Back home from Fiji
Discussion in 'Australian Motorcycles' started by BT Humble, Mar 28, 2006.
  1. BT Humble
  2. BT Humble
    atec77 Guest
    atec77, Mar 28, 2006
  3. BT Humble
    GB Guest
    Yeah! Someone's gotta find what's causing that and stop it!
    He'll make the rest of us look bad!
    What he said!
    GB
    GB, Mar 28, 2006
  4. BT Humble
    Marty H Guest
    Marty H, Mar 28, 2006
  5. BT Humble
    I had a good long rest when I got back to Suva. ;-)
  6. BT Humble
    G-S Guest
    Great Photos BT!
    And good job with the mast... reminds me of putting up radio masts from
    local bits and pieces in remote areas :)
    Looks like a fun (if busy) trip.
    G-S
    G-S, Mar 28, 2006
  7. BT Humble
    Cheer up Atec! Remember:
    Some things in life are bad
    they can really make you mad
    other things just make you swear and curse.
    When you're chewing on life's gristle,
    don't grumble, give a whistle!
    And this'll help things turn out for the best.
    And...
    (All together now!)
  8. BT Humble
    atec77 Guest
    Spose you wanna "hang about " as well ?
    Incidentally where did you get the Genny from ?
    might just be a solution for a problem our wireless club has .
    atec77, Mar 29, 2006
  9. BT Humble
    Oatley Electronics stock them: http://www.oatleyelectronics.com
    Also Jaycar: http://www.jaycar.com.au
    And there are a few sellers of the same unit on Ebay.
    They cost about $450 now, and the kit is fairly complete. The one I
    used for testing had either a defective or poorly designed charge
    controller though. The Oatley 200W machine looks like a better one for
    real world use (ie. low winds most of the time) IMHO.
    Solar is better though, if you can afford it. Much lower maintenance,
    and no moving parts.
    BT Humble, Mar 29, 2006
  10. BT Humble
    That sentence makes a lot more sense if you know that, before I left
    for Fiji, Oatley were also selling a 400W turbine with a smaller
    diameter rotor (ie. it was better in high winds, not so good in low
    winds).
  11. BT Humble
    atec77 Guest
    Thanks , 200 watts should keep our 3 band repeater working ok , solar
    sometimes can be better but this is a group of Hams , do you understand
    tight like a fishes arse ? :)I have the controller all built so will
    investigate a suitable Genny
  12. BT Humble
    atec77 Guest
    We have a 70 cm on Mt Tambourine (438.50 irlp), the 2 meter was up and
    is down again but we snagged a 75 watt Motorola and the 6 meters is here
    on the bench ( 45 glorious watts), sadly the current location doesn't
    allow much room so we are looking at two sites , one in the Beaudesert
    Shire without power but council land and free with good access 10 k from
    here and the other is a commercial site on Tambourine so of course we
    would prefer the free one as its to service Logan West
  13. BT Humble
    The other thing to remember is that it takes quite a stiff breeze to
    give you a genuine 200 watts output - you really do need a good site.
    In Australia at least, solar is more reliable (especially in the
    summer, when it's usually not so windy).
    Is the site remote and/or unattended? Security can be an issue too.
  14. BT Humble
    atec77 Guest
    In the middle of private property on a decent rise , unless we can get
    some free panels that wont happen ,
  15. BT Humble
    No hand-cranked "grinding" then?
    Knobdoodle, Mar 29, 2006
  16. BT Humble
    My disturbingly-strong right arm got quite a workout cranking that
    grindstone.
  17. BT Humble
    It's probably worth a try then. The $399 that they cost (Oatley has
    them on special) is probably less than it would cost to hire a logging
    anemometer to test your site.
  18. In aus.motorcycles on 29 Mar 2006 12:18:08 -0800
    Paging Big Iain to the Emergency Booth Joke Area.
    Zebee
    Zebee Johnstone, Mar 29, 2006
  19. BT Humble
    stuart t Guest
    For some time, I was too afraid to click the link, images of BT half
    nekkid (or worse, a sarong) on some idyllic tropical beach sprung to
    mind.
    I was alsmost dissapointed when I did open it, you worldly chappie,
    hope you get as much out of it as the Fijians do.
    Stu
    stuart t, Mar 29, 2006
  20. BT Humble
    He won't touch that one, I've made it too obvious. Pat should be along
    shortly though.
    (With the massive, powerful right arm and the pathetic, wimpy left one.
    It's from tenpin bowling, honest!)
    BT Humble, Mar 30, 2006
