Baffled and bothered!
Discussion in 'UK Motorcycles' started by TMack, Aug 26, 2005.
  1. TMack
    TMack Guest
    I have aquired a Gilera Coguar for my daughter to run around on (I know its
    crap but it was very cheap and with only 600 miles on the clock). It has
    the Honda 125cc OHC engine used in many 125cc bikes. It starts, runs well,
    stops and generally does everything that it should. However, it will NOT
    idle properly. I have adjusted the pilot fuel/air mixture to optimum and
    then set the idle speed to a reasonable tickover (engine at normal running
    temp). Then I can stand back and listen - it ticks over happily for a while
    and then for no apparent reason it speeds up to a very fast idle, then it
    may or may not slow down again - if it slows it may well spontaneously speed
    up again etc. I have stripped and cleaned the carb twice and there do not
    seem to be any blockages. I have tested for an air leak by blowing Holts
    "cold start" over exterior of the manifold and carb with no apparent effect.
    The throttle cable seems to move quite freely. As it is a very low mileage
    bike the carb is unlikely to be worn. My son has a honda 125 with exactly
    the same engine/carb combination and it idles perfectly so this is not
    likely to be a case of "they all do that sir". What am I missing here?
    TMack, Aug 26, 2005
  2. TMack
    Does the problem move to your son's bike if you swap the carbs?
    Krusty, Aug 26, 2005
  3. TMack
    Dan L Guest
    No you haven't, you have acquired a Gilera Cougar, thats "Coo-gar" like the
    mountain lion, not "Cog-you-ar" like a Jag with a manual gearbox.
    A clue
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Aug 26, 2005
  4. TMack
    Badger Guest
    **** me, someone *is* in a foul mood tonight! ;)
    Badger, Aug 26, 2005
  5. In uk.rec.motorcycles, Badger amazed us all with this pearl of wisdom:
    FFS, it's not like any keeps anything valuable in briefcase anyway, is
    it?
    Whinging Courier, Aug 26, 2005
  6. TMack
    TMack Guest
    Listen here, shit for brains - it is a Gilera COGUAR. Thats what it says on
    the bike, thats what it says on the handbook, thats what Gilera named it.
    Go Google it if you have any doubts. Check your facts before you post you
    **** - (thats "****" like a **** - not "cant" or "count").
    Tony
    TMack, Aug 26, 2005
  7. TMack
    TMack says...
    He's right you know. It took me by surprise too when I first saw one.
    Lozzo, Aug 26, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, TMack
    <Hands Dan a large "You still spelt 'acquired' wrong" shovel>
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Aug 26, 2005
  9. TMack
    Dan L Guest
    In my defence, I was very pissed off last night, and decided to socialise
    with Ron [1] and Charlie [2][3].
    However, having now googled I have found references to both names.
    Unfortunately there do not seem to be any close up pictures of the bike on
    the web (that I can find anyway), to verify one way or t'other.
    My conclusions are thus:
    a) Gilera's marketeers are dyslexic, or
    b) Gilera's customers are dyslexic
    c) If it isn't, it ought to be called a Cougar (what the **** is a Coguar
    FFS)
    d) Who gives a shit, sell it and buy a proper bike.
    [1] Bacardi
    [2] Coke (Diet)
    [3] On reflection, not a wise choice of company.
    Dan L (Oldbloke)
    Dan L, Aug 27, 2005
  10. TMack
    TMack Guest
    SNIP!
    http://www.bikepics.com/pictures/216169/ look closely at the side panel.
    Now if this kind of thing happens again I'm going to have to find your car,
    break a window and nick your briefcase.
    Tony
    TMack, Aug 27, 2005
  11. TMack
    Dan L Guest
    It's a fair cop, you got me bang to rights guv'nor.
    TBH I sort of knew once I started to google, but when have the facts ever
    got in the way of a good flaming on UKRM..
    Having realised my error I did try to find out about your problem with the
    bike to try and redeem myself. All I found were testaments from other
    owners saying the bike is a POS, so my last point 4. stands.
    Heh, cnut ;)
    Dan L (Oldbloke)
    Dan L, Aug 27, 2005
