Bandit brake bleeding
Discussion in 'UK Motorcycles' started by Kevin Stone, Mar 1, 2008.
  1. Kevin Stone
    Kevin Stone Guest
    Hi,
    What's the FOAK's tips and tricks on overhauling the front master cylinder
    and then bleeding the system.
    The brakes are very notchy (still) and spraying brake cleaner around the
    master cylinder temporarily relieves it (about a week).
    What would a dealer charge to do this (I've not a lot of spare time)?
    TIA
  2. Kevin Stone
    Grease the lever pivot point. You've washed all the grease out of it
    and that's why it's notchy.
    Lozzo, Mar 1, 2008
  3. Kevin Stone
    Dave Emerson Guest
    If you were operating the brake when you sprayed "around the master
    cylinder" you may also have sucked brake cleaner into the top of the
    reservoir via the breather hole.
    Brake cleaner is for cleaning the disc, pads and around the calipers.
    Dave Emerson, Mar 2, 2008
