Arse. My first crash.
Discussion in 'UK Motorcycles' started by Timo Geusch, Aug 9, 2004.
  1. Timo Geusch
    ArseFuckBolloxOuchCrunch.
    Going around the corner from the A12 onto the M11 sliproad/North
    Circular. I was a bit slower than usual, came around the corner and
    start thinking "Funny, this looks like Dieeeee....", the rear wheel
    spins up like mad[1] and the Pan goes into Speedway mode. I go foot
    down, manage to keep it from lowsiding. Of course, at this point the
    rear wheel grips again, the bike goes upright, thinks it's an NSR500,
    does a tank slapper and the next thing I know is that I'm sliding down
    the road on the side, watching the Pan pirouetting down the road
    thinking "Arse, this is going to get expensive". At the very least,
    the crash bar provided an entertaining shower of sparks that I could
    watch while we were both slowing down.
    Fortunately WhiteVanMan behind me had the good sense to stop a little
    bit down the road and use his van to block the lane. Thanks again mate
    for that, and helping me pick up the bike. Also, thanks to the cage
    dweller who stopped to check that I was OK and had a phone on me just
    in case.
    So after a short breather, I hopped back on the Pan and rode home,
    like, before the adrenalin wore off.
    The damage:
    To myself, a couple of bruises and a headache. Doesn't feel like a
    concussion, but I'll be off to bed in a few minutes just in
    case. Unsurprisingly, the left shoulder aches (I hit the road with the
    left side of the body), but no broken bones or open wounds.
    The clothing mostly survived OK as well, the waterproof overtrousers
    have a nice big hole in them, the MJK leather trousers show barely a
    trace of the damage that ripped the overtrousers, the jacket appears
    to be unmarked. The helmet, strangely enough, has a few
    marks that weren't there before. Not sure if I'll have to replace it,
    but it's probably a good idea. Oh, and the gloves are bin fodder, but
    I wasn't wearing the BKS due to the weather, so that's not that much
    of a loss.
    The bike looks surprisingly undamaged, as it was pirouetting down the
    road on the lhs indicator, crash bar and exhaust. Fortunately I didn't
    have the panniers on at the time. Damage appears to be confined to the
    crash bar and cover, lhs front indicator housing and the silencer, but
    that was looking shite anyway.
    Looks like I got lucky, the speedway bit must've slowed me down
    considerably, plus I didn't hit anything and didn't get run over,
    either. I'm glad I wore all the appropriate clothing, that would've
    been rather nasty without all the armour. If I had been a better rider
    I probably would've been able to prevent the crash, but that's a moot
    point now.
    Right, where's the Duck Tape, I need to fix up the damage on the
    bike.
    [1] However, I'd like to find out why the TCS didn't kick in - IMHO it
    should have when I hit the diesel as it was the typical "bike sliding
    because the back tyre is spinning a lot faster than the front", which
    AFAIK TCS should've picked up. Can anyone recommend a *good* Honda
    workshop in or around London who can check over the TCS as I'd like to
    prevent a repeat performance?
  2. Timo Geusch
    Oldbloke was seen penning the following ode to ... whatever:
    After my last experience with them I'll give them a miss, thanks.
  3. Timo Geusch
    Oldbloke Guest
    Timo Geusch wrote:
    <snip tale of woe>
    Glad you and the Pan are okay-ish
    Erm, HGB of Ruislip?
    <FX runs for cover>
    Dan L (Oldbloke)
    M'boy's current bike 1990 Suzuki TS50X (Heavily fortified)
    M'boys NEW bike 2003 Honda NSR125R
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Aug 9, 2004
  4. Timo Geusch
    'Hog Guest
    Snip tale of woe
    Oh dear, commiserations. Did you have a look at the road surface afterwards?
    This isn't just a new way to stop it working is it?
    I've never heard of a motorcycle skid pan school, MX being closest I
    suppose, but an interesting design is forming in my mind....
    'Hog, Aug 9, 2004
  5. Timo Geusch
    Molly Guest
    <snip experience>
    Tough luck mate, at least you're still alive.
    Good man.
    Molly, Aug 9, 2004
  6. Timo Geusch
    Linger Guest
    Fuuuuck, your luck is due for a change soon, its got to!
    Linger, Aug 9, 2004
  7. Timo Geusch
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Timo Geusch
    Oh you daft bugger.
    (Snip)
    A very good idea. Do it.
    Well, in the circumstances, my money's on "it's broken". But only
    because it's yours.
    Why not get yourself on a gravel car park and give it some? It'll either
    fishtail like a bastard (it's broken), or pull away (fairly) serenely
    accompanied by the engine doing odd stuff (it's not).
    Nigel Eaton, Aug 9, 2004
  8. Timo Geusch
    Stonge Guest
    Definitely do them, outriggers and the like.
    Stonge, Aug 9, 2004
  9. Timo Geusch wrote:
    Arse! GWS Timo.
    Easy to test - if the yellow light goes out it thinks it's working...
    As someone else said, gravel car park (or muddy field) and spin the
    rear up (over 5mph or else it doesn't work).
    I test mine on my trip home each night as there is a nice 'dished'
    roundabout off the A14 that I go straight across - the exit always
    gives me TWA with a satisfying flash of the yellow light as the back
    wheel leaves the ground.
    Attilla the Hungry, Aug 9, 2004
  10. Timo Geusch
    Andy Hewitt Guest
    My oh my, you dozy twit. A lucky escape there though, glad you're OK.
    Andy Hewitt, Aug 9, 2004
  11. Timo Geusch
    Nidge Guest
    Bastards
    I'd make it a mandatory penalty for the driver and the cnut that fills the
    tank to drinking 10% of the diesel they spill between 'em.
    Glad yer mostly OK Timo.
    Nidge
    ZX6R J2 Stunning in zit yellow. KX 125 MX 'I'm snot green -fly ME'. A few
    bits of CB500S in Norwegian Parrot blue. BOTAFOT#63
    'Just because I don't care doesn't mean I don't understand'.
    Homer (Simpson).
    Nidge, Aug 10, 2004
  12. Timo Geusch
    HooDooWitch Guest
    HooDooWitch, Aug 10, 2004
  13. Timo Geusch
    deadmail Guest
    I'd have said he was pretty lucky reading what the damage to the bike
    was.
    Oh. I'll refrain from comment here. Actually, that's bollocks I wont.
    If they really wanted to make a point they'd arrange a diesel spill on
    the day of their 'rally to westminster'. I'm sure that the voices are
    telling me to do it for them.
    deadmail, Aug 10, 2004
  14. Timo Geusch
    HooDooWitch Guest
    somehow managed to post:
    From what I've read of Timo in here, he actually needs his own
    category on the luck scale.
    You flash cnut. ;)
  15. Timo Geusch
    I don't think so. I'm amazed it's his first bike crash.
    Champ, Aug 10, 2004
  16. Did you actually check the bike for damage first?
    I've done similar on pushbikes, and ended up getting off
    a couple of hundred yards later to kick the handlebars
    straight, sort the brakes, etc.
    Good stuff.
    Lucky bugger.
    William Grainger, Aug 10, 2004
  17. Timo Geusch
    HooDooWitch Guest
    Perhaps that should have read "****, you're (un)lucky"?
  18. Timo Geusch
    deadmail Guest
    Be fair, he spends more time pushing than riding.
  19. Timo Geusch
    Cab Guest
    Timo Geusch bored us all completely to death with wittery prose along
    the lines of:
    Urk. Glad you're okay though.
    Cab :^) - almost as fast as G.i.n.g.e.
    GSX 1400 - 'Tarts Handbag' (tm) Bike, dead 550/4 Rat
    UKRMMA#10 (KoTL), IbW#015, Bob#4, POTM#3
    email addy : cab_at_ukrm_dot_org
    Cab, Aug 10, 2004
  20. Timo Geusch
    'Hog was seen penning the following ode to ... whatever:
    Well, it didn't bloody work. The Pan's still OK to ride...
    Timo Geusch, Aug 10, 2004
