Back we go again...
Discussion in 'UK Motorcycles' started by JackH, Feb 3, 2010.
  1. JackH
    JackH Guest
    Got the GSX back from 'the shop' yesterday evening.
    Lovely it was - nice crisp throttle response etc.
    Decided in view of this to go 'the scenic way' home.
    About 20 miles later, I can feel a slight misfire at lower revs, which
    differed from the original problem as it had been misfiring all the
    way up the rev range.
    Get home, get off, get a strong waft of raw petrol up my nose, and
    further investigation reveals fuel absolutely pissing out of carb 2.
    *sigh*
    At this rate Bonwick will be getting a free *OSM...
    JackH, Feb 3, 2010
  2. JackH
    TOG@Toil Guest
    On a positive note, I reckon I've got the carburetion just about
    sorted on the GN. After cleaning out the carb passageways, I had to
    reset the mixture setting. Trouble is, the mixture screw, instead of
    being in the side of the carb, screws down vertically, just forward of
    the slide chamber. So you need to take the tank off to access it. As
    carb adjustment has to be done with a hot engine, it's been a matter
    of arriving home from work, whipping off seat and tank (I've got that
    task down to about 45 seconds now), twiddle the mixture screw, replace
    tank and seat, quick run round the block, back home, remove seat and
    tank, another twiddle, repeat ad nauseam.
    Anyway, got it sorted now. It definitely doesn't like cold weather,
    though, and I'm wondering about carb icing. Oddly, there's a guy on an
    X-reg Suzuki 400cc dirt bike on my commute, and at the lights
    yesterday he was reachng down and fiddling ith the tickover screw.
    "Doesn't like this weather," he muttered. "Keeps stalling..."
    Anyway, a tenner a week on petrol is now my commuting cost, compared
    with a tenner a day last year, so I'm happy.
    TOG@Toil, Feb 3, 2010
  3. JackH
    Simon Wilson Guest
    TOG@Toil wrote:
    Does it really do 85mpg? Impressed if so.
    Simon Wilson, Feb 3, 2010
  4. JackH
    TOG@Toil Guest
    Nope. Checked the first tankful at 72mpg. Checked the last one at
    66mpg, but that included much faffing about with carb. Twenty-eight
    miles a day, so 140-odd miles a week at about a fiver a gallon.
    As opposed to 80 miles a day on a much bigger bike, or in the car.
  5. JackH
    crn Guest
    Wots wrong with a few feet of pipe and sit the tank on the seat to twiddle ?.
    Or am I being whoooshed ?.
    crn, Feb 3, 2010
  6. JackH
    TOG@Toil Guest
    You did read the bit about a quick run round the block, didn't you?
  7. JackH
    'Hog Guest
    Excuse me butting in but I used to have a bit of fuel tube pushed into a bit
    of bigger tube wiv a cork anna hole specifically for riding round the block
    wiv the tank off guvnor. For a Tame Spanner it's a rather good idea.
    'Course it only works on Airheads and SOB's, cable tying a K fuel pump to my
    leg proved impractical.
    'Hog, Feb 3, 2010
  8. JackH
    TOG@Toil Guest
    That'd work. The 400 Four, for some reason, will run for bloody
    *miles* with the tank off. Balancing the carbs doesn't require a
    separate fuel supply at all. I have, however, blatted a tankless bike
    around only to discover when I got back that I'd lost both front tank
    rubbers :-/
  9. JackH
    JackH Guest
    Good good. :)
    The nice man from the AA got to the bottom of what's up with the GSX as
    well.
    The return feed pipe which runs from near the bottom of the main body of the
    carb to the top where fuel then shuts a valve on the top rail once the
    pressure has built up, has broken off.
    He also said the reason it pulled through and the missing cleared on the
    road at higher revs, is because the bike was drawing enough mixture to limit
    the flooding, where as tickling along at lower revs was allowing the flow to
    overtake demand, and that's why it was pissing out as if someone had turned
    on a tap, on idle.
    Net result is a completely fucked carb and Suzuki want nigh on £600 for
    *one*.
    So it's a good job I spotted a set of partially dismantled carbs on eBay
    earlier in the week - £30 delivered is what has just been agreed, and the
    nice chaps at the bike shop where the bike now sits festering have agreed a
    'you've bought the bits, we'll supply the labour FOC as it was quite
    possibly our fault as to why said pipe broke', arrangement. :)
    All being well, I may get to ride the fucking thing without any more aggro
    for a while once it comes back.
    JackH, Feb 3, 2010
  10. JackH
    TOG@Toil Guest
    Was it pissing fuel before? If not, then they *definitely* broke it. I
    imagine it's very easy to do if you (for example) try and replace the
    float bowl the wrong way round. You've got to be very delicate-handed
    when faffing with carbs.
  11. JackH
    TOG@Toil Guest
    I was assuming he was. Also, there's no pressure as such in a carb-fed
    system. The float bowl just fills, the float rises, and shuts off the
    fuel supply, exactly like a lavatory ballcock.
  12. JackH
    crn Guest
    Indeed, it is usually possible to throw the tank and seat back on
    without fixing to get the run around the block, do another twiddle, etc.
    Saves a lot of spanner time if you can.
    crn, Feb 3, 2010
  13. JackH
    TOG@Toil Guest
    Yes, I was doing just that. Still an arse-ache.
  14. JackH
    JackH Guest
    According the nice AA chappie and the guys at the bike shop, there is
    when the carbs are fed by an electric pump rather than simply gravity,
    as is the case with the GSX.
    Chaps in the bike shop also reckoned that when you've got a leak as
    this had, the fuel pump pumps a bit harder because it thinks 'need a
    higher rate as no back pressure = system not full yet'.
    Maybe, maybe not.
    Aye, it's that kind of principal.
    JackH, Feb 3, 2010
  15. JackH
    JackH Guest
    JackH, Feb 3, 2010
  16. JackH
    If it's got a vacuum tap check that.
    sweller, Feb 3, 2010
  17. JackH
    JackH Guest
    I suspect this is the case, but given they're jolly decent chaps
    who've A: never fecked one of mine up before, and B: didn't try to get
    out of fixing it, I'm of the opinion that 'shit happens', rather than
    'string them up!'. :)
    One of the reasons I put it in to be looked at this time, is because
    it's an utter shit to get the carbs in and out of... and the AA guy
    reckoned they may have inadvertently done the damage when trying to
    prise the carbs off the inlet rubbers.
    Tis a good job I love the old girl, else it would be winging its way
    onto eBay by now, all the grief I've had with it.
    Anyway... main thing is, all being well it should now be reliable for
    the summer. :)
    JackH, Feb 3, 2010
  18. JackH
    Tell you what, though - going for a "quick run around the block"
    sitting on a cushion across the frame, with a 2-litre plastic lemonade
    bottle (with the bottom cut off) inverted, filled with petrol and
    connected to the carb inlet with a short piece of petrol pipe is ...
    interesting. Not to mention of dubious legality.
    It also really brings home the speed with which a big-engined bike will
    suck and snort its way through a litre of fuel - right before your very
    eyes, as it were.
    Pip, Feb 3, 2010
  19. JackH
    TOG@Toil Guest
    Fairy nuff.
    I really, really, really doubt that. To break something *inside* the
    carb, you've got to break *into* the carb. Just levering against it
    won't do that.
    Also ruminating about whether fuel pump pressurises bike carbs. My
    belief is that it doesn't, but ICBW. I also doubt the "pumps a bit
    harder" story, but again ICBW. My understanding is that the pup fills
    the carbs, and when full, the pump doesn't stop, but simply redirects
    the excess fuel back into the tank.
  20. JackH
    JackH Guest
    The pipe runs up the outside of the carb... ;-)
    I'll post a pic up later when I get the pics off my phone.
    Am just going by what the AA chap said - he seemed to know his onions,
    that's for sure.
    JackH, Feb 3, 2010
