Bandit 1200 - Snot oiller.
Discussion in 'UK Motorcycles' started by toad_oftoadhall, May 16, 2006.
  1. Are the threads in the back of the carbs (ususally for carb balancing)
    that you 'plug' the 'suck tube' from the snot oiler into 6mm jobbies?
    Please excuse lack of English skills and vocab in this post!
  2. toad_oftoadhall
    Moon Badger Guest
    Yup. Use the balance points for the vacuum pickup.
    Moon Badger, May 16, 2006
  3. toad_oftoadhall
    Look at the Scottoiler website, ffs.
    "All Bandit 1200's and all post 2000
    600's: There is a vacuum pipe from the
    RHS of the right hand carburetor going
    to the fuel tap on the LHS of the bike, as
    shown in the third picture.
    Cut into this pipe and insert the T-Piece
    from the Scottoiler Kit. Then press the
    Damper Elbow, part number 4, onto the
    third leg of the tee."
    That would infer that no interference with the plugs is required,
    rather using the standard technique of cutting into the vacuum pipe
    and teeing off it.
    SOP for you.
    Pip, May 16, 2006
  4. Ta.
    Now, about that threaded 'plug'. 6mm is it? [1]
    [1] I'd rather unscrew than cut.
  5. toad_oftoadhall
    No it bloody well wouldn't. You may infer, the article can only
    imply.
    You really should know better.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 16, 2006
  6. That's what I'm planning to do. Are they 6mm?
  7. toad_oftoadhall
    You're right, of course.
    Yes dear.
    Pip, May 16, 2006
  8. toad_oftoadhall
    Fucked if I know. Go and measure it.
    Why?
    Pip, May 16, 2006
  9. Yup. Looks like that's what I'll be doing.
    1) When I sell the bike I'll keep the snotoiler and will have to bother
    go out and buy/order/wait for a fual tap vacuum tube.
    2) I'd need order and wait for the t piece whereas I already have a 6mm
    fitting.
    3) Cutting and joinging _feels_ like a bodge to me.
    4) The 6mm fitting will save me a _small_ amount of time balancing the
    carbs.
    Hardly an overwhelmingly compelling case, but it's my bike. YMMV.
  10. toad_oftoadhall
    1. There should be a pipe joining piece in the Scottoiler kit, for
    re-joining purposes.
    2. There should be a T-piece in the Scottoiler kit.
    3. Standard way of connecting.
    4. Can't see that, really.
    Off you go, then.
    Pip, May 16, 2006
  11. toad_oftoadhall
    Moon Badger Guest
    Dunno, never owned a Bandit.
    You can cut the vacuum take-off pipe going to the fuel tap and insert the
    T-piece then the thingy that goes to the feed unit, or use the vacuum
    take-off points for carb balancing. IIRC, Scottoiler supply the brass
    widget that screws in to the take off if stubs aren't already fitted.
    Personally, I'd rather use that than cut, but I had to cut'n'shut on my
    Transalp as both take-offs are in use already. Not had a problem in the
    19,000 miles since I fitted it.
    It doesn't matter which way you choose to do it, just follow the
    instructions for the rest of it and enjoy a permanently dry looking yet
    adequately lubed chain.
    12,000 miles and only had to adjust the chain once. It got through two
    chains ( one, the original, lasted 5,000 miles, which I thought was shyte.
    Its replacement lasted 7,000 with the Scottoiler. In defence of the second
    chain, it cost £12 and was non O-ring )
  12. The Snotoiler is off my previous bike and has neither.
    Well I was finding it harder to think of good reasons by the time I got
    down to 3 & 4.
    Ta.
  13. toad_oftoadhall
    someone here Guest
    Contact through the website and they can post you a selection of these
    small parts for very little money.
    Or if you can get to an autojumble, they are often rattling around in small
    plastic containers.
    someone here, May 16, 2006
  14. toad_oftoadhall
    Fr Jack Guest
    I yanked the cover off the ickle pipe you attach carb balancers to and
    used the standard pipe...works fine and no carb probs.
    Cheers!
    Fr Jack
    B12S POTENTIAL LICENCE SHREDDER - AT GRIN FACTOR 10!
    FRJACKUKRM AT GMAIL DOT COM
    Fr Jack, May 16, 2006
  15. toad_oftoadhall
    Beav Guest
    Will you ****. Get a joiner piece which is just like the "T" piece but
    missing the third leg. Available from all good DIY places for about tuppence
    apeice.
    Get a "T" piece from the same shop as the inline joiner. Only another
    tuppence my son.
    It's only a vacuum. So long as it's tight, it's not a bodge.
    You can hook up the T" pice to a vac tube in about 2 seconds.
    Indeed.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 16, 2006
  16. Go down to the nearest aquarium shop and get one of each for tuppence
    ha'penny.
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, May 16, 2006
