velcroed to the bricks, which he was in effect, his
    nails dug into the pores in the bricks, then he'd climb down, bound across
    the pavement and up my trouser leg on the outside, negotiate the over hang
    of my belly when going up my jumper, then back onto my shoulder.
    A gutter pipe will be even easier, they push their backs against one side
    and scuttle up it (mine do that to get up behind dressing tables, wardrobes
    etc)
    if you have cavity walls, then they can easily get up inside them, the one
    that got in my house did that, clear evidence of where she exited by the
    fluffy insulation that had come out the top like a mole hill, makes you
    wonder how the **** they know they will pop out the other end.
    Rats can jump quite a distance too, but they dont often climb trees and leap
    from them, the can climb trees if they want to, they have short strong hairs
    on their tail that face downwards, so if they wrap their tail round a
    branch, it works like a one way ratchet type of thing, slides up but wont
    let them slide down unless they lift their tail off the branch.
    Buuuut, as you say, it may be squirrels, have you checked your water tank,
    as that's the usual place to find a squirrel, most people find them when
    it's body has shed all it's fur and blocked the outlet pipe tho,
    gazz, Mar 9, 2009
  13. Pip Luscher
    Tosspot Guest
    Pikeys.
    Tosspot, Mar 9, 2009
  14. African or European?
    The Older Gentleman, Mar 9, 2009
  15. Quite likely rats. It's very common for the bastards to get into loft
    spaces.
    Grimly Curmudgeon, Mar 9, 2009
  16. Pip Luscher
    Pete Fisher Guest
    Cue old joke about castrating camels using two bricks.
    "Does it hurt?"
    "Not unless you trap your thumbs between them."
    | Pete Fisher at Home: |
    Pete Fisher, Mar 9, 2009
  17. Pip Luscher
    Eiron Guest
    Ginge! we had that joke in Lozzo's magnet thread last month.
    Eiron, Mar 9, 2009
  18. Pip Luscher
    Pete Fisher Guest
    Did we? Probably didn't survive a 'mark all as read' purge.
  19. It's got a hazel nut in every bite.
  20. Pip Luscher
    No on Topic posts please!
    CT, Mar 9, 2009
