Battery and alternator load
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 29, 2005.
  1. Right, the battery on my bike is 14Ahr but I'm thinking of fitting an
    accessory that is rated at 20amps. I'm only going to be giving it short
    blasts of a few seconds at a time but how likely am I to **** the
    battery/bike/anything else?
    I appreciate the answer is "quite likely", but hey, this is one
    motherfucker I just *have* to have <EG>
    P.S.
    Will the fitting of a relay help?
  2. Whinging Courier
    MikeH Guest
    You'll need suitably heavy cable & fuse direct from the battery,
    preferably using a relay to avoid burning the switch contacts.
    Shouldn't do any damage to the bike unless it catches fire due to low
    capacity wiring - is it a *LOUD* horn?
    MikeH, Oct 29, 2005
  3. In uk.rec.motorcycles, MikeH amazed us all with this pearl of wisdom:
    Thanks for all of that. I've got some phat wiring should the need arise
    although I'm hoping some will be included.
    Heh, rumbled.
    I haven't decided /which/ one yet, but it's deffo going to be *one* of
    these motherfuckers!
    Right, for everyday use, I thought either the "Big Blast Horn" here:
    http://www.top-gear.net/products.asp?u=464891N90400.9540727735&deptid=
    121
    or the "Twin Air Horn - External" on page two[1]
    Those are great and all but for general stupidity I'd *really* like a
    set of either of these:
    http://www.top-gear.net/product.asp?u=464891N90400.9540727735&pnid=204
    &deptid=148
    Or
    http://www.top-gear.net/product.asp?u=464891N90400.9540727735&pnid=199
    &deptid=148
    The first one is better VFM but the second sounds better IMHO.
    I change my mind more often than a tart changes her hair so tomorrow it
    could be something else[2] but I really do like those musical ones -
    Heh, "The Godfather's" not bad but not nearly bonkers enough.
    [1] Sorry, I would link to the sounds but for love nor money, I cannot
    find the source, closest I can get is the location of the speaker icon.
    [2] I've also got some new beer to try.
  4. I had one of this pair...or similar.
    http://www.top-gear.net/product.asp?u=464891N90400.9540727735&pnid=413&deptid=231
    Just the low tone one was fucking impressive on its own.
    <googles>
    In fact it was identical to this one...
    url:http://marinestore.co.uk/Merchant2/...10027&Category_Code=horns-and-audible-warning
    GS850 x2 XS650SE / SE 6a
    Grimly Curmudgeon, Oct 29, 2005
  5. Grimly Curmudgeon, Oct 29, 2005
  6. This.... will make you get all tickly.
    http://www.groverairhorns.com/
  7. Whinging Courier
    A while ago, some **** posted a url for a page full of redneck pickups
    'equipped' with *hyuuge* horns - horns that filled the bed of the
    truck in a couple of cases. Fucked if I can find that page now,
    though.
    Pip, Oct 30, 2005
  8. Whinging Courier
    More bad form:
    http://www.trainweb.org/mdamtrak199/horns.html
    Read it and weep, CourierBoy.
    Pip, Oct 30, 2005
  9. Whinging Courier, Oct 30, 2005
  10. In uk.rec.motorcycles, Pip amazed us all with this pearl of wisdom:
    http://trainweb.org/mdamtrak199/horns/phorn/P5Lnew.jpg
    Nice!
    The others are a trifle large and would add at least 25% to the weight
    of the bike, not to mention the awkwardness of fitting.
    I suppose the rear wheel could be taken out and have a sprocket welded
    to the end of an air tank, thus making a rat-road roller but how on
    earth would you get the tank to turn whilst still supplying air to the
    pipes for the horn to work?
