Bathurst 1000
Discussion in 'Australian Motorcycles' started by Bernd Rosemeier, Oct 6, 2009.
  1. Bernd Rosemeier
    Toosmoky Guest
    http://www.triumphtorque.com/ (formerly T595.net)
    Sounds a bit like an Urban Legend. Mine is one of the older ones though...
    I figure it'd be more compatible with the T595/955i as that's the first
    bike they were designed for.
    Toosmoky, Oct 15, 2009
  2. Bernd Rosemeier
    Toosmoky Guest
    Apparently there is a bike dyno in Cairns.
  3. Bernd Rosemeier
    CrazyCam Guest
    That's what I thought too, but, Roger, the guy who told me this, knows
    Wayne (Mr.TuneBoy) and Roger was one of the first dyno operators to use
    TuneBoy, with Wayne standing beside him, showing him how to work it, so....
    Yeah, well the TuneBoy.exe does come up with 955 dash on it. :)
    I actually meant that the Rocket III, from the shop, has programming
    which sez stuff like, if in 1st, 2nd or 3rd gear, and the rider asks for
    full throttle, ignore him/her, and only give them 40% throttle.
    I think it also decides that something like 210 kph is quite enough for
    anyone, although it can be retrained from this bad habit by use of
    TuneBoy. ;-)
    as you say in another post:-
    "From memory the cable isn't that expensive but the licence is and is
    unique to each ECU.
    You're welcome to borrow the cable and USB adaptor anytime if you want
    to save yourself a few bucks."
    Yup. $200 seems to be the going price for a key, which is coded to the
    ECU identity, thus one key works for one ECU, on several copies of TuneBoy.
    Cable and software, IIRC was another $200.
    I,too, have the cable and software, and I too am prepared to
    lend/help/whatever anyone who wants to only pay for the key, and live in
    the Sydney area.
    N.B. the USB cable I have is the proper one for Triumphs, it may, or may
    not work for other makes of bikes.
    regards,
    CrazyCam
    CrazyCam, Oct 15, 2009
  4. Bernd Rosemeier
    alx Guest
    That cable is _very_ expensive if you lose it or your toolbox gets
    pinched.
    I've checked..cannot get a replacement cable..Have to buy a whole
    "new" kit. Not real impressed at that policy.
    alx, Oct 15, 2009
  5. Bernd Rosemeier
    CrazyCam Guest
    OK, in a way, I agree with you about the policy, but, to be fair about
    things, we, as in the populace of aus.moto, if we really had to,
    actually have enough technical expertise amongst us that we could knit a
    replacement cable.
    I suspect we'd find that the cable would cost us a fair amount of money
    for bits that aren't exactly common at Dick Smith's, but we could do it.
    Then again, we wouldn't (collectively) bother to do this unless or until
    it was one of "ours" who needed it, and we certainly wouldn't bother,
    just to under cut Mr.TuneBoy. Well, that's my opinion, anyway.
    regards,
    CrazyCam
  6. Bernd Rosemeier
    Toosmoky Guest
    Urban Legend rather than Urban Myth then... ; )
    Just checked the site. I thought it was $100 for the cable, $400 for the
    licence key/unlock code. Software free. It's been a while... It is $199
    for the key. Great! $200 less than I thought... : )
    Tuneboy.com.au sell adaptors for other makes for $49 each.
  7. Why did you ditch the Buell for the Vee? Mechanical issues? I love my Vee
    (which is going to a happy new owner on Saturday) but they really need a beef
    up in the brake department.
    Fraser
    Fraser Johnston, Oct 15, 2009
  8. Cool. I like their streetfighter looking things but the air compressor engines
    really put me off. Jap is hard to go by for decent power and reliability for
    not much money.
    Fraser
  9. Bernd Rosemeier
    Bill_h Guest
    Thanks Doug for the offer. I figure I'll stump up for the full kit and I
    can then play with it as necessary. Offer is appreciated though.
    Bill
    Bill_h, Oct 15, 2009
  10. Bernd Rosemeier
    Bill_h Guest
    Thanks for that. Mine is a 2001 Sprint so it won't be a problem.
    Bill
  11. Bernd Rosemeier
    G-S Guest
    We have ADSL2+ which syncs at 22Mbit downstream/1Mbit upstream
    (maximum possible is only a little more than that I gather).
    Cable is available in limited areas at 100Mbit downstream.
    Most towns are cities have access to ADSL2+ but the connection speed
    varies depending upon the distance from the exchange and there are some
    areas that have technology blockers which restrict connections to ADSL1
    at a max of 8Mbit.
    G-S
    G-S, Oct 15, 2009
  12. Bernd Rosemeier
    atec 7 7 Guest
    You should ride one pistons cams and pipes makes a new ride and they do
    handle quite well nothing soft and floppy in the frame these days
    atec 7 7, Oct 15, 2009
  13. Bernd Rosemeier
    Nev.. Guest
    I guess they read my criticism :)
    Nev..
    Nev.., Oct 15, 2009
  14. I will take one for a spin next chance I get and report my findings here.
    Fraser
    Fraser Johnston, Oct 16, 2009
  15. Bernd Rosemeier
    atec 7 7 Guest
    AH but once it's had it's guts ripped out and replaced with after-market
    you don't get to visit the dealer anywhere near as much
    throw the suspension away for some Eu stuff and it rides smoother and
    the bucks spent at the local machine shop balancing all the moving stuff
    helps to partially compensate for the square cams realistically it
    aint gonna idle smooth EVER but coming off a corner as the torque bits
    and it begins to make "that" noise through the gears ...
    atec 7 7, Oct 16, 2009
  16. You sound like a Jaguar owner "Once you spend the first 50 grand getting it
    right, then it just comes alive and only costs you 10k a year in routine
    stuff." Or you just buy something from Japan and ride it.
    Fraser
  17. Bernd Rosemeier
    Nev.. Guest
    Never understood all the allegations about twins and torque. None
    seem to produce as much as a good jap inline 4.
    Nev..
    Nev.., Oct 16, 2009
  18. Bernd Rosemeier
    atec 7 7 Guest
    Don't be a dick , I didn't buy a buggered v12 Jag and do my dough
    I did buy a pranged bike and rebuilt it how I wanted
    a concept you are familiar with
    you also understand toys cost money .
  19. Bernd Rosemeier
    atec 7 7 Guest
    Well you are a nev "nuff"
    None
    but they have to many cylinders to be a twin
  20. Bernd Rosemeier
    G-S Guest
    I don't really think that twins produce more torque than inline 4's
    (other things being equal) but the sound and feel of a good twin is SO
    SO SO much more appealing (to me at least) than the way an inline 4
    feels that I can put up with lower peak power and vibes at idle.
    G-S
    G-S, Oct 19, 2009
