Arse! Carb Cleaner Ate My Rubber
Discussion in 'UK Motorcycles' started by Nigel Eaton, Nov 6, 2003.
  1. Nigel Eaton
    Nigel Eaton Guest
    Wynn's carb cleaner. Lovely stuff.
    Only, there's these little rubber diaphragms in the sides of the carbs.
    Or more accurately, there *were* these little rubber... :^(
    It's also slightly disconcerting that despite *completely* stripping the
    carbs there are five or six bits in the rebuild kit that have no obvious
    home. Heigh-ho...
  2. Nigel Eaton
    Wik Guest
    Are you sure it was just the Wynns doing it not just that the diaphragms
    were perished, anyway? I used to use loads of the stuff during my
    murrican car days and never had it do that to any of them.
    Again, from murrican car experience, particularly with Holley carbs,
    there'd be a lot of parts common to all their models in a range. Fer
    instance, the Holley Vacuum Secondary models and the Double-Pumpers were
    pretty much identical 'cept for the way the secondary flutterbys and jets
    were actuated. So, a 600cfm v/s and a 600cfm DP would likely share the
    same basic throttle-body.
    As a result, a rebuild kit would /always/ contain bits you didn't need;
    different or extra springs, different "squirters", gaskets and more.
    | Wik -UKRMHRC#10- 2000 ZX12R-A1 -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Nov 7, 2003
