Bathurst 1000
Discussion in 'Australian Motorcycles' started by Bernd Rosemeier, Oct 6, 2009.
  1. In aus.motorcycles on Sat, 24 Oct 2009 03:00:24 GMT
    News to me really. As there's absolutely no bloody doubt when you
    *ride* one that the action is above 5k.
    Sure, if you get a large enough motor it will pull more than a small
    one. THe Norge will pootle along happily enough at low revs and will
    even acellerate from there.
    But nothing like it pulls from 5k. NOthing at all.
    The Old Girl and the Hack Guzzi (one an 850 one a 950) are quite
    simialr although they both have holes at around 4k for some reason so
    it disturbs the seat of the pants feeling. But still the fun for both
    is above 5k.
    Was so on the small blocks I've ridden too.
    Wheras on the long stroke pommy bikes (singles not twins I've only
    started a Vincent not ridden one) they didn't have much difference
    between low and middle.
    The Devil now it has a decent carb is all midrange..
    Zebee
    Zebee Johnstone, Oct 24, 2009
    #81
  2. Bernd Rosemeier
    Lars Chance Guest
    Yep; the K100's certainly torquey all right.
    http://www.ibmwr.org/ktech/dyno-update/index.shtml
    Yet the humble, air-cooled, carby R100 develops more torque and from
    1500rpm lower.
    http://www.bmwmoa.org/forum/showthread.php?t=34800
    Lars Chance, Oct 24, 2009
    #82
  3. Bernd Rosemeier
    G-S Guest
    Lars Chance wrote.
    You can't directly compare figures from one dyno to another, whilst they
    all quote direct torque they use different methods and a bike measured
    on one type of dyno will get a different result on a different type of dyno.
    Annoying I know...
    G-S
    G-S, Oct 24, 2009
    #83
  4. Bernd Rosemeier
    JL Guest
    You must be a Hammo artefact given the continual careful missing the
    point to still try and "win".
    I said
    "The
    4cylinder I replaced with my current twin had oodles of "low down
    don't have to go looking for it grunt". My current twin has it's
    torque peak further up the rev range than the 4 did. In fact the 4 had
    probably half as much again grunt anywhere in the rev range as the
    twin does. "
    The Bandit 1200 4 cylinder referenced above had oodles more grunt -
    it's peak torque was pretty flat from down around a thousand rpm right
    through to a relatively low redline for a 4 (errmm 9-10 grand mebbe ?
    I forget now). Definitely a lot more across the more - hence the
    "probably half again more" - that's seat of the pants - but if as I"m
    sure you will - you dig up the dyno chart I wouldn't be at all
    surprised if it was more than that. It was a tractor of a motor.
    Lastly, before you wave it around triumphantly, you'll note the above
    quote didn't claim to be a comparison of comparable motors - that is
    in fact exactly the point - the closer to under square you go the
    lower the HP, the higher the torque (and yes, torque or turning force
    is "grunt" as felt at the seat of the pants) it's why Hogly only
    release torque figures (because the engine config means the HP numbers
    are really sad), and similarly why a number of big (>600cc) singles
    put out HP numbers less than some (4stroke) 250s.
    Just because some twins display the characteristics you like doesn't
    mean it's a function of the number of cylinders any more than the fact
    that some redheads are scary psychos means that redheadedness causes
    scary psycho behaviour (correlation not equalling causation and all
    that).
    JL
    JL, Oct 26, 2009
    #84
  5. Bernd Rosemeier
    Lars Chance Guest
    So what you're basically saying is that you were comparing an apple with
    an orange and the whole post had nothing to do with the discussion to
    which you replied?
    ....... and you called ME stupid?
    Lars Chance, Oct 26, 2009
    #85
  6. Bernd Rosemeier
    Hammo Guest
    Yeah, low blow, JL. I'm with Elsie.
    Post some dyno graphs or something......
    Oh, all elephants are grey, but not all grey things are elephants would have
    been better than the redhead example.
    Hammo
    Going for science rather than seat of the pants....though that can depend on
    the pants.......
    Hammo, Oct 26, 2009
    #86
  7. Bernd Rosemeier
    Lars Chance Guest
    Hang on; I thought I WAS you?
    Bugger. That means I must be Johno then.
    #87
  8. Bernd Rosemeier
    G-S Guest
    9500 I think, I forget too.
    A Bandit 1200 has more low down torque than any twin I've owned or
    ridden with the exception of an M109.
    G-S
    G-S, Oct 26, 2009
    #88
  9. Bernd Rosemeier
    JL Guest
    No. But well done for being predictable.
    <speaking very slooooowly for the denser members of the class> The
    power characteristics you like are unrelated to the number of
    cylinders and totally related to the engine config.
    I didn't actually - I provided that as one of the two possible
    options. However you're starting to convince me that was the correct
    choice.
    JL
    JL, Oct 26, 2009
    #89
  10. Bernd Rosemeier
    JL Guest
    Yeah undoubtably - you trained him well :) If he's not you of course
    Awww, I was gentling tickling for a thread diversion there - both
    Betty and Toosmoky can usually be incited on that topic :)
    You and I both know that's a diversion, in your best tradition.
    I'm pretty sure you KNOW the science:
    "Low down grunt" aka "high levels of torque at the bottom of the rev
    range" is a function of engine config - long stroke motors with
    (comparatively) fewer smaller valves, narrower exhausts and narrower
    inlet tracts will provide more torque down low in the rev range at the
    expense of HP at the top end of the range when you compare two engines
    with the same number of cylinders and same capacity.
    The number of cylinders is irrelevant to the engine torque/hp trade
    off.
    For the same capacity and stroke a 4 will have smaller pistons than a
    twin. That config will leave the 4 with more torque down low than the
    twin as it will be more under square. There's a physical limitation on
    max piston speed with current metallurgy so the usual trade off is to
    make the 4 closer to over square so you can rev it higher - torque
    goes down and HP goes up with the rev limit (in simple terms - there's
    more to it than that). The general outcome for non sports bike is a
    bit more of both than a twin for the equivalent capacity and stroke.
    For sports bikes a lot more HP and about the same torque.
    JL
    JL, Oct 26, 2009
    #90
  11. Bernd Rosemeier
    JL Guest
    Ditto in my opinion, noticeably more than a 2004 Guzzi Le Mans 1200
    twin in my opinion ( I rode them back to back at the time) and I would
    think the Guzzi is closer to the torque side of the trade off than the
    HP side (although the newer 4V head would def be a move back towards
    max HP)
    JL
    JL, Oct 26, 2009
    #91
  12. Bernd Rosemeier
    LC Guest
    Is there a reason you keep explaining the *blindingly obvious* like it
    has some sort of relevance to the thread JL?
    Blind Freddie's deaf 4yo knows that long-stroke is a factor in
    torquiness.
    Here; let me help you with some more fascinating revelations:
    Water is wet.
    The sky is blue. (1)
    Fire is hot.
    Nigerian emails are sometimes dishonest and
    V-Twin motorcycles almost always have more low-down grunt than
    equivalent 4cyl motorcycles (despite the seemingly collective
    aus.motorcycles delusion to the contrary).
    LC, Oct 27, 2009
    #92
  13. Bernd Rosemeier
    JL Guest
    Right so now you finally admit that you were carefully ignoring the
    bleeding obvious while trying to prove a untenable position.
    JL
    Yes I kept explaining the bleeding obvious ever yet more simply
    because you were making it clear you were struggling to get it (or
    pretending to)
    JL, Oct 27, 2009
    #93
  14. Bernd Rosemeier
    LC Guest
    You're getting silly now JL. I was *ignoring* your obvious because it
    was irrelevant. No-one had questioned anything about engine design
    affecting torque and no one has expressed any interest in it at all
    (except yourself) so it *remains* irrelevant.
    No one has mentioned fuels yet either; are you going to get all
    hysterical and dribbling over them next?
    LC, Oct 27, 2009
    #94
  15. Bernd Rosemeier
    Lars Chance Guest
    I can't find a LeMans 1200 (do they even exist?) but the 1200 Griso
    (with the 4V head)
    http://www.motorcycle-usa.com/PhotoGallerys/xlarge/09_hd_guzzi.jpg
    leads the 1200 Bandit until about 3700 then falls into a rather large
    hole just as the Bandit starts coming on strong
    http://www.factorypro.com/images/dyno_chart_s7410.jpg
    The BMW R1200R kills the Bandit all the way though
    http://www.webbikeworld.com/BMW-motorcycles/bmw-r1200r/r1200r-torque-horsepower.jpg
    (Nm -> foot-pounds is about .74 so 82Nm is 60 and 117Nm is 86)
    Lars Chance, Oct 27, 2009
    #95
  16. Bernd Rosemeier
    Lars Chance Guest
    1500rpm lower.
    #96
  17. Bernd Rosemeier
    Lars Chance Guest
    Sorry for the repost people.
    #97
  18. Bernd Rosemeier
    alx Guest
    I'd be willing to just settle for your own confession of being stupid.
    But did you have to praise JL for supposedly making that claim on your
    behalf?
    alx, Oct 27, 2009
    #98
  19. Bernd Rosemeier
    G-S Guest
    A couple of points.
    I mentioned in an earlier post that you can't directly compare results
    from one dyno with another dyno because they aren't calibrated.
    Secondly you are ignoring gearing, the Bandit is stronger at slower
    speeds because it's got a lower first gear.
    How do I know?
    Well I currently ride and own a 1200 Moto Guzzi and I've owned 3
    separate Suzuki Bandit 1200's (although at the moment I have a Suzuki 1100).
    Believe me, the Bandit DOES have more torque down low and will pull away
    from the guzzi at any speed you care to name.
    But the Guzzi FEELS much nicer :)
    G-S
    G-S, Oct 28, 2009
    #99
  20. In aus.motorcycles on Wed, 28 Oct 2009 20:11:50 +1100
    And looks nicer too!
    I also note that pretty well everyone who rides the new 4V Guzzis
    says they lack down low.
    Zebee
    Zebee Johnstone, Oct 28, 2009
