B12 Rear Light Bulbs.
Discussion in 'UK Motorcycles' started by toad, Aug 23, 2007.
  1. toad
    toad Guest
    The bulbs in my rear light (IIRC: 12v 21/5W) seem to blow very
    frequently.
    I understand this is a common problem due to vibration.
    Can anyone recomend a suitable bulb that's more resistant to vibration
    or any other practical solution.
    toad, Aug 23, 2007
  2. toad
    TOG Guest
    Have a hunt here:
    http://www.superbrightleds.com/1157.htm
    TOG, Aug 23, 2007
  3. toad
    toad Guest
    toad, Aug 23, 2007
  4. toad
    Not to mention that the vibes were bad enough to fatigue and snap
    soldered connections - I can't see anyhting lasting forever under that
    sort of duress.
    Pip, Aug 23, 2007
  5. Although IME LED's still suffer in the back of B12's, however they do so
    far less frequently.
    YMMV.
    doetnietcomputeren, Aug 23, 2007
  6. The OP could do well to experiment with rubber/foam mounting the light
    unit if there's room.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, Aug 23, 2007
  7. toad
    haket2000 Guest
    I had the same issue with my B12, in the end I sawed off the back of
    the light unit and made my own strip light of LEDs and a few
    resistors. Problem solved.
    MARK
    haket2000, Aug 23, 2007
  8. toad
    I use a red oil lamp nicked from a passing guard's van, gimballed off
    the Renntec rack.
    Pip, Aug 23, 2007
  9. Let off some of the preload.
    steve auvache, Aug 23, 2007
  10. Do you use Esso Blue in it, though? Might cause a purple light.
    GS850x2 XS650 SE6a
  11. toad
    Of course not, you silly boy. That would constitute a hazard to
    navigation. I always use recently-rendered bio-oil, distilled from
    yokel moleskin squeezings and old chip fat.
    #Clear red light ....
    Pip, Aug 23, 2007
    Dr Ivan D. Reid, Aug 23, 2007
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    #ROOOOOOOOOOOOOOOxanne...
    Honda GL1000K2 (Fallen apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Suzuki TS250 "The Africa Single" Honda ST1100 wiv trailer Norton 850 Commando
    Kawasaki GTR1400
    Wicked Uncle Nigel, Aug 23, 2007
  14. Some rear light units dance about alarmingly, unknown to the owners. I
    recall being behind a boxer twin at the lights some time ago and the
    rear light unit on that was bouncing around like a demented crossroads
    dancer freshly escaped from RiverDance.
    Since I was riding a boxer twin myself and was suffering more than the
    normal plague of blown rears, I took notice and rubber-mounted my own
    unit. Easy done, as you say.
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Aug 24, 2007
  15. toad
    I didn't know BSA made a B12, is it similar to an A10?
    sweller, Aug 27, 2007
  16. toad
