Battery bolts
Discussion in 'Motorcycle Technical Discussion' started by GoHabsGo, Mar 28, 2008.
  1. GoHabsGo
    GoHabsGo Guest
    Well, I lost one of the battery bolts over the winter. Does it make any
    difference what type of bolt I use to replace it? Does it matter if it is
    different than the original material? Perhaps a stupid question but I
    always that questions not asked are even more so.
    Thanks.
  2. GoHabsGo
    NA Guest
    I don't know if it'll make any difference but you can easily get a
    replacement though. Drop by a local motorcycle dealer's service area,
    and you'll probably see a bunch of dead batteries. You can probably get
    one for free if you frequent that shop or ask nicely. These dead
    batteries are trash and going to recycling centers anyway.
    NA, Mar 28, 2008
  3. Probably not. Never had a problem with this.
    You should check the terminals occasionally
    anyway so it's easy to swap if you see any
    corrosive problems.
    Rob Kleinschmidt, Mar 28, 2008
  4. GoHabsGo
    . Guest
    No, it doesn't matter what the material the bolt is made of, but, if
    you could find a 1/4-20
    BRASS bolt and square BRASS nut in the specialty boxes at your local
    hardware store, that would be the optimum
    solution.
    If you don't want to look for brass hardware, an ordinary 1/4-20 steel
    bot and hex nut will work just fine.
    I find it sad that motorcyclists are so mechanically ignorant that
    they have to take their motorcycle to a $tealer$hip and be ripped off
    by the part$ department when they have the simplest problems, like
    lost hardware.
    One rider wrote that he'd lost a bolt, and the prick in the part$
    department told him he had to buy a whole new battery...
    ., Mar 28, 2008
  5. GoHabsGo
    GoHabsGo Guest
    Thanks for the feedback. I ended up buying a few ordinary steel bolts.
    Nuts were not needed in my case as they thread right to the battery.
    I don't think this is necessarily a mechanical question but more of a
    chemistry related question. I just wanted to make sure that the bolts I
    use wouldn't have a reaction, particularly if each bolt was a different
    metal alloy.
  6. GoHabsGo
    Dave Emerson Guest
    You were right to be concerned and steel bolts are not a good permanant
    solution, for the reason you suggest.
    A bolt for an old battery, as per other response, is your best bet.
    Dave Emerson, Mar 29, 2008
