Anybody ever replace the winding in a generator rotor?
Discussion in 'Motorcycle Technical Discussion' started by Paul Barrett, Apr 25, 2008.
  1. Paul Barrett
    Paul Barrett Guest
    I have a 1980 CB750C with an open-circuit in the generator rotor.
    Before I go plunk down $160 for a rebuilt one, I was wondering if it's at
    all feasable to rebuild one myself.
    (I've got two, so even if I tear one up, I still have one for the
    core-charge if I buy one.)
    It looks like the hardest part would be getting it apart. I found the 4
    screws under the front surface, but I guess there's more holding it together
    than that.
    I hear it's supposed to end up around 4 Ohms. If it's 18ga. wire, that'd be
    about 700ft, which I'm guessing would be about 1000 turns, which could be
    sealed with epoxy.
    Thoughts anybody (yeah, I'm a cheapskate).
  2. Paul Barrett
    . Guest
    An eternally-broke acquaintance tried rewinding his Suzuki stator with
    transformer wire he bought from Radio Shack.
    Transformer wire is insulated with a reddish brown enamel that will
    not survive immersion in hot engine oil.
    Suzuki's supplier (Denso? Nippon Kogyo?) used some kind of wire that
    was insulated with a green plastic when winding
    their OEM stators...
    ., Apr 26, 2008
  3. Paul Barrett
    Paul Barrett Guest
    Would a stator typically be immersed in hot engine oil? This one's outside
    the seals & is dry.
    Paul Barrett, Apr 26, 2008
  4. Paul Barrett
    Ron Seiden Guest
    I've known people who wound their own coils for building electric guitars,
    so anything's possible...
    Ron Seiden, Apr 27, 2008
  5. Paul Barrett
    Paul Barrett Guest
    Oh well - I found a place that rebuilds them (if you send them a core first)
    for $79.
    Never did get the darned thing apart. I don't know if it requires a solvent
    or special puller or both.
    But for that price to get one rebuilt, it no longer seems worth trying it
    myself.
    Paul Barrett, Apr 27, 2008
