Batteries again (sigh)
Discussion in 'UK Motorcycles' started by TD, Jul 23, 2009.
  1. TD
    TD Guest
    So you make sure to give your "second" bike's battery (bought in the last
    year) a charge every month or so. When it comes to starting the bike, the
    starter doesn't even turn as the battery's so low, and you realise that your
    charger was broken.
    It's on charge now with a working charger. Is there any hope for it or given
    that it was so low it wouldn't even get close to turning over, should I forget
    it and get a new one? Even if it starts now, it's no good to me if it only
    holds a charge for a day etc, moan, try to get it right and still goes
    pear-shaped yadda...
    TD
    2000 GSX1300RX (red and black)
    1991 VFR400R NC30 (black and red)
    1993 Eunos Roadster (supercharged)
    Missing: SOB, Unreliable Italian exotica
    TD, Jul 23, 2009
  2. TD
    If it was *completely* flat to the point where it wouldn't even light
    the idiot lights, it may well be toast, otherwise it should be fine.
    If it is toast, it should still be under warranty.
    Krusty, Jul 23, 2009
  3. TD
    TD Guest
    Ooh, so there's hope. The idiot lights /did/ come on - I definitely know
    where /they/ are. Headlight when I tried it was, er, marginal. I'd better
    look for the receipt just in case.
    TD
    TD, Jul 23, 2009
  4. TD
    Eiron Guest
    Battery guarantees don't cover that sort of incompetence.
    And the dealers know when you are lying. :)
    Eiron, Jul 23, 2009
  5. TD
    Malc Guest
    So why did you spend most of last winter yada yada instead of buying a
    new battery?
    Malc, Jul 23, 2009
  6. TD
    The Corvette battery died after 3 years - too flat to charge. It was a
    Varta with a 5 year guarantee, & they replaced it no problem.
  7. TD
    wakefieldpa Guest
    I revived an old battery with some new acid. The battery was good,
    just kept getting dischaged by the alarm.
    I was fed up buying new batteries at ~50 a shot, so i'm trying a new
    tack.
    Paul.
    wakefieldpa, Jul 23, 2009
  8. TD
    Beav Guest
    tack.
    Make sure to hammer it home fully, or the acid wil leak out.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 23, 2009
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, Beav
    I really wish you'd get your quoting sorted out.
    go and talk to the Catholics.
    Wicked Uncle Nigel, Jul 23, 2009
  10. TD
    How do you do it (**** up your posts that is, not hammer a battery)?
    You've just made 3 posts in under 3 minutes, 2 of which you quoted
    properly, but somehow you managed to screw this one up the same way you
    often do. I am genuinely intrigued!
  11. TD
    I suspect it's X-Newsreader: Microsoft Outlook Express 6.00.2900.5512
    CT, Jul 23, 2009
  12. TD
    Simon Wilson Guest
    Probably the acid. Or the paint fumes.
    Simon Wilson, Jul 23, 2009
  13. TD
    Nige Guest
    hehe - age :)
    Nige, Jul 23, 2009
  14. TD
    zymurgy Guest
    You grumpy bastard ;)
    I thought you'd been on holiday !
    Oh, the FJ is up on stilts, getting fettled, so i'd love you to spend
    15 mins in the shed if poss.
    http://img199.imageshack.us/img199/5334/strip1s.jpg
    Pretty please.
    Ta,
    Paul.
    zymurgy, Jul 23, 2009
  15. TD
    Malc Guest
    Jolly good, just making sure ;-)
    Malc, Jul 23, 2009
  16. TD
  17. From personal experience...
    If you let it lie discharged for longer than a couple of months and the
    battery is still fairly new, you might get away with it, but I wouldn't
    trust it as a reliable stand-by. Best to use that battery in the bike
    for a while to keep it regularly cycled and see if it handles that ok.
    If it does, then use it as a back-up and make sure it's on proper
    mainenance charge.
    The older the battery, the less likely you are to get away with it; to
    the extent that a battery a few years old just won't tolerate it at all
    and dies permanently. There are the odd exceptions, of course.
    Grimly Curmudgeon, Jul 23, 2009
  18. TD
    zymurgy Guest
    Cheeky **** ... that's my airport hack bike that is,
    P.
  19. TD
    Beav Guest
    And I really wish you had something serious to worry about.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 24, 2009
  20. TD
    Beav Guest
    That's piss easy. Sometimes I get the indents, sometimes I don't. Sometimes
    I noice it when I'm replying, sometimes I don't, but all times I really
    don't think it's anything to get upset about.
    Me too. Nothing has changed on the settings in my newsreader (obviously,
    it's a shite one albeit the most popular one used on here).
    You don't hammer a battery either, it's the tack one hammers.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jul 24, 2009
