anyone flown this week?
Discussion in 'UK Motorcycles' started by Buzby, Aug 23, 2006.
  1. Buzby
    Buzby Guest
    How anal are they being about the size of hand baggage?
    Are they sticking exactly to the 45cm x 35cm x 16cm limit or am I going to
    get away with a slightly larger bag measuring 45cm x 30cm x 22cm
    Buzby, Aug 23, 2006
  2. Buzby
    I flew last Wednesday when they had started allowing som ehand
    baggage, but most people weren't taking anything more than a carrier
    bag's worth or a handbag. BA did have their baggage measuring wotsits
    all over the place though, so I suspect that anything vaguely large
    would have been forced to be fitted into it.
    Best thing, really, is to check it all in. Makes everyone's life
    easier.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Aug 23, 2006
  3. Buzby
    Buzby Guest
    Was it a hoop thing? - I've a floppy 'pilot' case which is only a slightly
    larger volume but 10cm wider and meaning I can get everything in with a bit
    of judicious packing. If not it's back to the laptop bag.
    I would - but it's a couple of grands worth of camera gear and a laptop, so
    the likelyhood of being reunited with it all present and correct at the
    other end is unlikely.
    Buzby, Aug 23, 2006
  4. Buzby
    No, it's a 3d rectangular frame into which the bag has to fit,
    effectively checking all three dimensions against a flat edge.
    That's probably the best idea. Of course, I don't know if they're
    actually using this, nor if they've applied this to other airlines.
    Best to check with your airport/airline first.
    Have faith. 99.n% of luggage gets through unmolested. I've frequently
    checked my laptop and other valuables through with no probs.
    _______
    Ace, Aug 23, 2006
  5. Buzby
    Cab Guest
    Yes. Three times so far. Once on Monday and twice on Tuesday. I had no
    problems/limits at all. From France, no liquids are allowed in hand
    baggage on flights to the UK, USA and Israel.
    Mind you, I wasn't anywhere near the UK.
    Cab, Aug 23, 2006
  6. Our company insurers aren't insuring laptops, buggrit. And I'm off to
    Ecuador on Monday.
    The Older Gentleman, Aug 23, 2006
  7. Buzby
    Ecuador on Monday.[/QUOTE]
    So if it's nicked they have to bear the loss themselves. What's the
    problem?
    _______
    Ace, Aug 23, 2006
  8. So if it's nicked they have to bear the loss themselves. What's the
    problem?[/QUOTE]
    Company's saying "You insure it yourself", unbelievably.
    NUJ is not impressed....
  9. Buzby
    Cab Guest
    Don't take it and tell work to stuff it.
    Cab, Aug 23, 2006
  10. Cab wrote
    Send it via a freight handler, like musicians are being told to do with
    their tools.
    steve auvache, Aug 23, 2006
  11. Buzby
    Beav Guest
    The wife flew to Sweden this (Wednesday) morning at 10;00am. No liquids in
    hand luggage (or mascara if you're so inclined). You can take laptops,
    phones and a whole slew of other electronic gizmo's though, but they're
    checked frst. You have to take your shoes of for them to be x-rayed too, bt
    it's all pretty much as it was apart from this "no liquids" thing.
    Manchester 'port had a cardboard box you put your hand baggage in. If it
    fits, it's Ok (apparently). A little squeezing should see it go in the box,
    but if you've got an analy retnentive twat on the counter, you could be
    bollocksed. Safer to go with the 45/35/16 size.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Aug 24, 2006
  12. Buzby
    Why do I occasionally get the impression that you're working for a right set
    of cunts?
    Funny that. Neither would I be.
    Timo Geusch, Aug 24, 2006
  13. No, it's mine.
    Company has a laptop for use when travelling. I prefer to use my own
    iBook because it's a better machine and it's customised to how I like
    it.
    The Older Gentleman, Aug 24, 2006
  14. Buzby
    Cab Guest
    Isn't the NUJ a closed shop?
    Cab, Aug 24, 2006
  15. Buzby
    Cab Guest
    Worrabout the NUS?
    Cab, Aug 24, 2006
  16. Buzby
    ginge Guest
    says...
    In that case they're completely right.
    Use theirs, or consider the situation your own problem.
    p.s. Boo-hoo-hoo.
    ginge, Aug 24, 2006
  17. Buzby
    Cab Guest
    FFS, give us the complete story then. You can't expect them to insure
    your own stuff, can you?
    Cab, Aug 24, 2006
  18. Well, that's it, basically. We have one crappoy company laptop for
    travellers.
    Lots of us have our own laptops.
    Some twonk in our Brussels office left a company laptop at a conference.
    Just forgot about it, and the insco has said: "That's it, no laptops
    covered on our insurance now."
  19. If I was robbed while on company business, and had my clothes and
    possessions stolen, I'd expect the company to cough. As, I suspect,
    would you.
    See other reply for why laptops aren't covered.
  20. No way.
