Auto electrician required
Discussion in 'UK Motorcycles' started by Champ, Sep 24, 2009.
  1. Champ
    I've run in a little complication with my intention to fit my race
    ZX10R engine in my road bike.
    The race motor really needs the race ECU. The race ECU only works
    with the race loom (it plugs into the road one, but just doesn't
    work). The race loom doesn't have any connectors for lights,
    indicators, horn, etc.
    The only solution I can think of is to splice the road stuff into the
    race loom. Modern bike wiring looms are fearsome things, and it's a
    job that is definitely way beyond me. So, can anyone recommend an
    auto electrician who'd be up for such a job?
    Champ, Sep 24, 2009
  2. Champ
    Surely that's not beyond the capabilities of a certain ex-racer who
    might be near your house at the weekend?
    My weekend off has been a bit like the tide the way it's gone from one
    way to the other almost every hour but it now appears that I've
    guaranteed the time off by arranging an 'important' site visit half
    way home for 1pm. I know it's abuse of power but I honestly don't give
    a flying ****.
    Andy Bonwick, Sep 24, 2009
  3. Champ
    Nige Guest
    Have you got a schematic diagram of the loom for either ECU type bike? I'll
    bet you'll find they are very similar indeed with only minor mods, or maybe
    pins etc. I can help you easily if you have a diagram.
    Lights & things like indicators usually use relay logic to operate & dont
    have much to do with the engine ECU.
    As i say, if you have some diagrams i can probably sort the loom, but it
    will be more like sensors or pinouts that are different.
    You have my number.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 24, 2009
  4. Champ
    Yep, I've got diagrams for both looms.
    I know it's do-able. Just not by me...
    Champ, Sep 24, 2009
  5. Champ
    Nige Guest
    heh. Stuff like this is easy. Compare both diagrams to start with, there
    will be something very obvious. Or, it could be something as simple as a
    sensor not in the loom, or maybe it needs a shunt etc.
    feel free to ring to avoid costs :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Nige, Sep 24, 2009
  6. Champ
    First stop would surely be to ask the people who make the race ECU? It
    may be something as simple as the sidestand or clutch cutout switches
    need bypassing, or the immobiliser etc.
    Krusty, Sep 24, 2009
  7. Champ
    zymurgy Guest
    I think the same, there can't be a great deal of difference around the
    ECU wiring requirements.
    He has both wiring diagrams, so highlighting the differences in in the
    ECU wiring on the loom shouldn't be that hard ...
    Paul.
    zymurgy, Sep 24, 2009
  8. Champ
    I don't have a phone number for the Kawasaki race department, and even
    if I did my Japanese is limited.
    But you've got the nub of it, I suspect. It's not the sidestand, as
    the motor spins over (which it wouldn't with the stand down). But the
    road bike has an immobiliser - I'll bet it's something to do with
    that.
    I've been poring over the two wiring diagrams for the last hour trying
    to figure it out, and I've gone goggle-eyed. Time for bed.
    Champ, Sep 24, 2009
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Didn't the Team UKRM 750 need a resistor appropriately inserted before
    it would play ball?
    A similar thing, perhaps?
    go and talk to the Catholics.
    Wicked Uncle Nigel, Sep 24, 2009
  10. Champ
    Ah right, it's a proper posh one.
    Do they have that horrible system where the ECU has to match the coded
    ignition key? If so, I'll bet that's the problem. If the race bike's
    got an ignition, you probably just need to swap that over. If not, the
    ignition feeds to/from the ECU are probably the bits to concentrate on.
    Feel free to bung them over if they're emailable. I did some fairly
    major loom chopping on RatTig & the Corvette so have a bit of
    experience in such nightmares.
    Krusty, Sep 25, 2009
  11. Champ
    Alex Ferrier Guest
    'cept, if they still do it. It'll be arse about face this time around.
    Instead of trying to graft a road ECU into a race loom. It's grafting
    a race ECU onto a road loom. Which probably means the fake 12V feed
    will need grafting to a real 12V feed.
    Alex Ferrier, Sep 25, 2009
  12. Champ
    You mean putting a Ferrier in the saddle didn't provide enough impedance?
    wessie, Sep 25, 2009
  13. Champ
    A little light bulb went on above my heard when I recalled that, about
    an hour ago.
    Similar, but much, *much* more complicated.
    Champ, Sep 25, 2009
  14. Champ
    Yes.
    There's a thing called the 'immobilizer antenna' by the ignition
    switch, which (amongst other things) feeds an 'immobilizer amplifier'.
    In short, the key and the ECU are matched. There's a few people tried
    to put ZX10R engines in kit cars & sidecars without the original
    ignition key, and run into this problem.
    Which depressed me, until I realised that I have the opposite problem
    - I have an ECI that doesn't care about the ignition key at all. But,
    immobilizer will be expecting some sort of 'go' signal out of the ECU
    before it allows the fuel pump (and perhaps some other stuff) to run.
    The fuel pump not priming when I had the kit ECU plugged in is a big
    clue.
    So I *think* I just need to figure out how to bypass the immobilizer.
    They're big, but I'll try and send you something.
    Champ, Sep 25, 2009
  15. Champ
    zymurgy Guest
    Ah, the looms and ECU's i've worked with recently were pre-HISS days,
    thank god.
    Paul.
    zymurgy, Sep 25, 2009
  16. Champ
    crn Guest
    Why make life so bloody complicated.
    You have a race loom and ECU, which includes all of the ignition gubbins.
    Fit them and forget about them.
    Now you want some lights and a horn.
    Grab a roll of wire, some tape and some connectors.
    Any light and horn switches that will fit the bars will be good enough.
    How difficult can it be ?
    crn, Sep 25, 2009
  17. Ah, the mantra that accompanies any ukrm project or undertaking :)))
    The Older Gentleman, Sep 25, 2009
  18. Champ
    Try thinking about what a *modern* superbike has that a race bike
    doesn't[1]. There's a lot more than 'some lights and a horn' involved,
    & building a loom from scratch that's both reliable & fits in the very
    limited space would not be easy. It wouldn't get around the immobiliser
    problem either.
    [1] Neutral, fuel, oil, battery, temp & indicator warning lights,
    clutch & sidestand switches, fan switch, speedo sensor, possibly
    barometric & O2 sensors to name a few - all of which /could/ be
    controlled through circuitry in the ECU that isn't present in the race
    one.
  19. Champ
    crn Guest
    If you put a race bike together with all of the race bike bits and ONLY
    race bike bits it should just work. No immobiliser and nothing that
    depends on having one.
    How many of these extras do you need to make a bike road legal ?.
    What is the objective ?. A road legal race bike or a complete road Kwak
    with a race engine ?.
    A problem simplified is a problem solved.
    crn, Sep 25, 2009
  20. Champ
    Yes, which is completely irrelevant.
    It's not just about making it legal, it's about making it work & usable
    reliably as an everyday bike.
    Knowing Champ's usage, I'd say almost certainly the latter.
