Bandit air filter
Discussion in 'UK Motorcycles' started by DR, Jun 8, 2006.
  1. DR
    DR Guest
    Is it a difficult job to change the air filter on a (K3) Bandit 12?
    Only I did the Hein Gericke £25 deal last weekend, and it would be a
    shame not to.
    DR, Jun 8, 2006
  2. DR
    SP Guest
    I can't see how it could be a difficult job, myself. I could be wrong
    mind, not having (a) the bike and model in question, and (b) the HBOL
    to refer to.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Jun 8, 2006
  3. DR
    SP said...
    The filter on my 600 was a shitbag to do. I suppose I should have taken
    the tank off completely, rather than prop it up with a sawn off bit of
    log, thereby stretching the hoses, one of which came off at the carb
    end. That took almost 2 hours to put back on, for which I had to remove
    the fucking tank anyway.
    Put it all back together then remembered I'd forgotten to secure the
    filter box lid properly, so it all had to come apart again.
    I'll just take the tank off and not try to cut corners next time, if I
    don't kill it first.
    Lozzo, Jun 8, 2006
  4. DR
    Eiron Guest
    It's a Suzuki. How difficult can it be?
    (I'm being ironic.)
    Eiron, Jun 8, 2006
  5. DR
    zymurgy Guest
    <kicks self>
    Adie, do you still need that Air Filter ?
    P.
    zymurgy, Jun 8, 2006
  6. DR
    SP Guest
    Ah well, I've always fully removed the tank anyway. After all, it
    doesn't put a lot of extra time onto the job. And it gives you a
    chance to check any pipes that are routed through there, including the
    wiring.
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jun 8, 2006
  7. DR
    SP Guest
    Well, it wasn't difficult on my GSXR-750L, but you know how the Japs
    like to make things awkward.. ;o)
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Jun 8, 2006
  8. DR
    Fr Jack Guest
    Take the tank off - piss easy, after that.. ;-)
    And waaaaaaaaaay easier than doing the same on the Tiger.....
    Cheers!
    Fr Jack
    B12S POTENTIAL LICENCE SHREDDER - AT GRIN FACTOR 10!
    FRJACKUKRM AT GMAIL DOT COM
    Fr Jack, Jun 9, 2006
  9. Easier than on a Trophy 1200. On that bike, the carbs have to come off.
    The Older Gentleman, Jun 9, 2006
  10. DR
    Eiron Guest
    It was an 1100L I was thinking of, and the 750 is virtually identical.
    Getting the seat off is easy, as is the rear bodywork.
    Removing the battery is a doddle.
    The battery carrier is topologically impossible to remove unless you keep your
    bike in a non-Euclidian space.
    The filter is not so bad if you have the right length screwdriver and small hands
    but still a struggle to get it past the wiring loom.
    During manufacture the carbs and airbox are fitted to the engine
    then the whole lot is put into the frame. I doubt that maintenance was
    ever considered.
    Eiron, Jun 9, 2006
  11. DR
    Adie Guest
    will it fit a 12 if so then yes. if not then donate to the current
    owner of the B6.
    Adie
    Triumph 955iSS (going) / ZX9R / GSF1200 bandit / CG125
    keeper of the FAQ for my sins
    Adie, Jun 10, 2006
  12. DR
    zymurgy Guest
    Ok, i'll pop it up, so to speak.
    Cheers
    Paul.
    zymurgy, Jun 10, 2006
